Swinging Pendulum and Conservation of Energy
In summary, the group discussed the difficulty of finding the maximum speed of a pendulum swing with given measurements of length and amplitude. They considered using the formula vf= square root of 2gh but were left with incorrect answers. The group then suggested applying the conservation of energy method and using proper units, which led to the correct answer. They also discussed the meaning of "amplitude" and how it can be interpreted differently. They concluded that this is a fundamental method and recommended not memorizing formulas but learning this method instead.
Axelerator
Hello all, I've been having major difficulty with a question that deals with a pendulum swing, and to find the maximum speed after the release
The length of the pendulum is 85.5cm and the amplitude is 24.5cm
I was thinking to find the vf= you have to do square root of 2gh and solve, but I'm always left with the wrong answer,
Any help would be greatly appreciated.
That seems like it should give the right answer. What are you using for g and h? Are they in the proper units?
I don't know if that formula is correct or what it applies to but I would recommend not memorizing a bunch of formulas for specific cases (only memorize the ones that are hard to derive), but instead apply a general method that can be used to solve any equation.
In this case, like you said in your title, you can use conservation of energy to equate gravitational potential energy at the top to kinetic and gravitational potential at the bottom.
Like Euclid said make sure you are using proper units (meters not centimeters) and that you determined the height properly.
yes i converted 85.5 to 0.855 m, and my final answer is 4.09 m/s but the text says 0.838 m/s
You see, I did derive the formula, from equating 1/2mv^2 = mgh and i managed to get v= square root 2gh, and i cannot seem to get the answer, and I am using appropriate units. I just don't understand what the use of 24.5 cm, it says it is the amplitude.
The term "amplitude" seems to be unclear here. I took it to mean the maximum height, but this gives 2.19 m/s for the max velocity.
Usually the amplitude is given in terms of degrees.
I took the amplitude to mean the arc-length of half a pendulum swing and obtained an answer close to yours (I guess you used small angle approximation)
The question says:
Simple pendulum, 85.5 cm long, is held at rest so that its amplitude will be 24.5 cm as illustrated. (figure shown with a hanging pendulum and its length is 84.5 and the space between it after it has moved is 24.5). Use energy concepts to determine maximum speed of the pendulum bob after release.
Euclid how did you get 2.09 m/s...? Question is boggling me =(
24.5cm must be the horizontal amplitude. This means [tex]l \sin \theta = 24.5[/tex]cm. For h, use [tex] h = l(1-cos\theta)[/tex]. This should give the correct answer.
How is such applicable if no angle is given?
I am using theta to denote the angle between the pendulum at its maximum height and at its minimum height.
You don't need to know theta, since [tex] \cos \theta = \sqrt{1-\sin^2 \theta}=\sqrt{1-(24.5cm)^2/l^2}[/tex]
I still can't get the answer of 0.838, or even close to.
Show me your work, and I will try to figure out where you went wrong.
ok, I did as you suggest square root of ==>
1-(0.245)^2/(0.855)^2
cos theta = 1.1334 and then i applied what you gave me when you said
h= L (1-cos theta)
= 0.855 (1-0.99)
=1.71 x 10 ^-4
then i put that back to v= square root 2gh
= 2(9.8)(1.71 x 10 ^-4)
=0.05789 m/s...
Seems very wrong to me...?
h= L (1-cos theta)
= 0.855 (1-0.99)
=1.71 x 10 ^-4
=0.05789 m/s...
sorry for the double post, but also may I point out that this technique has not even been remotely explained at all, i was wondering is there any other technique to solve this problem?
cos can never be > 1
try again
To my knowledge, this is the best method to solve the problem.
And it's a fundamental method anyway, so it would be beneficial to learn it.
I don't understand I did what you asked me to, and I get 1.13 from the information you've given me
1 - (255/855)^2 = 1 - (25/85)^2 = 1 - (5/17)^2 = 1 - 25/289 = 1- 8/100 = .92
The equality is only approximate, but I do not have a calculator on me. In any event, it is certainly NOT 1.13.
ok, I see what I did wrong, thing is, cos of that is around 23 degrees, so do I subtract that when I do h= L (1-cos theta)?
No, remember the whole point was to avoid calculating the angle. And, the cosine of a number does not give back degrees.
cos \theta = \sqrt{.92} (Approx)
Use this in your formula for h = L(1-\sqrt{.92}).
Awesome! Thanks a million dude, I finally got the answer thanks a lot. :D
1. What is a swinging pendulum and how does it demonstrate conservation of energy?
A swinging pendulum is a weight attached to a pivot point that can freely swing back and forth. As the pendulum swings, it demonstrates the transfer of kinetic energy (energy of motion) to potential energy (stored energy) and back again. This shows the law of conservation of energy, which states that energy cannot be created or destroyed, only transferred or transformed.
2. How does the length of the pendulum affect its energy?
The length of the pendulum affects its energy by changing the period, or the amount of time it takes to complete one swing. A longer pendulum has a longer period, meaning it takes more time to complete one swing. This results in a slower swing and less kinetic energy, but more potential energy at the top of the swing. A shorter pendulum has a shorter period, resulting in a faster swing and more kinetic energy, but less potential energy.
3. Can the mass of the pendulum affect its energy?
Yes, the mass of the pendulum can affect its energy. A heavier pendulum will have more kinetic energy as it swings, but also more potential energy at the top of the swing. A lighter pendulum will have less energy overall. However, the mass of the pendulum does not affect the period or the transfer of energy between kinetic and potential.
4. How does the angle of release affect the pendulum's energy?
The angle of release, or the angle at which the pendulum is pulled back before being released, affects the pendulum's energy by changing the initial potential energy. A larger angle of release will result in a higher initial potential energy, which will then be converted into kinetic energy as the pendulum swings. A smaller angle of release will result in a lower initial potential energy and less kinetic energy.
5. Can the air resistance affect the pendulum's energy?
Yes, air resistance can affect the pendulum's energy by reducing the amount of energy lost to friction as it swings back and forth. In a vacuum, a pendulum would continue to swing forever due to the conservation of energy. However, in the presence of air resistance, some of the energy will be lost to friction, resulting in a shorter period and smaller swings over time.
