Why do we treat velocity and position as independent in a lagrangian
In summary, the Euler-Lagrange equations follow from the principle of least action by setting the first functional derivative to 0. You evaluate this derivative by expanding the arbitrary path around the trajectory and taking the limit as the support of the derivative to the single point.
Storm Butler
78
I was wondering why when we derive the euler lagrange equations and when we use them we treat x and x dot as independent quantities?
Behind the Euler-Lagrange Equations of a given Lagrangian is Hamilton's principle of least action (in the Lagrange version). Thus you calculate functional derivatives of the action with respect to [itex]q(t)[/itex]. The Euler-Lagrange Equations follow from the principle by setting the first functional derivative to 0.
To evaluate this derivative, you have to expand the arbitrary path around the trajectory, i.e., you calculate the functional derivative from its definition. If you have the action in standard form,
[tex]A[q]=\int_{t_0}^{t_1} \mathrm{d} t L[q(t),\dot{q}(t)],[/tex]
then the functional derivative is defined by
[tex]\frac{\delta A}{\delta q(t)}=\lim_{\epsilon \rightarrow 0} \frac{A[q+\epsilon \eta]-A[q]}{\epsilon}=\left. \frac{\mathrm{d} A[q+\epsilon \eta]}{\mathrm{d} \epsilon} \right|_{\epsilon \rightarrow 0}.[/tex].
Here [itex]\eta[/itex] is a function with support at a very small region around [itex]t[/itex]. Particularly you must have [itex]\eta(t_0)=\eta(t_1)=0[/itex] according to the constraints that the boundary points of the paths are not varied in Hamilton's principle (by definition).
After taking the derivative you take as another limit the support of [itex]\eta[/itex] to the single point [itex]t[/itex], i.e., in a sense [itex]\eta(t') \propto \delta(t'-t)[/itex]. From these considerations, after one integration by parts you get
[tex]\frac{\delta A}{\delta q(t)}=\frac{\partial L}{\partial x} - \frac{\mathrm{d}}{\mathrm{d} t} \frac{\partial L}{\partial \dot{q}},[/tex]
where the [itex]q[/itex] and [itex]\dot{q}[/itex] have to be taken as independent variables when taking the partial derivatives, but then have to be interpreted as [itex]\dot{q}=\mathrm{d} q/\mathrm{d} t[/itex] again when taking the time derivative.
Hmm, that's not how I usually see it done. In the derivations I've seen, they say something like "Since the integral of [itex]\eta[/itex] times blah is zero and [itex]\eta[/itex] was arbitrary, it follows that blah is zero." Is that not fully rigorous?
I would also like to know, what is the functional derivative of A before you do anything to η?
The reason we treat velocity and position as independent in a Lagrangian is because they represent two fundamental aspects of motion that are not directly dependent on each other. Velocity is the rate of change of position, but it is not determined solely by the position itself. It also depends on other factors such as the forces acting on the object. Therefore, in order to fully describe the motion of an object, we need to consider both position and velocity separately.
In the derivation of the Euler-Lagrange equations, we treat position and velocity as independent variables because they are the two most basic quantities that are needed to describe the state of a system. By treating them as independent, we can take into account all the relevant factors that influence the motion of the system, such as forces and constraints.
Furthermore, treating position and velocity as independent allows us to consider a wide range of systems, including those with complex and nonlinear dynamics. If we were to treat them as dependent variables, it would limit our ability to accurately describe and analyze the behavior of these systems.
In summary, treating position and velocity as independent in a Lagrangian is necessary in order to fully describe and analyze the motion of a system, and it allows for a more comprehensive understanding of complex systems.
1. Why do we treat velocity and position as independent in a lagrangian?
The Lagrangian, which is used in classical mechanics to describe the motion of a system, is based on the principle of least action. This principle states that the path a system takes between two points in time is the one that minimizes the action, which is defined as the integral of the Lagrangian over time. In order for this principle to work, the Lagrangian must be a function of independent variables. In this case, the independent variables are position and velocity.
2. What is the significance of treating velocity and position as independent in a lagrangian?
Treating velocity and position as independent variables allows us to describe the motion of a system in a more general and elegant way. It also allows us to easily incorporate constraints and external forces into the Lagrangian, which would not be possible if we treated velocity and position as dependent variables.
3. Is it possible to treat velocity and position as dependent in a lagrangian?
No, it is not possible to treat velocity and position as dependent variables in a Lagrangian. This is because the Lagrangian is based on the principle of least action, which requires the Lagrangian to be a function of independent variables. If velocity and position were treated as dependent, the Lagrangian would not be able to accurately describe the motion of a system.
4. How does treating velocity and position as independent in a lagrangian affect the equations of motion?
Treating velocity and position as independent variables in the Lagrangian leads to a set of second-order differential equations known as the Euler-Lagrange equations. These equations are derived from the principle of least action and provide a concise and efficient way to describe the motion of a system.
5. Are there any limitations to treating velocity and position as independent in a lagrangian?
While treating velocity and position as independent variables in the Lagrangian is a powerful tool, it does have its limitations. For example, the Lagrangian cannot accurately describe systems that exhibit chaotic behavior or systems that involve quantum mechanics. In these cases, alternative methods must be used to describe the motion of the system.
  • Mechanics
  • Mechanics
