Notions of simultaneity in strongly curved spacetime
In summary: This statement seems to suggest that for strong curvature, simultaneity may become an issue that GR can't accurately handle. So, we may need more general theories to handle this.
PAllen
2,412
While simultaneity conventions for inertial frames in flat spacetime (SR) are non-controversial, numerous questions, discussions, and debates in this forum indicate how confusing and controversial notions of simultaneity can be for more general cases. A couple of formal and true answers are generally unsatisfying to many:
- Simultaneity is undefinable, in any preferred way, in general. It is never observable or measurable anyway.
- You can pick any any event not in your past or future light cone to be a simultaneous event to your now. Except locally, there is no preference. (Sufficiently locally, one can argue for a preference for the Fermi-Normal simultaneity).
I thought of a possibly useful way to classify simultaneity notions for fairly general spacetimes and observers (I assume an orientable spacetime). Of critical importance is that any sensible implementation of these notions for inertial observers in flat spacetime produce the same result. However, they may differ wildly in curved spacetimes and/or for non-inertial observers. I assume, in what follows, that any observer can be considered past/future eternal unless their world line encounters a singularity.
1) It is reasonable to expect that any event in your causal past (on or inside your past light cone) is simultaneous to some event in your past.
2) It is reasonable to expect that any event in your causal future (on or inside your future light cone) is simultaneous to some event in your future. Executing (1) in various ways produces a foliation (family of simultaneity surfaces) that at least covers the union of all of your past light cones (all events that are ever in your causal past). I propose to call such foliations past inclusive if they at least cover your total causal past, but may cover more; and past only if they cover nothing except your total causal past.
Similarly, notion (2) leads to future inclusive and future only simultaneity conventions.
Finally, one may require that simultaneity be designed to cover any event in your total causal past or future. Call these causal inclusive and causal only
As mentioned, for inertial observers in flat spacetime, these are all the same, and the obvious implementation is Minkowski frames.
Now consider these for the Oppenheimer-Snyder spacetime (asymptotically flat; collapsing space time region; interior and exterior SC regions eventually). I choose this for qualitative plausibility and to avoid the white hole region (the notions certainly apply to full SC geometry).
A) Consider a distant, hovering, eternal, observer. Exterior SC type time slices represent an implementation of past-only simultaneity. No events on or inside the EH are covered. On the other hand, any future-only simultaneity implementation covers the interior, and indeed, is also a causal inclusive simultaneity. There are infinite such choices which can agree with local Fermi-Normal simultaneity.
B) Consider an observer that is distant and hovering into eternal past, but at some moment free falls into the BH (late enough so they hit the singularity). For this observer, both past-only and future-only conventions include both interior and exterior events. However, past only covers only a portion of spacetime - ending with the past of the termination of free fall world line on the singularity. A future only simultaneity covers all of space time, and is thus also a causal inclusive simultaneity.
In my opinion, it seems clearly desirable to favor causal inclusive simultaneity; and thus it is unfortunate that so much attention is paid to SC time slice simultaneity, which is exclusively a past-only simultaneity.
Without claiming to have understood all of the above, especially the different theories/interpretations mentioned, I would like to add the question on how far we can analyze such things as 'simultaneity' based on existing GR theory when considering 'strongly curved spacetime'.
The reason for this thought stems from some statements of Einstein in his book 'The Meaning of Relativity' (6th Ed, 1955):
"In this connexion the following should be noted: The present theory of relativity is based on a division of physical reality into a metric field (gravitation) on the one hand, and into an electromagnetic field and matter on the other hand. In reality space will probably be of a uniform character and the present theory be valid only as a limiting case. For large densities of field and of matter, the field equations and even the field variables which enter into them will have no real significance. One may not therefore assume the validity of the equations for very high density of field and of matter, and one may not conclude that the ‘beginning of the expansion’ must mean a singularity in the mathematical sense. All we have to realize is that the equations may not be continued over such regions."
In general this is more or less the present understanding of GR; it is an "effective field theory" that is a low-energy approximation to some more fundamental theory.
