Capacity vs Bandwidth: Exploring Data Transfer Rates
In summary: AM also uses frequency modulation, but the carrier frequency is also constantly changing. This results in a spectrum with a lot of different frequencies present.
znb
hi,
1.please tel me in detail why do we say that for higher capacity we require more bandwidth?
higher capacity means more data rate, meaning more bits per seconds(and i know BW is bps) but tell me in terms of frequencies availble in a band..coz we transmit our signal on 1 freq then what it has to do with the other freq in that band, when we transmit our signal after modulating it on some higher freq carrier then how does it actually travel in the air..what my understanding is that only sinusiods (with single frequency)travel then where is the data? and also what is the use of the bandwidth, let say if i modulate my signal on 2Ghz and it has a BW of say 500MHz then my antenna generates the signal of 2GHz sinusiod..so where is the data coz its just a plain sinusiod of 2G and also what are the other freq in that band doing?..does this antenna generate 2.1G, 2.2G also and propagates like a signal with variable frequencies to extract the data in terms of variation in freq??Plz explain..um so confused and i nkow um very bad with basics.
2. also why we say that more bits per seconds means more variations in the signal(in terms of time domain) and does more variations in the signal refer to more frequency componets present in that signal?
You cannot transmit any meaningful information on a single frequency.
A signal of exactly one frequency is nothing more than a sine wave. You can represent ones and zeros by the presence or absence of this signal, but that's it, and it's really unreliable.
When people say "I'm transmitting my data at 2 GHz," they do not mean that they're using only one specific frequency. What they mean is they're transmitting over some band of frequencies centered around 2 GHz.
If you imagine modulating this pure sine wave in any way, you will introduce components of other frequencies. The two most familiar modulation schemes are instructive. Amplitude modulation (AM) varies the amplitude of a carrier frequency. This actually smears the signal out over a nearby range of frequencies, called a channel. In frequency modulation (FM), the carrier frequency itself is varied to encode the transmitted information. This obviously involves a range of frequencies.
Your intuition is corect: you cannot change a signal in the time domain without also changing its spectrum in the frequency domain.
- Warren
A 2 ghz FM signal with 500mhz bandwidth could be implemented as a signal with a rage from 2ghz-250mhz to 2ghz+250mhz. With AM signals, it's not quite as obvious, the rate of change in amplitude uses up bandwidth. Morse code transmitters modulate the ramp on and off time to take several milliseconds to reduce bandwidth.
I got this thing sir but how does it transmit in the air. does your antenna transmit all these frequencies in that band at the same time? and if let's suppose u are using FM then how your anteena transmit the signal.
eg. for 101 it transmit one freq then for 010 another freq from the band and so on...in a consecutive fashion..is it right??
and how does it go with AM? coz here only the amplitude of the waveform changes and this waveform will be having only one frequency..then what the other frequencies of the band be doing??
also tell me why we do need more BW for higher cap data.
higher cap>>more bits per sec>>more variations in the data>>more freq components present coz of variations>>therefore more BW?
is this right?? please correct me.
BUT variations can me bw 2-3 frequencies?right then how this whole thing goes??
please HELP
Of course it does. If it didn't, the receiver would not be able to recreate the signal.
No, the FM transmitter simultaneously transmits on all the frequencies in the band.
Think about your voice. Your voice contains frequencies from about 100 Hz all the way up to about 5 kHz. When you speak, your voice uses frequencies all throughout this band, simultaneously. Your listener will only be able to understand you if his/her ears receive all of thse frequencies simultaneously.
If you continuously vary the amplitude of a pure sine wave, you no longer have a signal of just one frequency.
Think about this: one way to vary the amplitude of a sine wave is to add other sinusoids of different frequencies to it. Try it on a graphing calculator. So, a sine wave with a varying amplitude is not a pure sine wave: it contains all kinds of different frequency components.
- Warren
ok if transmitter transmits all the frequencies in that band simultaneously then we would have different sinusoids in the air as an output of our antenna..lets say 900Mhz, 900.1 Mhz and so on rite?? but they r pure sinusoids where is our data?there must be some thing that indicates..e.g.
usually in telecom our digitized voice is modulated on some higher frequency..
for bits 00 we assign some freq1 and for 10 another freq2 and so on ...if our speech Sx is 00 10 00 10 10...so freq1 and freq2 ll be trasmitted?? BUT 00 is transmitted only 2 times where as 10 is 3 times then what is done at the transmitter that tells this thing..PLZ EXPLAIN
Not just discrete frequencies like 900 MHz and 900.1 MHz. The information can be transmitted at every frequency simultaneously, in a continuum.
As an example, one of the simplest sorts of digital information transmission is called BPSK, or "binary phase-shift keying." This modulation uses a single carrier frequency, but can broadcast the carrier at two different phases, 180 degrees apart.
Each bit will occupy a specific amount of time. Let's say the transmitter transmits 0 degrees phase for one microsecond, then switches to 180 degrees phase for the next microsecond. That might be an encoding for a zero, and a one.
It may sound like this information occupies only a single frequency, but it does not. The transitions from one phase to the next involve abrupt changes in the waveform, and these discontinuities involve energy in other frequencies.
- Warren
ok that means in air we transmits all these frequencies that helps in constructing a waveform that changes its phase from 0 to 180 and to get this, all the frequencies are sent at different power levels..
MY main concern is that how we transmit them in air??i mean all these freq ll be in sinusoid form,it is the power with which they r transmitted creates the difference?...
