Is there direct evidence photons attract gravitationally?
In summary, there is no direct evidence that photons attract one another gravitationally. While GR predicts that photons should have a gravitational charge, it is not necessary for them to have an inertial mass to act as a charge analogous to electric charge in E&M. However, there is evidence that photons experience gravitational pull from massive objects and their gravitational self-interaction is an important component of the Big Bang theory. While there is no direct evidence that marbles attract gravitationally, conservation of momentum supports this idea. The unique nature of gravity, which affects all known particles and energies, makes it uncertain if anything is immune from its effects. The exception for gravity itself in Einstein's theory raises questions about the conservation of gravity as a quantity in the
  • #36
im with you on this. it is one of the issues that seem pretty gnarly once we allow photons generate gravitational fields. so in a certain sense it is a bit of a paradox. but from the external inertial frame observer outside the field, momentum must have been transferred to the gravitating body by the photon.
Science news on Phys.org
  • #37
Maybe it should be a strong clue the equations for GR are called the Einstein Field Equations.
I had always thought that the use of field was derivative of the curvature of spacetime but maybe the field is the fundamental concept and the curvature of spacetime is just a convenient mathematical tool.
Any GR specialists care to clarify?
  • #38
inflector said:
Is the issue here that momentum is conserved in a frame-dependent way? Just like energy is conserved in a frame-dependent way? i.e. that from the photons frame it is just going straight so there is no change in momentum but from the perspective of an observer the photon curves and therefore there is a need for an offset to the change in the photon's momentum vector?
Momentum is not conserved when you have curved spacetime. So, to understand anything you have to use full GR. The conservation is a consequence of isotropy, so it only holds in the limit of flat Minkowski spacetime.
  • #39
Very interesting, My "amateur" understanding, is that gravitation is the attraction between mass, for something to be effected by gravitation it has to be in the presense of a mass. Yes, that mass changes the shape of the space around it, so a 'straight line' is not straight, but curved or warped.
Photons, light, travel at the speed of light, therefore cannot have mass, otherwise they would require infinite energy to 'accellerate" the photon to the speed of a photon.
Which to my untrained mind makes no sense.
From the photons perspective, there is no time, and no distance. To me, I see a photon (from the photon) as the instant it comes into existence it recombines with mass and ceases to be a photon.
Photons also travel at the 'speed of gravity' or gravity travels at the speed of light, so I can't see how there can be interaction between photons and gravity. except from a external frame of reference, and what you then observe is the change of shape of space (due to gravity) and the photons traveling in that changes space in straight lines.
If the level of energy in a photon had an effect on the gravitational attraction, then would you not see different images of distant objects when looking at different light spectrums. Due to the lower 'bending' or gravition effect on the higher energy photons?
Would you get less, or can you detect less or more gravitational lensing if you observe the magnified object at RF frequencies, light, and x-Ray/Gamma ray energies?
That would confirm that higher energy photons are bent less by a large mass that lower energy photons.. But I do not think this has been observed ?
We are so lucky to live in such an interesting Universe, with lots of interesting things to find out about..
  • #40
Darryl mass ,energy or pressure bends space-time .
  • #41
I don't know, I would be interested to know what energy that does not have mass would effect gravity (therefore bend space).
The only energy I can think of that is not massive is electromagnetic, and the point of this question is an energetic particle like a photon affected by mass ?
Or does it travel in a straight line, along curved space.
and Pressure, I would have to consider pressure to be mass, (something compressed), or if its massless, its an electromagnetic or electric or magnetic field pressure.
Or gravitation pressure (in intensity), we allready know gravity effects gravity, but does gravity affect massless particles that travel at c, that experience zero time (they travel at c).
We know gravity warps space, so a gravity pressure would be a specific bening of its local space, so gravity indirectly changes the path of the photon, to an outside observer. But the photon itself would see no (to me) experience no interaction with the gravity directly, its just traveling in what is for it a straight line.
If gravity travels at the speed of light, and mass curves space with gravity, and a photon can only travel at one set speed, then for it to maintain that set fixed speed, it has to travel along the curve of space/time to maintain a constant c. ! mabey :)
Q.
Gravitational lensings ? I am trying to visulise the shape of the space/time bending around a super massive object, with a light source behind it, (gravitational lens), and trying to work out if the lens would be concave or convex, if the mass changes space time the most in the center of the mass and less on the outside, so the gravity and space/time bending would be too strong for photons to 'pass through the lens' (a black hole), but going further out away from the centre of mass would be a point where the rate of space bending would allow photons to take a 'short cut' through a point in space where a straigh line is a curve so for a photon to stay at a constant speed, it has to change paths, to stay in space/time..
space, and length to me is not constant, it depends on where you are, and how fast your going !.