However, none of that affects the predictions of GR about event horizons and black holes, at least not for BHs of sufficiently large mass (certainly any BH of stellar mass or more), because at the horizon of any such BH, and even far into its interior, there are no "large densities of field and of matter"; spacetime curvature for a hole of that size does not become large until you get close to the singularity at r = 0.
Actually, this is a question which bugs me all the time. What do we consider as 'large' in terms of matter and field density? What is the cut-off point?
I realize there is no hard answer to this question, and we have to go with certain heuristics. My understanding has been that matter and field density near or within a stellar mass black hole can be considered large enough.
This may not apply to supermassive black holes, as the average matter density does tend to get closer to that of ordinary matter, but any black holes even a few order of magnitude smaller should qualify as having large matter and field densities?
If you want to consider quantum theories or 'what really happens in our universe', those are very different questions from what classical GR predicts.
Because of the strength of evidence for supermassive collapsed object, any quantum + gravity theory must address the facts:
- during collapse, average matter density is not large at time of crossing EH
- curvature = tidal gravity is mild.
Be that is it may, in the context of beyond classical GR, the question is wide open. There are, for example, several approaches where a true horizon never forms, even for a super massive BH (fuzz balls approach from string theory is just one of half dozen such approaches). Any approach that preserves unitarity would seem (IMO) to require some relaxation of true horizon behavior.
As you say, there is no "hard" answer to the question, because we don't know for sure what more fundamental theory classical GR is the low energy limit of. However, the best current belief, AFAIK, is that "large" means "approaching a value of 1 in Planck units", since Planck units are the natural units of quantum gravity. In other words, curvature becomes "large" when the radius of curvature becomes small enough to be of the same order as the Planck length. This was the criterion I was using when I said that the curvature at the horizon, and even deep into the interior, of a BH of stellar mass or larger is not "large"--the radius of curvature is many, *many* orders of magnitude larger than the Planck length.
"Field density" means radius of curvature; see above for why it's not "large" near or within a stellar mass BH. For matter density, the corresponding criterion would be the Planck density (one Planck mass per Planck length cubed). The density of collapsing matter in an idealized spherically symmetric collapse is far smaller than the Planck density until the matter has collapsed almost to r = 0 (i.e., it is not "large" at the horizon and well inside it).
Not by the Planck criterion. By that criterion what we consider "ordinary matter" has a density of something like 10^-93. Even neutron star matter has a density of something like 10^-80 in Planck units. It takes a *lot* more than a few orders of magnitude to get from "ordinary" densities, or even neutron star densities, to "large" densities in Planck units.
PeterDonis said:
...the best current belief, AFAIK, is that "large" means "approaching a value of 1 in Planck units"...
OK, I wasn't aware of this. If that is the case, then I suppose nowhere in the Universe is matter and field density large, except very close to singularities within black holes.
I was going by references I have come across stating 'curvature of space is large near a big star' or a neutron star. In fact, thinking about it, that may not be quite the same thing as matter/field density (rather its rate of variation perhaps), or may be those are also relative statements.
And very close to the Big Bang.
Those statements are using a different criterion for "large", basically comparing the matter/field density to that of "ordinary matter". Which criterion you use depends on what you want to use it for. If you want to determine at what point classical GR, as a low-energy effective field theory, starts breaking down (i.e., stops being a good approximation), the Planck unit criterion is the right one to use (at least, according to our best current understanding).
Yes, there is that. Perhaps another case would be at velocities close to c? Not at all sure that is correct, just a random thought...
I can accept that as a good answer, to the best of our current knowledge as you mentioned.
No. The criterion can't be frame-dependent, and "velocity close to c" is frame-dependent.
OK. I thought it might be a wrong idea even when I posted it. The clarification helps.
PAllen said:
...Be that is it may, in the context of beyond classical GR, the question is wide open. There are, for example, several approaches where a true horizon never forms, even for a super massive BH (fuzz balls approach from string theory is just one of half dozen such approaches). Any approach that preserves unitarity would seem (IMO) to require some relaxation of true horizon behavior.
I somehow missed this post earlier. Yes, I can see that logic.
2) It is reasonable to expect that any event in your causal future (on or inside your future light cone) is simultaneous to some event in your future.Executing (1) in various ways produces a foliation (family of simultaneity surfaces) that at least covers the union of all of your past light cones (all events that are ever in your causal past). I propose to call such foliations past inclusive if they at least cover your total causal past, but may cover more; and past only if they cover nothing except your total causal past.
