Precision Rectifier: Get Answers to Your Questions
In summary, a precision rectifier is an electronic circuit used to convert AC to DC with high accuracy and low distortion. It typically uses diodes and operational amplifiers to achieve this conversion. The main advantages of using a precision rectifier are its accuracy and ability to handle high frequency signals. There are various types of precision rectifiers, each with its own unique characteristics, and they are commonly used in power supplies, audio equipment, signal conditioning circuits, communication systems, and data acquisition systems.
xw0927
hey,dude,i m confusing about the precision rectifier...why the Vout =E,my question is why the Vout=E - V(diode) ?why the Vdiode does not take into account when finding Vout?here the attachement of the precision circuit diagram..
The op-amp compensates for the diode drop as part of the negative feedback.
oic~~~~quite confusing about that because i haven't learn the characteristics of opamp.anyway.thx ya~
1. What is a precision rectifier?
A precision rectifier is an electronic circuit that is used to convert alternating current (AC) to direct current (DC) with high accuracy and low distortion. It is commonly used in electronic devices such as power supplies, audio equipment, and signal processing circuits.
2. How does a precision rectifier work?
A precision rectifier typically uses a combination of diodes, operational amplifiers, and other components to rectify the input AC signal. The diodes act as one-way valves, allowing only the positive or negative portions of the AC signal to pass through. The operational amplifier is used to amplify and shape the output signal to match the input signal.
3. What are the advantages of using a precision rectifier?
The main advantage of using a precision rectifier is its ability to accurately convert AC to DC with minimal distortion. This is important in applications where precise and stable DC voltage is required, such as in electronic instrumentation and control systems. Additionally, precision rectifiers have a high input impedance, low output impedance, and can handle high frequency signals.
4. Are there different types of precision rectifiers?
Yes, there are several types of precision rectifiers, including half-wave, full-wave, and precision peak detectors. Each type has its own unique circuit design and characteristics, and is suitable for different applications. Some precision rectifiers also have additional features, such as adjustable gain and offset, to further improve their accuracy.
5. What are some common applications of precision rectifiers?
Precision rectifiers are commonly used in power supplies, audio equipment, and signal conditioning circuits. They can also be found in electronic instrumentation, measurement devices, and control systems. Additionally, precision rectifiers are used in communication systems to convert high frequency signals to DC, and in data acquisition systems to accurately measure and digitize analog signals.
  • Electrical Engineering
