How does radiation shielding using absorbing materials work?
In summary, the absorption of gamma radiation by a thick lead sheet occurs through three basic reactions on the molecular/atomic/subatomic level: pair production, photoelectric effect, and scattering. The same logic can be applied to cosmic particles, specifically high speed protons, but the shielding needs may differ. A lead shield that is effective for gamma rays should also work for cosmic particles.
anj16
38
I understand that, for example, a thick enough sheet of lead can absorb gamma radiation, but I want to understand what actually happens at the molecular/atomic/subatomic level. Also, can the same logic be applied to cosmic particles? I have tried Googling for an answer, but to no avail. Can someone enlighten me?
Thank you!
There are three basic reactions of gamma rays with matter, pair production (at high energy), photoelectric effect (all energies, but increasing as the energy gets lower), and scattering (which lowers the energy). The first two are absorption, although the positron from pair production will annihilate an electron resulting in two lower energy gamma rays. The lower energy gamma rays are more easily absorbed due the increase in cross-section for the photoelectric effect. These reactions are all on the atomic level.
Casmic ray particles are mostly high speed protons, so the shielding needs are different. However a lead shield that is good for gamma rays should be adequate.
1. How do materials absorb radiation?
Materials absorb radiation through a process called attenuation, where the energy of the radiation is reduced as it passes through the material. This can happen through different mechanisms such as absorption, scattering, and reflection.
2. What makes a material effective for radiation shielding?
An effective radiation shielding material must have a high atomic number, which means it has more protons in its nucleus, as this allows it to absorb more radiation. It should also have a high density and thickness to provide a physical barrier for the radiation to pass through.
3. Is there a difference between alpha, beta, and gamma radiation shielding?
Yes, there is a difference in the materials used for shielding different types of radiation. Alpha particles can be stopped by a sheet of paper, while beta particles may require thicker materials such as aluminum or plastic. Gamma radiation, on the other hand, requires denser materials like lead or concrete for effective shielding.
4. How does radiation shielding protect humans from harmful effects?
Radiation shielding protects humans by reducing their exposure to harmful radiation. When exposed to radiation, the cells in our bodies can be damaged, leading to health issues such as cancer. Shielding materials absorb or deflect the radiation, reducing the amount that reaches our bodies and minimizing potential harm.
5. Can radiation shielding materials become radioactive?
No, radiation shielding materials do not become radioactive. They may become contaminated with radioactive particles if they are exposed to high levels of radiation, but they can be decontaminated and do not become radioactive themselves.
  • Astronomy and Astrophysics