That looks very interesting. Can you translate the above into normal English, with which I mean the kind of physicists English that Einstein and Feynman used? Then likely more people will understand what you mean and participate. :tongue2:
If you ask a specific question, maybe I can help. I put a lot of time into writing that up, and it is as clear and simple as I know how to make it without writing a 'book'. IMO, Einstein and Feynman would understand it perfectly and be able to discuss it.
Are you familiar with backward and forward going light cones, and their use to define causal structure of spacetime?
?? I suppose that they would be able to understand it and translate your mathematical English into plain English. Einstein would perhaps talk of rods and clocks, and Feynman would give colourful examples.
Light cones, yes; their use to define "causal structure of spacetime", no. And I don't believe in "structure of spacetime" as a physical entity. Of course, I do believe in space-time events as physical occurrences.
Though we have had little luck understanding each other, I will try one tack (it would be really helpful if you asked a specific question).
Do you think it is plausible to expect that if I compute that a physical detector somewhere in the history of the universe receives a signal from me, that I would want to assign a time coordinate to this predicted physical event?
Background: I can compute, purely using SC coordinates (exterior + interior, with limiting process over SC radius), that a physical detector with its own clock falling with (but above, in vacuum) a collapsing body will receive a signal from me at a specific finite reading on its own clock, when it has fallen through an event horizon to near the singularity. Is there some 'hand of god' that prohibits me from assigning a time coordinate to this predicted physical event, because I will never detect this event?
So basically you are saying that simultaneity is a convention, right?
But it does not mean that you can use different conventions at the same time.
With SC type time slicing there is no EH and no interior region for collapsing mass. All you can get is "frozen star". EH appears at infinite future i.e. never.
In order to have EH and interior region with SC type time slicing you have to have eternal BH.
PAllen said:
[..](it would be really helpful if you asked a specific question).
Regretfully it would require specific questions about nearly ALL of the cited text - and I really think that this is why there was little feedback on your first post. However, it seems that we won't need it, see next:
In fact you are continuing the discussion that I started earlier about the theoretical possibility of assigning distant time, even putting physical clocks at distant places, thus making the discussion very concrete and physical. Evidently this is what we agree on.
However, that brings us immediately to the real sticking point that has all the time been lurking over the discussions of the last weeks:
If you use a valid coordinate system, then there is nothing against it. The issue is about what kind of coordinate systems are valid in GR, and if perhaps contradictory mapping models can be made that match the mathematics of GR (but perhaps not all equally well matching the foundations), thus resulting in contradictory predictions.
We know that this can happen with Earth maps; however that is without consequence, as it's easily verified (I can give a simple example). It appears that the same problem occurred in GR, but without the possibility for a direct "reality check".
On a side note there is a somewhat similar case in SR, with tachyons. Are tachyons really SR? Must they exist if one can "fix" the math to contain their mathematical possibility?
For the case of Earth maps, do you claim there is case of conflicting prediction for maps as used in differential geometry:
- associated with each map is a metric expression, such that each map expressed the same geometry
- if one is talking about the same sphere using different maps, and one map doesn't cover all of the sphere, you use other maps to cover the rest, such that you are always describing the same complete sphere.
Who decides what is a valid coordinate system? Differential geometry has a well defined, precise, answer to this (see any definition of topological manifold, refined further to become a pseudo-riemannian manifold).
If you think this is wrong, then what is your precise criteria for a valid coordinate system? If it is different from above, you have a new theory, not GR as understood by everyone else. And in this new theory, general covariance is rejected, because that requires that any coordinates allowed by the criteria in the prior paragraph or good.
One possible analogy for our disagreement is:
- Imagine a 2-sphere in polar coordinates. Bob doesn't like what happens at or near the poles. So Bob decides to analyze only different object: a sphere missing a little disk around each pole. This is a valid, different geometric object. It is easy to demonstrate that you have holes using only polar coordinates with metric.
Now in the case of O-S collapse, the hole you are proposing 'must' be accepted as the correct prediction of GR is rather strange. A clock in the middle of collapsing dust ball stops for no reason. It stops in a strange sense - locally everything proceeds at a normal rate until it is declared to stop.
