| New Reply |
Integrability (meaning) |
Share Thread | Thread Tools |
| Jan18-13, 09:58 AM | #1 |
The title is self-explanatory. What is it meant in the physics and maths community by the words integrability and integrable system?
| Jan18-13, 10:18 AM | #2 |
Have you seen an explanation like this:
http://en.wikipedia.org/wiki/Integration_(mathematics) where they first discuss integrating a smooth function..... or is this what really interests you: http://en.wikipedia.org/wiki/Integrable_system like maybe one of the systems listed at the end of the article?? |
| Jan18-13, 11:23 AM | #3 |
So, is it correct to state in general that: "an integrable system is a system which thanks to certain properties its dynamics is exactly solvable" ?
| Jan18-13, 12:39 PM | #4 |
You should wait for someone who is more up to date on math and current terminology than I....but I'll give you my 2 cents:
first, you posted this under Quantum Physics,so if you are looking for a specific answer, check here in the Wikipedia article: Quantum integrable systems that seems different from you latest post. second, You may have to define what 'solvable' means to you because the section in Wikipedia says this: General dynamical systems |
| Jan18-13, 01:24 PM | #5 |
∂f/∂x = F(x,y) ∂f/∂y = G(x,y) does f(x,y) exist? Answer, only if an integrability condition is satisfied: ∂2f/∂x∂y = ∂2f/∂y∂x, that is, ∂F/∂y = ∂G/∂x. |
| Jan19-13, 02:35 AM | #6 |
it is more suited with classical section,integrability of system is classified according to it's holonomicity.In classical dynamics a system which is non holonomic has at least one non-integrable eqn.they look like
Ʃaidqi +atdt=0 this eqn should not be a total differential(or can be converted).there are many examples of it.One simple and particular is rolling of a sphere on a rough surface.Point of contact satisfy a non integrable relation. |
| Jan19-13, 04:10 AM | #7 |
Recognitions:
A simple but eluminating example is the potential curl [tex]\vec{F}(\vec{x})=\frac{-y \vec{e}_x+x \vec{e}_y}{r^2}.[/tex] It's everywhere curl free, except in the origin, i.e., [tex]\partial_x F_y-\partial_y F_x=0,[/tex] but it does not have a unique potential in every region in the plane that contains the origin, where the singularity sits. Indeed, integrating the vector field along any circle around the origin gives [itex]2 \pi[/itex]. To make the potential unique, one has to cut the plane by a ray starting from the origin. A standard choice is the negative [itex]x[/itex]-axis. I.e., you take out the points [itex](x,0)[/itex] with [itex]x \leq 0[/itex]. It's most easy to find the corresponding potential by introducing polar coordinates. Here, we use [tex](x,y)=r (\cos \varphi,\sin \varphi)[/tex] with [tex]\varphi \in (-\pi,\pi),[/tex] which automatically excludes the negative x axis. The function [itex]\vec{F}[/itex] then reads [tex]\vec{F}=\frac{\vec{e}_{\varphi}}{r}.[/tex] The potential thus can be a function of only [itex]\varphi[/itex], and the gradient reads [tex]\vec{F} \stackrel{!}{=}-\vec{\nabla} V(\varphi)=-\frac{1}{r} V'(\varphi).[/tex] This gives, up to a constant [tex]V(\varphi)=-\varphi.[/tex] The potential is indeed unique everywhere except along the negative [itex]x[/itex] axis, along which it has a jump [tex]V(\varphi \rightarrow \pi-0^+)=-\pi, \quad V(\varphi \rightarrow -\pi + 0^+)=+\pi.[/tex] In Cartesian Coordinates this potential is given by [tex]V(\vec{x})=-\mathrm{sign} y \arccos \left (\frac{x}{\sqrt{x^2+y^2}} \right ).[/tex] |
| New Reply |
| Thread Tools | |
Similar Threads for: Integrability (meaning)
| Thread | Forum | Replies | ||
| Integrability on [0,1] | Calculus & Beyond Homework | 0 | ||
| Integrability of sin(x)*x^(-a) | Calculus | 3 | ||
| integrability of f^2 | Calculus & Beyond Homework | 1 | ||
| Integrability | Calculus & Beyond Homework | 4 | ||
| integrability | Calculus & Beyond Homework | 1 | ||