You can think about a transmitted waveform in either the time domain or in the frequency domain. It's not particularly helpful to imagine a transmitter designed to simultaneously transmit multiple perfect sinusoids on different frequencies, with different powers.
Instead, just understand that a transmitter which transmits an arbitrary, complex waveform is doing fundamentally the same thing.
- Warren
but complex waveform doesn't travel in air?
Of course complex waveforms can travel through air (in the form of electromagnetic radiation)! Complex waveforms are nothing but a sum of simple sinusoids, and simple sinusoids travel through air just fine.
- Warren
you tell me how it goes in this case..
-yu have binary data 1 0 and you are required to do frequency modulation.
-if ur data is 1000001
-then for 1 you slect one freq and for 0 another
-but 1 only appeares twice in the message where as 0 appears 5 times
-you transmit freq A and B for 0 1 respectively
-BUT how you manage to tell that 1 appears only 2 times where as 0 appears for 5 times?
What you're describing is binary frequency-shift keying (BFSK).
You break the transmission down into units of time. For the first microsecond, you transmit frequency A. For the second, third, fourth, fifth, and sixth microseconds, you transmit frequency B. For the seventh microsecond, you transmit frequency A again.
- Warren
but you said earlier
I never said anything like that. FM is an analog modulation scheme not, a digital one.
- Warren
ME:
YOU:
SCROLL UP
why don't you come to yahoo sir??
Again, FM is an analog (continuous) form of modulation, in which an analog signal (like a voice) is used to modulate a carrier.
BFSK is a digital (discrete) form of modulation, in which only two specific frequencies are used.
Your questions are so vague that I really do not understand where you are stuck. Simply telling me "SCROLL UP" doesn't help.
I prefer not to use Yahoo.
- Warren
but there i can make you understand more clearly what i exactly want to know
how does our speech signal propagates in air?
first our speech is digitized then digital modulation is performed like BPSK etc and then this whole thing is sent using analog modulation using some higher freq carrier rite?
Well, BPSK is extremely simplistic, and is not used in many real-world applications. Cell phones digitize the audio, chop it into packets, use it to modulate a carrier with a scheme like QAM, and then broadcast it over radio during the appropriate time slots.
- Warren
lets say our voice is digitized our sx is 1010
now it is digitally modulized using PSK either 2,4,16 etc.
we ll have a complex wave form with varying phase BUT ofcourse this can not be made to travel in actual, rather all the frequencies that helps make this wave form to occur in such complex way with warying amplitude are transmitted...tell me am i correct till here?
Ocourse after this they are modulated on some high carrier and transmitted in air...i wll ask things beyond this later but confirm me am i correct till digital modulation?
There is no difference at all between a complex waveform, and the waveform's Fourier decomposition.
As I've said multiple times now, you can certainly broadcast a complex waveform through the air using electromagnetic radiation.
- Warren
okk.
why do we say if we have more bps we require more bandwidth.
as per my understanding..in order to send many bits in a unit time..we require as many frequencies to modulate them in that unit of time??
otherwise if we have lesser frequencies then we need to come up with some good higher modulation scheme or shud stick with lower data rate..is it rite?
If you want to transmit at higher data rate, you generally need more bandwidth. You can sometimes improve data rate by improving your modulation or coding, but many systems already use very efficient modulations, near the theoretical limit.
The theoretical limit is rather easy to understand: you have limited signal power, and noise with a known power. The larger the bandwidth, the smaller the power-spectral density of that noise.
Read this, and let me know if you have specific questions. Your questions are currently too vague.
http://en.wikipedia.org/wiki/Shannon–Hartley_theorem
- Warren
why don't you reply me there on yahoo please??
I give up.
- Warren
Hello all
I am very new to this forum. I found very interesting and helpful topics been discussed in this forum especially post from Warren are very detailed and informatic
sorry to putting my question in 3year old thread..
I also have similar question what ZNB had
I understand Digital modulation (bpsk,qpsk etc) uses phase of the carrier wave to transport digital bit information.
How can I visualize phase change of carrier wave phase 0 to 180 or 180 to 0 degrees in case of BPSK if frequency domain? How much bw does this occupy in frequency domain?
what happens if we suppress all frequency components other than carrier frequency?
What is the rational behind Nyquist theorem?
"where fp is the pulse frequency (in pulses per second) and B is the bandwidth (in hertz). The quantity 2B later came to be called the Nyquist rate, and transmitting at the limiting pulse rate of 2B pulses per second as signalling at the Nyquist rate"
1. What is the difference between capacity and bandwidth?
Capacity refers to the maximum amount of data that can be transferred in a given amount of time, while bandwidth refers to the maximum rate at which data can be transferred.
2. How are capacity and bandwidth related?
Capacity and bandwidth are closely related, as a higher bandwidth allows for a higher capacity. However, other factors such as network congestion and hardware limitations can also affect the actual data transfer rate.
3. What units are used to measure capacity and bandwidth?
Capacity is typically measured in bits or bytes, while bandwidth is measured in bits per second (bps) or bytes per second (Bps).
4. How does data transfer rate affect internet speed?
Data transfer rate, which is determined by both capacity and bandwidth, is a key factor in determining internet speed. The higher the data transfer rate, the faster data can be transferred, resulting in faster internet speed.
5. Can capacity and bandwidth be increased?
Yes, both capacity and bandwidth can be increased by upgrading network infrastructure, using faster hardware, and optimizing data transfer protocols. However, there may be limitations based on the capabilities of the devices and network being used.
  • Electrical Engineering
  • General Engineering
  • Astronomy and Astrophysics