Note that for Krauss, et. all, assuming their quantum simulation is correct, they have good physical justification for this - this central clock is not acatually stopping; it evaporates in finite local time. Then it makes sense to talk about chopping a classical model at similar point.
If, instead, you accept the the interior clock proceeds normally, there is no escaping (using any coordinates), that the clock is proceeding for some time after an event horizon has formed around it. Any signals it sends will not escape, but it can readily receive signals from an external observer.
No, this is not correct. The correct statement is: SC type time slicing cannot *cover* the EH and interior region.
This is not correct either. SC type time slicing cannot cover the EH and interior region for *any* black hole spacetime; it only covers the exterior. But in both cases you cite (collapsing mass and eternal BH), the EH and interior region are part of the spacetime; they are just not covered by the SC type time slicing.
Who says? It is no different than saying: I have two problems in analytic plane geometry. One is easier to compute in cartesian coordinates, one in polar coordinates. So I do one calculation one way, the other a different way.
This is just false. For an O-S collapse, there is always an interior because it is a collapsing ball of dust. If you restrict yourself to what a distant observer sees, what they see is a ball that freezes throughout, at a radius just larger than the SC radius.
Outside the frozen ball, you can apply SC coordinates and metric (or others). Inside (where matter is), you must do something else.
Now, SC time slicing is a specific choice of simultaneity (of which there are infinite choices, including simple, physically defined ones: https://www.physicsforums.com/showpost.php?p=4165220&postcount=23 ). If I pick a different choice, and use it throughout, then the external observer assigns well defined time coordinates to the dust ball collapsing inside the horizon, and even a well defined time to the formation of a singularity.
I don't think this can happen, because any valid coordinate system in GR has to preserve geometric invariants, and all of the physical predictions of GR depend only on geometric invariants. So any valid coordinate system in GR must lead to the same physical predictions as any other valid coordinate system.
Please do; I don't understand what you're referring to here. See my comments above about what a "valid" coordinate system is. Any valid map of the Earth would also have to preserve geometric invariants; that is, you would have to be able to calculate, say, the correct great-circle distance between New York and Sydney using any valid map (though the calculation might be easier in some maps than in others). Note that this is *not* the same as how the distance "looks" on the map: the NY-Sydney great circle looks very different on a Mercator projection than it does on a stereographic projection, but both allow you to calculate that the physical distance is the same; it's just represented differently in terms of the coordinates.
I'm not aware of any requirement that everything mathematically possible according to any theory must exist. The maximally extended Schwarzschild spacetime, including a white hole and a second exterior region, is mathematically possible in GR, but nobody, AFAIK, thinks it's physically possible.
Hmm, I meant it differently. You can't use different conventions within single calculation/reasoning. Because there can be convention dependent statements.
With "inside" I mean "inside EH" not "inside gravitating mass".
And you can apply SC type time slicing inside collapsing mass. With SC type time slicing I mean equal time for forward and backward trip of light signal (after factoring out dynamics of collapse) just like it is for outside coordinates.
OK, if you assume a transparent pressure less dust, and do this radially from infinity, you get this SC time slicing outside and something similar inside. The whole point of this thread is that neither SR nor GR say this is the only allowed way to slice spacetime. And it is provable that you have hole in spacetime (world lines of particles that just end for no reason, at finite proper time along them), or a region not covered by these coordinates.
The point of this thread, is that you can choose many other intuitive simultaneity conventions for a distant observe (and simultaneity convention identically equals time sicing), which don't have a hole, and assign finite time coordinates to events inside the EH, which itself labeled with a finite time coordinate.
You can do this, as PAllen said, but it's important to note that if you do, this time slicing still won't cover the horizon or the region of spacetime inside it. That includes the portion of the collapsing matter that is inside the horizon.
I've got several comments:
On the map issue. There ARE coordinates that are mildly "special" at any given point. These coordinates are the ones where your map is drawn to scale. The mathematical feature of such maps is that the metric is diag(-c, 1, 1, 1).
