[3 phase induction motor] direction of rotation
In summary, the direction of rotation of a 3 phase induction motor's rotor is determined by the direction of the rotating magnetic field, which is dependent on the phase rotation. This is due to the phenomenon of flux bunching, where the rotor bars develop a mechanical force in the same direction as the rotating flux to satisfy Lenz's law. The direction of the rotor-bar current that produces the flux can be determined using the right-hand-rule.
varunag
25
How is the direction of rotation of rotor of a 3 phase induction motor determined? Assume the rotor to be squirrel cage or any other type of rotor.
I was able to reason this out, but couldn't actually write it on a paper since my explanation lacked the physics... (it was based on simple understanding of electromagnetic induction)
I would be thankful if someone could give a good explanation for this.
TIA
-varunag
TIA
-varunag
It's based on the direction of the rotating magnetic field, which is dependant on the phase rotation. Hence if you swap in two line leads on a three phase motor, the direction of the magnetic field and thus motor will reverse.
CS
Thanks "stewartcs".
but as I said in my post that I was able to justify the direction. I want to know the physics involved in this. If you could help me with that it would highly appreciable.
varunag said:
Thanks "stewartcs".
Here is a simplified version of how they rotate:
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/indmot.html#c1
Conceptually, in a multiphase motor such as a three phase motor, the rotor essentially follows the rotating magnetic field generated by the stator. Since the stator windings are 120 electrical degrees apart (3-phase motor), they develop alternating magnetic fields in the stator coils (which are essentially magnets now). The "magnets" pull on the rotor bars and cause it to rotate thus turning the motor.
Here is a visual of how the field rotates.
http://www.tpub.com/neets/book5/18b.htm
Does that help?
CS
Thanks once again. But I think I'm unable to explain my question. I try once again. "How does the rotor feel the torque?(say for squirrel cage induction motor)".
Let me tell you my explanation.
Considering a squirrel cage rotor. Consider one rectangular face of the rotor. There is a slip in an induction motor. As a result there is a relative speed of rotating field with respect to the rotor. Now as the rotating field approaches this rectangle, the flux through this increases, but by "eletromagnetic induction principles" we can say that, the rotor will oppose this increase and will try to move away --> here moving away will mean that it has to move in the direction of the rotating field. But since the speed of the rotating field is more (due to slip) it somehow will move past this rectange. And then the flux through the rectangle will start decreasing. To oppose this the rectangle will move towards increasing the flux --> hence in the direction of magnetic field.
Hence we can say that the rotor rotates in the direction of rotating field.
Is this explanation correct? If no, atleast now you would better understand my question.
-varunag
-varunag
The rotor "feels the torque" due to "flux bunching". In accordance with Lenz's law, the voltage, current, and flux generated by the relative motion between a conductor and a magnetic field will be in a direction to oppose the relative motion. Hence, to satisfy Lenz's Law, the conductors must develop a mechanical force or thrust in the same direction as the rotating flux. For this to happen, "flux bunching" must occur. Thus, the generated flux due to rotor-bar current must be in the opposite direction. The direction of the rotor-bar current that produces the flux can be determined by using the right-hand-rule.
Hope that helps.
CS
thanks stewartcs. this helps.
cheers,
-varunag
What is a 3 phase induction motor?
A 3 phase induction motor is a type of AC motor that converts electrical energy into mechanical energy through electromagnetic induction. It is commonly used in industrial applications for its reliability and efficiency.
How does a 3 phase induction motor work?
A 3 phase induction motor has a stator and a rotor. The stator contains three sets of windings that are connected to a 3 phase power supply, creating a rotating magnetic field. The rotor, which is made of conductive bars, is placed within the magnetic field and the interaction between the two creates a torque, causing the rotor to rotate.
What determines the direction of rotation for a 3 phase induction motor?
The direction of rotation for a 3 phase induction motor is determined by the direction of the rotating magnetic field. This is dependent on the order in which the three phases are connected to the windings in the stator. Reversing the order of the phases will reverse the direction of rotation.
Can the direction of rotation be changed in a 3 phase induction motor?
Yes, the direction of rotation can be changed in a 3 phase induction motor by swapping the connections of any two of the three phases. This can be done manually or through a motor control system.
What are the applications of a 3 phase induction motor?
3 phase induction motors are commonly used in industrial settings for various applications such as driving pumps, compressors, fans, conveyors, and other machinery. They are also used in household appliances like washing machines and air conditioners.
  • Electrical Engineering
