What is the best way to separate ions in water?
In summary: This sounds like you're asking how to force Na+ and Cl- ions apart from each other so you could have "1 mole of positive ions in one jar and 1 mole of negative ions in another jar". That is NOT possible, the electromagnetic interaction is just too strong.
sr241
83
What is the best way to separate ions in water? for example separating Na+ and Cl- ions from a sodium chloride water solution ( water is a ionizing solvent). is using magnets a best way or is electromagnets a best way or using Lorentz force(combination of electrical and magnetic force) a best way.
How to calculate energy required to separate these ions, is there any chance this energy would be less than enthalpy of formation of sodium chloride?
Chemistry news on Phys.org
How would you separate ions with magnets?
Electrolysis looks like an obvious solution.
What do you plan to do?
I suspect someone with much understanding of chemistry would not use the term 'separate the ions' in solution which basically you cannot do.
You can electrolyse a NaCl solution with slightly complicated results, products are chlorine gas Cl2 hydrogen H2 and NaOH. This is an industrial process you can fnd in school chemistry books, I have a vague uncertain memory of seeing it done in a laboratory apparatus at school.
You can in solution use ion-exchange resins to exchange the ions for others, e.g. the Na+ by K+or H+ or the Cl- by OH- or by SO42- (in a 1:2 ratio obviously). Probably done in your school if you are in one to prepare 'deionised water', and in dishwashers etc. (to get rid of Ca2+ particularly.
Magnets poles attract +vely charged ions and -vely charged ions separately. if we flow the ionic solution through a pipe and place a "C" magnet over it and split the +ve and -ve ions into separate vessels; what is the energy requires to separate these ions how to calculate it.
No they do not. Magnetic poles would attract magnetic charges, but those do not exist (or have not been found yet).
Independent of the mechanism, you need at least the amount of energy you can get if you mix them again afterwards.
Magnets can propel ions (Charged particles) that's why Ion thrusters in rocket science works.
Large hadron collider works using this principle they can accelerate proton (H+ ion).
What is the known best way to separate ions in solution?
Static magnets can change their direction, but not their velocity (in the frame of the magnets). Ion drives use electric fields to accelerate the ions.
Again, magnets are just used to keep the particles in the circular path. Acceleration is done via electric fields.
Did you see my suggestion of electrolysis?
Can we flow ionic solution (NaCl water solution) through a pipe and put a "C" magnet over it and split th flow of +ve ions and -ve ions into two separate vessels. does this idea work? has anyone tried this? can this idea called a novel one? is this idea is of any use to practical problems?
You can get a small displacement, but that is quickly canceled by the electric field that forms. If you connect the sides electrically, it might be possible to separate some ions. I doubt that this process has a reasonable efficiency.
Likes 1 person
since magnets only change directions and does no work I thought I made a free energy device to split ions in solution
This sounds like you're asking how to force Na+ and Cl- ions apart from each other so you could have "1 mole of positive ions in one jar and 1 mole of negative ions in another jar". That is NOT possible, the electromagnetic interaction is just too strong. If you know Coulomb's law, you could calculate as an exercise the force that one mole of positive charges and one mole of negative charges would exert on each other even if the distance between them was 10 kilometers. Or estimate by dimensional analysis the pressure that would be needed to confine 1 mole of free Na+ ions in a volume of 1 dm3.
What is a "free energy device"? I hope you don't mean some kind of perpetual motion machine...
That is not possible, and it is pointless to try - in addition, it violates the forum rules to discuss that.
Your deflected ions would slow down due to the electrical potential that forms, and slow down the water flow.
If we use an inverted "Y" tube with short hands at the end of flow tube and place "C" shaped magnet at the junction of "Y" tube. will this work?
I am some what sure that a simple device like this will not be enough to tweak a well established law like conservation of energy.
The complexity is completely irrelevant. You can show (with mathematics) that the known laws of physics conserve energy. It is pointless to try to violate mathematics. You would need some violation of the known laws of physics, and this can be found with a real experiment only. You do not have this (in particular: you do not have this in a peer-reviewed journal), so this thread cannot lead to anything interesting. I closed it.
1. What methods can be used to separate ions in water?
There are several methods that can be used to separate ions in water, including distillation, precipitation, chromatography, electrophoresis, and ion exchange.
2. How does distillation separate ions in water?
Distillation separates ions in water by boiling the water and collecting the steam, which is then condensed into a liquid. Since ions have different boiling points, they can be separated based on their vaporization rates.
3. What is the principle behind precipitation in ion separation?
Precipitation works on the principle that when certain ions are mixed together in water, they can react and form insoluble compounds. These compounds can then be filtered out, leaving the separated ions in the water.
4. What is the difference between chromatography and electrophoresis in ion separation?
Chromatography separates ions based on their different affinities for a solid or liquid phase, while electrophoresis separates ions based on their charge and size differences. Chromatography is a slower process but can separate a wider range of ions, while electrophoresis is faster but can only separate ions with significant charge and size differences.
5. How does ion exchange separate ions in water?
Ion exchange involves passing the water through a resin that contains charged particles. The ions in the water will interact with the charged particles and be exchanged for other ions, resulting in the separation of ions in the water.
  • Chemistry
  • Electrical Engineering