Because these maps are to scale, one can freely interchange coordinate distances (i.e. changes in coordinate) with physical distances. They're easy to work with. Discussions don't go off in as many strange tangents when you use maps that are to scale, and people don't get "lost" so much, I find.
Some recent discussion reads to me something like this:
"Your'e reading the map wrong - here , use this one, It's almost to scale - well, not really to scale, actually, but the distortions are at least finiite."
"No - I like the one that's infinitely distorted better, because - nevermind why, I just like it better."
People for some reason seem to have a really hard time dealing with distances in GR but if done correctly it's not that complex - just make sure your map is to scale (and if its not, learn enough math to covert your maps so they are to scale, this can reasonably be motivated with as little math as algebra).
The only remaining issue with maps is the SR issue. This is understanding that time is not absolute, that simultaneity is relative, that as you change your notion of simultaneity your notion of distance also changes correspondingly because space-time is a continuum, and space and time are fundamentally linked.
Mathematically: the maps of SR and GR preserve the Lorentz interval.
This is where I keep feeling the communication is lacking - but many people who say they "get" this point obviously don't :-(.
The notion of "now" is relative. The local notion of now is determined by backwards compatibility with Newton's laws, but said notion of now (necessary for this backwards compatibility) is purely local, and not universal. This relativity means that this, or any other , notion of "now" is not used to determine cause and effect, but rather one uses light cones. To put it succinctly, "now" is relative, light cones are absolute.
The last issue. I think there are some people who believe in "white holes", but not in the context of classical GR. See the thread on Nikodem Poplawski I started
- if one is talking about the same sphere using different maps, and one map doesn't cover all of the sphere, you use other maps to cover the rest, such that you are always describing the same complete sphere.[..]
No, I meant nothing like that. Instead my illustration is about different mapping systems, which are related by conformal transformations. It's a very simple example that I thought of when I awoke one morning at the time that we were discussing Hamilton's model, which as we all agreed, in the way he literally pictures it isn't exactly GR. My example is a bit silly, please don't laugh - but you may smile. :cool:
There is a flatland country near the equator, and sailors are setting out on voyages to distant destinations. Now comes a cartographer, who decides to make a map that can serve as a travel guide. Based on intuition (inspiration?) he then develops a map of the world with the strange property that it has medians that converge when going away from the equator towards the North. As a result everything ends in a singularity, which he gives the name North Pole. Thus it appears that one cannot get further away than the North pole, which is intellectually unsatisfactory.
Then comes along a different cartographer who thinks up a conformal transformation that results in a very similar map, but now with the medians running parallel. The funny thing of that map is that the singularity is gone; on that map people can continue beyond the North pole. Of course, the two maps can be transformed from one into the other without problems up to that singularity, but predictions definitely differ from that point onward.
Now they have a problem; at best one of the two will match reality. Either Flatlander Earth physics law can tell them which one to choose as the most correct one, or Earth science is incomplete, so that the flatlanders don't know yet which mapping would best, even just in theory.
I agree with you about valid coordinate systems. However, it appears that the disagreements in the physics community that I noticed relate to the issue of what is valid. If so, then this is a "hot potato". :devil:
Note: regretfully I can merely choose like a voter about a political issue: Yes, I do have an opinion, and No, I probably don't have enough GR expertise to make a case. So, please regard me as a science reporter who meddles in expert discussions and asks annoying questions. :wink:
[..] I'm not aware of any requirement that everything mathematically possible according to any theory must exist. The maximally extended Schwarzschild spacetime, including a white hole and a second exterior region, is mathematically possible in GR, but nobody, AFAIK, thinks it's physically possible.
Yes, that is what I think too. I got the impression that PAllen was heading for the contrary opinion, although within certain limits.
Not at all. I believe (physically intuit?) that tachyons are not likely to exist in our universe; nor white holes; nor closed time like curves; nor super-extremal kerr black holes; nor alcubierre drive; nor actual singularities. I also admit that all of these have mathematically consistent treatment.
But in each of these cases, I see a clear reason to 'draw a line'. Tachyons have to be added to SR in violation of the causal interpretation of SR. White holes have no process by which they can form. Similarly, for most of the others, there is no known process they can form out of plausible initial conditions. Singularities I interpret as a clear sign that GR has broken in this domain.
With black holes, treated classically, we have, instead, the singularity theorems: With almost any reasonable starting point, once collapse has gotten close to a critical radius, it must proceed all the way to a singularity. Further, all the approaches, classically, to try to avoid an event horizon formation amount to my example chopping the poles off a sphere because I don't like what they do to my coordinate preference.
I honestly haven't seen this in what I've seen of the reputable physics community (which is not a lot as I am not an academic). There is certainly a lot of disagreement, but it doesn't look to me like disagreement about which coordinate systems are valid. It looks to me like disagreement on which physical principles should be retained, and which discarded, when they conflict.
For example, the black hole information loss problem basically comes down to: which do you want to keep when push comes to shove, general relativity or quantum mechanics? GR predicts that gravitational collapse leads to the formation of regions of spacetime from which information can't get back out; that means a quantum state that falls in gets lost, so unitarity, a central principle of QM, is violated. Hawking's position (at least until about 2004-ish; he seems to have switched sides in what Susskind calls the "Black Hole War" about then) was, so much the worse for QM. Susskind's and t'Hooft's position (there were others, but they seem to have been the primary ones who held to this position throughout) was, so much the worse for GR. They can't both be right. But nobody, as far as I can see, was arguing one way or the other based on which coordinates were valid and which weren't.
Fair enough. :smile: You ask better questions than a lot of science reporters do.
  • #31
There is no hole in spacetime with SC type time slicing for collapsing mass. EH forms at infinite future i.e. never. So there is no hole in spacetime.
And wordlines of particles do not end. They just extend toward infinite future.
You would not claim that there is some problem with this expression, right?
[tex]\lim_{t\to\infty}f(t)=a[/tex]
Let's say that t is coordinate time and f(t) is proper time of infalling particle.
You can choose different simultaneity conventions but then we need good understanding of the things that depend on simultaneity convention as they would change along with it.
And I think that in order to improve that understanding it would be good idea to start with some examples from flat spacetime.
  • #32
I thought it would be useful to do something Peter Donis suggested in another thread. That is, to look classically at the complete geometry of a collapsing shell of matter, which is like the Krauss case. I found a couple of references, and have done some order of magnitude calculations based on the arxiv paper (adjusted for a matter shell rather than a null dust shell).
The follwoing gives a Kruskal diagram (and other coordinates) for a collapsing shell. This one is pressure-less, and only the final stages (where the matter is almost light like) is shown (the r=0 line and the shell line need to slanted closer to vertical to consider a collapse from rest not too far from the SC radius):
http://casa.colorado.edu/~ajsh/collapse.html
This paper discusses collapse of a null dust shell, including Kruskal coordinates (section 4):
http://arxiv.org/abs/gr-qc/0502040
While this is not quite the case of interest, the techniques shown for matching interior and exterior are general.
I think the interesting case to consider is a clock sitting inertially at the center of a collapsing shell, under the further assumption that the shell is transparent. There are a number of interesting features:
- The spacetime inside the shell is pure Minkowski flat spacetime; there are no tidal forces at all. There is no matter density at all. In the whole region inside the shell, SR physics applies. The analog of this is obviously true for Newtonian physics; it is also well known that this is exactly true for GR as well (that inside a spherical shell, physics is indistinguishable from SR with no gravity).
- The clock inside operates according to SR physics, time locally flowing normally, until shell collapse reaches singularity. The clock at the center cannot detect the shell passing the event horizon. Nothing about physics within the shell changes on approach to or passing the event horizion - the interior is pure SR until the singularity.
- The clock at the center sees the external 'universe' proceeding normally except highly (but finitely) blue shifted until the moment of singularity. Here, the clock world line ends for a very physical reason: the shell has collapsed to a singularity, bringing the clock with it. One of the things I wanted to get right here was the blueshift relation. Unlike an O-S collapse, where an infaller (with right trajectory) can have very mild or even no blue shift relative to the outside universe, the boundary matching conditions for a shell collapse require that the whole interior (for observers stationary with respect to shell center) experiences (in the limit of zero thickness shell) the same blueshift as a clock riding exactly on the shell.
- A distant observer, of course, never sees the shell reach the event horizon. Similarly, they see the inside clock stop at a time before the clock hits the singularity.
