Potential Energy and Kinetic Energy Problem
In summary,Brandon has a net vertical velocity of 0.0985m/s and Tom has a net vertical velocity of 0.141m/s as they ascend and descend the mountain. Their average kinetic energy going up and down the mountain is .441 and .905 respectively.
jayced
Brandon and Tom are climbing a mountain. He starts from an elevation of H1=511m above sea level. In 6.18 hours he climbs to an elevation of H2=2746m above sea level. The length of his path is L1=16000m.
Brandon has a mass M1= 91.1kg and Tom has a mass M2=11.2kg
Vertical velocity up the mountain=0.0985m/s
Horizontal velocity down the mountain=0.141 m/s
A)Calculate the change in gravitational potential energy for Brandon and for Tom as they make their climb in the Rockies.
Delta GPE for Brandon=
Delta GPE for Tom=
B)Calculate the average kinetic energy for Brandon and for Tom as they climb up the mountain and as they descend.
KE for Brandon going up=
KE Tom going up
KE for Brandon coming down =
KE for Tom coming down=
A)GPE=mgh
B)KE=1/2mv^2
It seems to simple for question A is too simple to be true so I'm concerned about wether it is correct.
M computations:
GPE=mgh
=(91.1kg)(9.8m/s^2)h and (11.2kg)(9.8m/s^2)h
Question:What height should i use for h? Is this the right equation? What is meant by Change in gravitational energy,do I have to subtract them?
For B)
KE=1/2mv^2
KE=1/2(91.1kg)(0.0985 m/s^2)^2
=.441
KE Brandon going down
KE=1/2(91.1kg)(0.141 m/s^2)^2
KE=.905
Whats the units for KE?
Is this correct and if so should I do the same for Tom?
change in gpe = [tex]mgh_2 - mgh_1 = mg(h_2-h_1)[/tex]
so in your equation h refers to the change in height...
For the kinetic energy part, you need the net velocity... you used only the horizontal and vertical component of velocity in your formula.
"Vertical velocity up the mountain=0.0985m/s"
so what is the magnitude of the net velocity? use trig...
Thank you Learn,
I don't understand because my avg velocity going up the mountain was 0.0985m/s. My avg velocity going down the mountain was 0.141m/s. But if I used my net velocity would that make my numbers the same for KE goin up and down for Brandon,becuase the only variable that changes is my mass. I'm really confused. Help clarify things for me please.
jayced said:
Thank you Learn,
This is what the question says:
The average velocity going up the mountain is not 0.0985m/s... the average vertical velocity going up the mountain is 0.0985m/s... Brandon has both vertical and horizontal velocity... what is the horizontal velocity while Brandon is going up the mountain? What is the net velocity going up the mountain (vector sum of horizontal and vertical velocities) ?
We are getting there Learn,
Can I find the horizontal velocity by doing my avg velocity of .705m/s times my time which is 22680s? Is my horizontal velocity equation v x t?
Then in order to find my net velocity I add my horizontal and vertical velocities,Correct?
But what does my net velocity solve for? I really need help with my forumulas because i am getting confused.
My avg velocity is .705m/s if that helps.
How did you get 0.705?
I got 0.705 when i divided the length of their path(16000m)/ the time it took them to get there 22680s,which equals 0.705m/s. That was their average speed in m/s.
jayced, I'm confused by the question itself... is this just the question or does this include stuff you calculated:
"Brandon and Tom are climbing a mountain. He starts from an elevation of H1=511m above sea level. In 6.18 hours he climbs to an elevation of H2=2746m above sea level. The length of his path is L1=16000m.
Horizontal velocity down the mountain=0.141 m/s"
so all of this is part of the question? they gave 0.0985m/s and 0.141m/s in the question?
It was one problem but my teacher refernced it for more questions. For the first part I calculated:
A)What is the average angle of ascent the path makes with the horizontal?Theta=8 degre
sin theta =2235m/16000m the 2235 came from 2746m-511m=2235
sin-1(0.139)=8.03 degrees
B)What is their average speed along the path in meters/second? average speed=.705 m/s
Avg speed=d/t
So I took 16000m/22680s=.705m/s
C)What is their average vertical velocity? Vup=0.0985 m/s
DeltaV/t=Average velocity
2235m/22680s=0.0985 m/s
D)After some food they hike back down to their starting point in T2=4.24 hours
What is their average vertical velocity? Vdown=0.141 m/s
DeltaV/t=avg vertical velocity
2235m/15840s=0.141m/s
This is what I calculated right above. Did I clarify it enough? The only thing that's given was :
ok. so the average velocity up the mountain is 16000/22680 = 0.705m/s. use this for the kinetic energy going up the mountain
How did you get 15840s for the time down the mountain? 4.24*3600 = 15264s
anyway for down the mountain, use 16000/time down the mountain... then use that velocity to get kinetic energy down the mountain.
60mins=1hr 24mins= 24min*60s=1440s
60mins* 4hr=240mins
60s=1min
240min*60s=14400 +1440s= total seconds =15840
60mins* 4hr=240mins
60s=1min
Oh, I see... it's not 4.24 hrs, but 4hrs, 24 minutes... okay, so 16000/15840 = 1.01m/s. use this for the kinetic energy down the mountain...
Wow ,thanx so much learningphysics you helped me plenty and this is the best kept secret. Good luck and know that its greatly appreciated.
:smile: you're welcome.
What is potential energy?
Potential energy is the energy an object has due to its position or state. It is stored energy that has the potential to do work.
What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is directly proportional to the mass of the object and the square of its velocity.
How are potential and kinetic energy related?
Potential energy can be converted into kinetic energy and vice versa. For example, when a roller coaster car is at the top of a hill, it has a lot of potential energy. As it goes down the hill, this potential energy is converted into kinetic energy, causing the car to gain speed.
What is the formula for calculating potential energy?
The formula for potential energy is PE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height of the object.
What is the formula for calculating kinetic energy?
The formula for kinetic energy is KE = 1/2 mv², where m is the mass of the object and v is the velocity of the object.