If you were on the surface of a black hole, with a tape measure and measured out 1 meter, it would be the same 1 meter as you can measure out on earth, but if you could take both of those lengths to a third location, (with its own space/time) the two lengths would be very different.
But when you are on the black hole or on the Earth you would see no difference in length.
So it would appear to me that mass has gravity, and gravity changes the shape and size of space, light speed is constant and to remain constant it has to travel a straight line through space that is varying in shape.
  • #42
njinear said:
einstein says energy carries gravity, but he makes the exception for gravity itself, that the tensor has an entry of zero for gravity's gravity. since gravity does not have gravity itself and it can carry energy away (seems pretty well proven by binary star decay) then the gravity in the universe is not a conserved quantity, with significant cosmological implications since energy is more often emitted than absorbed.
Would it be ridiculous to say that gravity tends to consume energy, by converting PE into KE and ultimately regurgitates it as EM radiation? I don't think this process fails to conserve mass/energy and although I've never heard of conservation of force, I think it may do that too. After all, EM radiation is really just magnetic/electric fields being transmitted at C, right? So why wouldn't the gravitational force of all the fuel consumed by a star not be conserved in the total EM radiation generated in the process?
the fact that photons are deflected by gravity doesn't mean they generate gravity. the deflection is due to the shape of spacetime, the photons are following the geodesic. we would expect gravity waves to do the same thing, because if for no other reason, there is no straight line EXCEPT the geodesic.
there is no straight line except the geodesic, and the relative straightness of those seems to be due to relations between relative mass, momentum, inertia, and gravity. I am curious if physics will eventually explain spacetime as a product of energy, where mass emerges from energy and is attributable to it along with inertia. I could see how the emergence of inertia from energy could be responsible for the relative straightening/flattening of spacetime that allows energy to move linearly at all, but I don't know whether BBT already addresses this or whether some other physics may go in this direction or already is.
further, if a photon for example has gravity, it seems like a bit of a problem getting "gravitons" in some quantum version of gravity to be "entrained" by the photons.
Could the relationship between gravitons and photons be analogous to that between photons and electrons? By this I mean that the gravitons emitted by low-intensity EM waves could be negligible but as EM waves intensify to the point of matter-forming capacity, they would emit more gravitons. This is of course assuming that some level of EM waves can somehow "congeal" into particles with inertia - but how else could matter (have) form(ed) considering that BBT seems to be convinced that energy preceded matter in the universe?
Intuitively, I think it will turn out that gravity and EM force exist as a single hybrid force at levels of energy-density of a black hole or greater. If so, my question would be why that force differentiates into matter/inertia/gravity and EMism with the emergence of spacetime. Sorry if this post sounds speculative, but I find these questions directly implicated by BBT as far as I understand it so far.
  • #43
I'm afraid so.
I'm afraid not.
This is overly speculative.
  • #44
Vanadium 50 said:
I'm afraid so.
Do you even understand what I meant?
I'm afraid not.
Well, if it was it could explain a potential mechanism for why/how photons would radiate linearly in higher gravity fields and coagulate under their own gravitation in the absence of stronger gravity. Likewise, there is a relationship between gravity and pressure that generates photons with increasing frequency and a similar relationship could exists between photons and gravity where increasing inertia results in more concentrated gravity-emissions. The question would be under what conditions does/would radiation "congeal" to the point of exhibiting inertia. Is your only basis for refusing to consider this the fact that you understand photons as fundamentally massless and you recognize no possible connection between EM energy and matter-formation?
Let me ask you a question, then. What possible behavior could EM radiation exhibit in a BH-level gravitational field where it cannot escape gravity? If it can't move linearly, what would light do? Wouldn't it have to propagate intensively instead of extensively? Similarly, without being able to move, how would electrons generate magnetism? So if electromagnetism was prevented due to stasis of the particles involved, how would that force be able to be expressed except as gravitation?
  • #45
"What possible behavior could EM radiation exhibit in a BH-level gravitational field where it cannot escape gravity?"
For the photon, it has no concept of time, or distance, the photon will in a BH grav field, travel at the speed of light, in a straight space/time line.
If for you as an 'observer' see that space/time you are seeing it from your space/time/gravity.
The photons don't slow down, they can't by definition slow down, they travel at the speed of photons, or the speed of light, regardless of where they are.
