GHZ Experiment: Detections vs. Hidden Variables
In summary: However, the lack of definitive results does not necessarily mean that the theories are false. There are a number of possible explanations for the lack of definitive results, including the possibility that the theories are true, that the experiments have been flawed, or that the theories are not applicable to the specific phenomena being studied. In summary, the evidence suggests that hidden variables theories may be possible, but more research is needed to confirm or disprove them.
trosten
47
Have anyone done the GHZ experiment? As I understand it from a book I read QM predicts detections that hidden variables theories can't produce at all! If theese detections has been done then all hidden variables should be out of question even if the Bell experiments haven't been flawless!?
Yes, there had been at least one experimental test:
Jian-Wel Pan, Dik Boumeester, Matthew Daniell, Harald Weinfurter and Anton Zeilinger, "Experimental test of quantum nonlocality in three-photon Greenberger-Horne-Zeilinger entanglement", Nature 403, 515-518 (2000).
This did support QM, but I think there must be something terribly wrong with the supposed "local realist" theory that they assume. I mean to look into it. It would help if I could get hold of something nearer to the raw data and not just the published "normalised" results. Detection rates were very low, so a variation of the standard "detection loophole" would have applied, but the published results show such severe contrast to the supposed local realist predictions that I think there must be more to it than this. Perhaps the LR prediction is one that applies to the geometrically symmetrical case covered in:
Daniel M. Greenberger, Michael A. Horne, Abner Shimony, Anton Zeilinger, Bell's theorem without inequalities, Am. J. Phys. 58 (12), 1131 (1990)​
The actual experiment may have had completely different symmetry properties. As I said, though, I intend to look into it. The theory is horrendous (much worse than that for the Bell inequalities) so I shall have to build up my courage to tackle it!
Caroline
http://freespace.virgin.net/ch.thompson1/
keep it up! :smile:
Y'all make it sound as if it's a foregone conclusion that the experiment will be consistent with LR. :tongue2:
I don't believe that, I believe QM will prove to be complete. But I think caroline has got a point that a lot of the experiments to disprove LR with bells theorem have been flaved.
I spoke to a teacher at my school and he said that recently other researches have shown that there haven't been any experiment that have dissproven LR so far since all experiments have contained missed photons etc. All though the research show that its highly unlikely that LR is correct, it still isn't proven it isnt.
Re ordinary Bell tests, I think that some day a sufficiently careful experiment will show that the QM predictions can give wrong numerical predictions.
Re the GHZ test, though, something seems to have gone wildly wrong. There is a fairly thorough coverage of the history of the test in Amir D Aczel, “Entanglement: The greatest mystery in physics”, Four Walls Eight Windows, New York, 2001. Though Aczel, despite many one-to-one discussions with some of the people involved, seems to have come away with a totally false impression of the validity of the Bell test experiments, he is the best source I know for the history from Bell's paper to about 1998. Apparently the GHZ test was discussed at conferences and privately then given publicity by Mermin before the official paper had been published. Something odd was going on here ...
Caroline
Caroline
"Violations of Local Realism in the Innsbruck GHZ experiment"
http://arxiv.org/PS_cache/quant-ph/pdf/9811/9811013.pdf
Not really straightforward conclusive... Some of the quotes:
Quote 1)
"Some observed events do not follow
the usual pattern of the GHZ correlations. The aim of
this paper is to show, following the ideas of ref [4], that
those ‘wrong’ events are irrelevant in the derivation of
a GHZ-type contradiction for the quantum predictions"
Quote 2)
"It will be shown that in any local realistic theory those
wrong events must happen (or not) irrespective of what
observables are chosen to be measured by the remote
observers at the three spatially separated stations"
Quote 3)
"Thus, the GHZ argumentation
can be confined to only the “right” events."
Regards, Hans
My understanding of the GHZ experiment is that it does not rule out situations where the underlying hidden variable is different between distinct outcomes.
This seems a rather weak interpretation of how a local realistic hidden variable might work i.e that the hidden variable is tied to some immediate property of the object under measurement as opposed to something more holistic.
Bohm's work on hidden variables although not dealing with GHZ explicitly (as far as i know) points n this direction
What is the GHZ Experiment?
The GHZ Experiment, also known as the Greenberger-Horne-Zeilinger Experiment, is a thought experiment in quantum mechanics that was proposed by Daniel Greenberger, Michael Horne, and Anton Zeilinger in 1989. It explores the concept of entanglement and the implications for the existence of hidden variables in quantum theory.
What is the purpose of the GHZ Experiment?
The purpose of the GHZ Experiment is to test the validity of the quantum theory and the existence of hidden variables. It aims to determine whether entangled particles are truly connected in a non-local way or if there are hidden variables that can explain their behavior.
How does the GHZ Experiment work?
The GHZ Experiment involves three entangled particles, each with two possible states (either spin up or spin down). The particles are separated and measured simultaneously, and the results are compared. If the particles are truly entangled, their measurements should be perfectly correlated, regardless of the distance between them.
What are the potential outcomes of the GHZ Experiment?
If the results of the GHZ Experiment are perfectly correlated, it would support the existence of non-local connections between entangled particles and disprove the possibility of hidden variables. However, if the results are not correlated, it would suggest that there are hidden variables at play.
What are the implications of the GHZ Experiment for our understanding of quantum mechanics?
The GHZ Experiment has significant implications for our understanding of quantum mechanics. If the results are perfectly correlated, it would confirm the non-local nature of entangled particles and challenge our traditional understanding of causality and reality. On the other hand, if the results are not correlated, it would suggest that there are hidden variables at play, which could potentially lead to new theories and explanations for quantum behavior.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
