Ballistic
- 16
I am analyzing the landing of an aircraft with the following assumptions:
- I consider the main and the nose landing gear wheels as skids, in order to ignore the tyre deflection;
- I have a 3 DOF aircraft model, with X and Y-axis indicating the forces acting respectively horizontally and vertically and the theta angle positive clockwise. This frame of reference is referred to the center of gravity;
- I assume that the plane has already touched the ground, so I don't consider the gliding phase towards the runway.
Now the summation of moments aroung the c.g. gives:
ƩMcg = Iyy[itex]\ddot{\vartheta}[/itex]= RNLG * Ln - RMLG * Lm - hcg * [itex]\mu[/itex]Fvert
Where:
[itex]\ddot{\vartheta}[/itex] is the angular acceleration of the pitch moment;
RNLG and RMLG are the vertical reactions of the nose and of the main landing gear shock absorber;
Ln and Lm are the distances respectively of the nose landing gear and of the main landing gear from the c.g.;
[itex]\mu[/itex] is the friction coefficient;
hcg is the vertical distance between the runway and the c.g.;
Fvert is the resultant of the vertical forces.
Knowing the value of Iyy, which is the airplane pitch moment of intertia I can then compute [itex]\ddot{\vartheta}[/itex].
From this angular acceleration of the pitch angle I want to find the angle of attack, which is the difference from the pitch angle and the flight path angle:
A.o.A. -> α = θ - γ
My questions are:
1) Can I assume γ = 0 (flight path angle), since the plane has already touched the ground when I start my computations?
2) If so, how do I integrate [itex]\ddot{\vartheta}[/itex] in order to get the picth angle? What are my intitial conditions?
I hope that everything is clear and sorry for the long post.
Where:
A.o.A. -> α = θ - γ
My questions are:
