An way to visualize dark matters effects on space-time?
In summary, the analogy of a flat rubber sheet is often used to try to explain space-time curvature and gravity, but it is a very bad analogy because it uses gravity to explain gravity.
freerangequark
In an attempt to explain space-time curvature and gravity, the analogy of a flat rubber sheet is often used whereas a massive object, such as a bowling ball indents the sheet in the same way that a massive object such as a star creates curvature in space time.
Would it be a fair analogy then to say that dark matter, with its repulsive qualities can affect the same rubber sheet, however instead of indenting it, it causes a rise on the sheet?
Is that an accurate way to visualize how dark matter affects the curvature of space-time?
Thanks,
FRQ
PS - Please keep the reply in layman's terms if at all possible.
Astronomy news on Phys.org
Dark matter does not act repulsively. Dark matter acts gravitationally exactly like matter i.e. attractively.
What distinguishes dark matter from ordinary matter is that it is electromagnetically invisible - it interacts with neither atoms nor the EM spectrum.
Dark energy acts repulsively.
But it's a very bad analogy, and its a shame that so many popular science treatments of the subject use it.
Would it be a fair analogy then to say that dark matter, with its repulsive qualities can affect the same rubber sheet, however instead of indenting it, it causes a rise on the sheet?.
This shows why its such a bad analogy. The analogy tries to say that it is the intrinsic curvature of the rubber sheet that causes a deflection. But the intrinsic curvature is the same whether the rubber sheet is pushed downwards or upwards. So unless both have the same effect then the analogy is wrong. Of course your intuition tells you that they are different, but that is because you assume that there is a gravitational field external to the rubber sheet. So the analogy is using gravity to explain gravity.
I thought the analogy was saying that mass dictates how spacetime curves, and the resultant curvature tells matter how to move within spacetime. No?
Thanks,
FRQ
Thanks,
FRQ
I did a google search to find out what was it was that was curved that "tells matter how to move". Sometimes it was space, sometimes it was spacetime.
The trouble with the space version is that it doesn't accurately reflect what general relativity is about, which is the curvature of spacetime
But then the trouble with the spacetime version is that things don't move within spacetime as this would imply some sort of time external to spacetime.
Yes, matter has a geodesic path within spacetime, whose curvature is determined by the distribution of the matter. But in the case of the rubber sheet analogy the path would be the same whether the sheet went upwards or downwards - I think it would be deflected inwards in either case, so if the analogy suggests that it would be deflected outwards for a sheet pulled upwards then there's a problem with the analogy. The thing is that a ball bearing rolling on the sheet does not follow a geodesic of the surface.
1. What is the concept of visualizing dark matter's effects on space-time?
The concept of visualizing dark matter's effects on space-time is to use scientific models and simulations to understand how dark matter, which is a hypothetical form of matter that does not interact with light, affects the fabric of space-time. This can help scientists better understand the behavior of dark matter and its role in shaping the universe.
2. How does dark matter affect the fabric of space-time?
Dark matter is thought to make up about 85% of the total matter in the universe, and its gravitational pull affects the movement of galaxies and other objects in space. This, in turn, affects the curvature of space-time, which is the fabric of the universe. By visualizing these effects, scientists can gain a better understanding of how dark matter interacts with space-time.
3. What tools and techniques are used to visualize dark matter's effects on space-time?
Scientists use a variety of tools and techniques to visualize dark matter's effects on space-time. These include computer simulations, gravitational lensing, and observations of the cosmic microwave background radiation. Each of these methods allows scientists to indirectly observe and measure the effects of dark matter on space-time.
4. How does visualizing dark matter's effects on space-time help us understand the universe?
Studying dark matter's effects on space-time can help scientists better understand the structure and evolution of the universe. It can also provide insights into the nature of dark matter itself, which is still largely a mystery. By visualizing these effects, scientists can test and refine theories about the universe and gain a deeper understanding of its origins and composition.
5. Are there any limitations to visualizing dark matter's effects on space-time?
There are some limitations to visualizing dark matter's effects on space-time. Since dark matter does not interact with light, it is impossible to directly observe it. This means that scientists must rely on indirect methods, which may not always provide a complete understanding of its effects. Additionally, our current technology and understanding of dark matter may also limit the accuracy of these visualizations.
  • Astronomy and Astrophysics