- Later free fall clocks will be seen, from a distance, to stop on reaching the event horizon. Such a clock, itself, will experience no such thing, and its time will progress further until it hits the singularity (the shell is 'long gone' into the singularity).
Classically, one may ask by what possible rationale should one declare that a clock operating according to pure SR physics, be declared to stop for no local physical reason? What does what a distant observer sees have anything to do with their local, pure SR physics?
All of the above is indisputable for classical GR. The Krauss paper, by choice, only covered what the outside observer sees, for the classical case, because of what they discovered about the quantum case. The quantum analysis (if true) showed that, a lot of the above does not happen in our universe. It shows, instead, that (no matter what coordinates are used), the interior clock actually evaporates into not quite thermal radiation well before its classical end. The Kruskal diagram changes in significant ways as a result. Only with this justification, does it make any sense to 'chop' the classical analysis based on Schwarzschild time coordinate.
Note, that in the classical analysis without the quantum chop, perfectly reasonable, physically based simultaneity conventions, establish simultaneity between the interior clock and exterior clocks well after the shell has crossed the event horizon. One simple example is:
  • #33
You think that this is a logical proof, but it isn't. What you have actually proven is only that there is no hole in the region of spacetime covered by the SC type time slicing. You have *not* proven that that region of spacetime is the entire spacetime, and in fact it's easy to prove that it's not. See below.
No, they don't, at least not the way you mean. When you have extended an infalling worldline all the way to t = infinity by your clock, that worldline still only has a *finite* length. "Length" for worldlines means proper time, and the proper time for an object to fall to the horizon is finite.
This isn't quite the right expression. The right expression is:
[tex]\lim_{t\to\infty} \int_{t_0}^t dt' f(t')[/tex]
where [itex]t_0[/itex] is the time by the distant observer's clock that the infalling object starts falling. Substitute the correct function f(t'), for the proper time of the infalling object, do the integral, and take the limit. You will find that it gives a finite answer. This shows that "extending the worldline to infinity" by the distant observer's clock only extends it by a finite length. The SC time coordinate is so distorted at the horizon that it makes finite lengths look like infinite lengths.
This also shows why the region of spacetime covered by the SC time slicing can't be the entire spacetime: what happens to the worldlines once they reach the horizon? They have only covered a finite length, and spacetime is perfectly smooth and well-behaved at the horizon: the curvature is finite, there is nothing there that would stop the objects from going further. The only physically reasonable conclusion is that they *do* go further; that is, that there is a region of spacetime on the other side of the horizon, where the infalling objects go, but which can't be covered by the SC time slicing.
This is a good idea; do you have any suggestions? I would suggest comparing the description of flat spacetime in Rindler coordinates to its description in Minkowski coordinates.
  • #34
This is false. You detect readily in SC coorinates that there is a hole in space time. You integrate proper time along an infall trajectory and find that proper time stops at a finite value (unlike for various other world lines). You ask, what stops the clock? There is no local physics to stop the clock - tidal gravity may be very small; curvature tensor components are finite. The infinite coordinate time is not a physical quantity in GR. Einstein spoke of rulers and clocks, as Harrylin likes to point out. This clock stops for no conceivable local reason. If you add SC interior coordinates, and use limiting calculations, you smoothly extend this world line to the real singularity (with infinite curvature). All of this is exactly as if you chopped a disk around the pole from a sphere - you would find geodesics ending for no reason.
There is no physical observable, anywhere in SR or GR, that depends on simultaneity convention at all. This is part of what Pervect was saying above. Belief that simultaneity convention has physical consequence reflects complete, total, misunderstanding of SR and GR.
As for flat spacetime, the Rindler example Dr. Greg has posted beautiful pictures of, is relevant. The belief that there is no hole in SC exterior coordinates is 100% equivalent to the belief that most of the universe doesn't exist because a uniformly accelerating rocket can't see it.
  • #35
I would like get this point better and as I understand you are confident about your understanding of that point.
Transformations between inertial SR coordinates preserve Lorentz interval. And they don't change metric just as well.
But in GR transformations between coordinates don't have to preserve metric intact. That's how Lorentz interval is left the same, right?