Distance, is an amount of traveled in a specific time period, at a specific speed.
So distance is a relationship between time and speed.
To calculate the arrival time of an object, you use its speed and the distance in that calculation, if you travel at a certain speed for a certain time, you can calculate the distance.
But if you travel at that speed for a longer or shorter time, the distance will vary.
Time slows down by gravity, because gravity changes the shape of space/time,
So as your local time gets slower, (with higher gravity), the distance you can travel is less if you are traveling at a fixed speed.
So to vary your distance you can vary your speed, (if you can) or you can vary the rate that time "ticks".
Thats what happens with light in a black hole, that light is still traveling at the speed of light the but equation for its speed uses a value for time that is much much slower than is experienced say on Earth.
So if time is going REALLY slow, evening traveling at the speed of light gets you no where.
the higher the gravity the slower time goes, on a black hole time is going so slow, that from an external frame of reference "from outside" its looks black, and light can't escape.
But for the photons in a BH, I would say they travel in a straight line they do not experience or even 'feel' gravity, and they are as far as they are concerned traveling in a straight line, and the speed of light..
IF there is matter in the path of the photon, it will be absorbed by that matter, so its the space/time line curves into the surface of the BH you would expect that photons would (from the outside) travel backwards, when in fact due to the ultra slow time, would make the direction of the photon when emmitted to be in the direction of the mass, because that is the straight line space time path for that photon that HAS to travel at a constant speed, regardless of how fast time goes.
At a point away from the BH will be a point of space/time where time is going fast enough for the photon to make forward progress (from external frame of reference).
Then as gravity continues to decrease, its local rate of time will continue to increase, so the distance traveled by the photon in unit time is high enough for light to be seen from the outside.
Its not the photon speeding up, its time speeding up, the photon travels at one speed and one speed only, if it does not travel at that speed it ceases to be a photon. Which is what happens when a photon strikes an object.
For the photon there is NO time, therefore NO distance,
If a photon has no time and no distance, there is nothing for it to react too,
So if you had a two photon universe, no gravity or matter, and those two photons just happened to be coherent or sitting next to each other.
Neither of the photons experiece time, and they travel at a constant speed, I am sure from an outside observer in an infinite length of time, the two photons would be in the exact same relative position as when they started.
So the photon that you see in your telescope after traveling in space for 13 billion years, as created at the instant it was detected in your telescope !. If your the photon that is.
So a photon, at the speed of light experiences zero time, so the instant its created its destroyed, but that 'instant' can be an infinite time ! I think..
So it to me has to do with photons having to travel at one fixed speed, and the knowledge that gravity changes time.
And if you change speed or the rate of time (or time itself) then distance will change.
With light you can't change speed, but you can change local time, so if you slow time up enough no matter what speed you travel you won't get anywhere, if time stands still, as you can't have infinite speed, but a fixed speed that is why you have places where time is so slow that light can't get anywhere, its not until further out where time is running faster where light can go enough distance to propagate outwards.
So if your traveling at 300,000Km/s but a second for you is a million years for me on earth, then for me, you are only traveled 300,00Kms in 1 million years.
But for you it was only a second gone by on your watch.
So really its all about time and a fixed speed, if something has a fixed speed but travels through space where the rate of time varies that will cause that photon to appear to travel in a curve, and appear to be gravitationally attacked to mass, but its not, its just changing course to stay at a constant speed in varying time.
So a gravition lens is really a gravity induced time lens.
  • #46
javierR said:
No.But there's evidence that light and massive objects gravitate (light if deflected by stars e.g.). If photons weren't "charged", how would this occur? Because the gravitational interaction is not part of QED. QED is the interaction of photons
and particles that interact via photon exchange.
note that because we have not been able to discern any experimental difference between inertial mass, passive gravitational mass (affects magnitude of force felt in a gravitational field), and active gravitational mass (affects magnitude of force EXERTED on other masses), it doesn't mean that there are no situations (like photons) in which they can be different.
that being said, it is pretty well accepted that all three of these things are equivalent for all phenomena.
to answer OP, no we have not experimentally observed gravitational interactions between 2 photons.
  • #47
The "correspondence principle" of acceleration being the same as gravity. Given that idea as a starting point, look at a beam of light crossing the elevator -- it seems to drop. This strange prediction was found to be true.
  • #48
If I am in a black hole and i shine a laser out towards the event horizon, Would the photon get red shifted to zero. Assuming it got shot straight out and didn't get bent.
