Single slit diffraction - distance between 1st&2nd order dark fringes
In summary, the conversation discusses the use of the formula y=(n*lambda*L)/d to find the distance between the first- and second-order dark fringes on a screen when monochromatic light with wavelength 580nm passes through a single slit 2.60um wide and 2.10m from the screen. The conversation also mentions using the angle of deviation from the original direction of the light ray and the known length L to find the difference in y. It is noted that the equation in the formula may be a good approximation if the angle of deviation is small.
louza8
58
Monochromatic light with wavelength 580nm passes through a single slit 2.60um wide and 2.10m from a screen.
Find the distance between the first- and second-order dark fringes on the screen.
y=(n*lamda*L)/d
y1=580nm*2.1m/2.1um=0.468m
y2=580nm*2.1m*2/2.1um=0.937m
y2-y1=0.468m
I am not sure how to handle the dark fringes in single slit diffraction, so I am not sure where I am going wrong.
Thanks for people's help in advance.
Do you know what the letters mean in the formula y=(n*lambda*L)/d and when is it a good approximation?
ehild
y is the distance between the fringes hitting the screen, n is the order, lambda is the wavelength, L is the distance to the screen, d is the width of the slit?
i don't know when it is a good approximation or what you mean by that.
Yo know a formula which contain the angle of deviation from the original direction of the light ray, hitting the slit. It is the exact one. ehild
n*lamda = d*sin(theta) ?
so would i use the angle found theta, and the known length L in a triangle to find the difference in y?
Yes. Calculate theta for n=1 and for n=2. The relation between L and y is y/L=tan(theta). If theta was very small, not more than a few degrees, you could approximate sin(theta) with tan(theta) and the equation in your first post would be valid. It is not the case now.
ehild
thanks ehild, helpful as always
1. What is single slit diffraction?
Single slit diffraction is a phenomenon that occurs when a light wave passes through a narrow slit and spreads out into a pattern of light and dark fringes on a screen placed behind the slit.
2. How is the distance between the 1st and 2nd order dark fringes calculated?
The distance between the 1st and 2nd order dark fringes can be calculated using the equation: dλ = xL/D, where d is the distance between the slits, λ is the wavelength of the light, x is the distance between the 1st and 2nd order dark fringes, L is the distance between the slit and the screen, and D is the distance between the slit and the source of light.
3. What is the significance of the distance between the 1st and 2nd order dark fringes?
The distance between the 1st and 2nd order dark fringes can be used to determine the wavelength of the light passing through the slit. This is because the distance between the fringes is directly proportional to the wavelength of the light.
4. How does the distance between the 1st and 2nd order dark fringes change with different wavelengths of light?
The distance between the 1st and 2nd order dark fringes increases as the wavelength of light increases. This is because longer wavelengths diffract more, causing the dark fringes to spread out more.
5. What other factors can affect the distance between the 1st and 2nd order dark fringes?
The distance between the 1st and 2nd order dark fringes can also be affected by the width of the slit, the distance between the slit and the screen, and the distance between the slit and the source of light. Additionally, the type of light source and the properties of the material the slit is made of can also play a role in the distance between the fringes.