  • #49
cragar said:
Look at this thread and this article titled on the gravitational field of light.
http://authors.library.caltech.edu/1544/1/TOLpr31a.pdf
https://www.physicsforums.com/showthread.php?t=174805
And it also depends on if they are parallel or anti-parallel if they will be attracted .
The paper is not theoretical proof that photons attract gravitationally. This is because the authors begin with the assumption that a photon (i.e. a "pencil" or beam of photons) has a gravitational field. So to say that photons attract one another from this article is circular reasoning.
  • #50
I've read through all the replies in this thread and I don't think there is a clear answer yet. It might be more relevant in the GR forum but I don't want to start a duplicate thread.
A long time ago in a forum far, far away, I read that while light and matter interact, two photons do not interact gravitationally according to GR. The graphic some way down this article seems to back that up though the text doesn't mention it:
http://plus.maths.org/content/os/issue29/features/kalmus/index
However, if two "boxes of photons" were placed some distance apart in deep space, I would expect them to accelerate towards each other in the same way as any other masses. The form of the energy in the box should be irrelevant.
So if two photons pass on perpendicular paths (say in the x and y directions respectively) and at the crossing point of the paths, they are separated by a small amount in the z direction, would GR predict that their paths would be deflected or not?
Would that for example be expected to cause some blurring of quasar images due to interaction with the photons of the CMB?
  • #51
Has anyone considered that photons may not "exist" until observation? IE the EM wave travels outwards from it's source as a normal wave, with the photons only appearing when the wave interacts with matter. In such a case I wonder how gravitation affects a propagating wave front, and if it's any different than "photons as little bullets". Especially once the flux is so low that the average distance between photons would be much larger than their wavelength.
  • #52
Drakkith said:
Also, if light did attract itself, wouldn't light from far away stars and galaxies look...different after thousands, millions, or billions of light years?
Maybe that explains why we think that matter in the universe accelerate away from each other? The stars and galaxies appears to be located further away than they really are. The further away the observed star or galaxy is, the errors in estimated distance accelerates and not the matter itself?
EDIT:
So the redshift observed from a far away star might happen due to the longer distance the light has traveled - due to the photon-photon gravity(?). And also, if photons have gravity, they have mass, and therfor they does not travel at the "ultimate" speed...
Vidar
  • #53
Not only is there no direct evidence that photons attract gravitationally, there is also no direct evidence that leptons attract gravitationally. This is an area that I have researched (mostly within the limits of classical mechanics), and the consensus seems to be that it is still an open question. I am assuming that by "attract gravitationally", the op is referring to active gravitational mass.
Newton's third law of motion is usually used as an argument that these particles must have active gravitational mass. But this is an argument that I have never understood, because in all other cases, other than gravity, the source that creates the force (one body, the other, or both) is irrelevant. Why it should make a difference in the case of gravity is a mystery to me. But gravity is unique, so who is to say one way or the other. There is no direct evidence to confirm or deny. However, one thing is for sure, if these particles (at least in the case of leptons) do not generate a gravitational field then the equivalence principle will be violated.
  • #54
Hmmm, my multi-quote button won't work for some reason, so I'll have to do this the hard way.
Low-Q, a couple of things. First, light does not have mass, it has energy. When we say mass we mean "invariant mass", that is the mass something has when observed in it's stationary frame of reference. Light does not have an a frame of reference, so we cannot apply a mass to it. Since it does carry energy, and energy contributes to the stress-energy tensor of General Relativity, and that tensor determines gravity, we can say that light does in fact have gravity.
Second, EM radiation is everywhere, so light would not be red or blue shifted due to the approximately equal distribution of light in the universe. The same thing applies to the distribution of galaxies. (If it's pulling equally strong from all sides, gravity cannot red or blueshift light)
TutleMeister, what experiments have you done? Do you have a link to a paper or something? I'd love to see it. (Or do you mean something less professional when you say "research")
  • #55
Here is an essay from The Gravity Research Foundation. I'm not sure if this meets your requirements, but it has references at the bottom of the page.
http://www.gravityresearchfoundation.org/pdf/awarded/2001/unnikrishnan_gillies.pdf
  • #56
Lets say we have a black hole and then we have another black hole that is identical but made of antimatter and they collide, they will turn into photons and we will still have a black hole, the light can't escape. And this Black hole will cause other photons to be curved by it or drawn in.
  • Quantum Physics
  • Other Physics Topics
  • Quantum Physics
  • Beyond the Standard Models
  • Quantum Physics
