Resistor Voltage Drop Concept Question
In summary: Suppose you had a lamp that needed 20 volts at 1 amp and the supply was 120 volts.The battery would still have to supply 1 amp and the resistors would have to drop 100 volts.So, the total resistance (apart from the lamp) would be 100 volts divided by 1 amp, or 100 ohms.It doesn't matter where around the circuit you put this 100 ohms and it could even be made up of a number of smaller resistors in series. You could have two 50 ohm resistors in the positions shown as R1 and R2 in the diagram.Don't get hung up about the direction of current flow. It isn't important. Just accept that current flows
Simon777
35
I'm currently studying electric circuits and can't find the answer to my question anywhere so far. I realize current is the flow of positive charge even though positive charges stay put in reality and that this is an old historic concept that is still around today because Benjamin Franklin designated positive charge as the one that moves. My issue is understanding how positive charge is the same things as negative charge flowing in the opposite direction in the following situation:
http://www.tutapoint.com/kcimages/Series_Circuit.png [Broken]
Suppose there is a light bulb in the middle of the two resistors that needs a voltage drop of 20V with the battery providing 120V. If the charge flows from positive to negative, then the left resistor would need to provide the voltage drop. If the charge flows from negative to positive, then the right resistor would need to provide the voltage drop and in this case it matters which way the current is moving.
I'm sure it could work either way, but my mind cannot accept that until I solve this. Could anyone help clear this up for me?
The current from the battery depends on the total resistance, so all the resistors contribute to the final voltage on the lamp.
So, suppose you had a lamp that needed 20 volts at 1 amp and the supply was 120 volts.
Don't get hung up about the direction of current flow. It isn't important. Just accept that current flows from positive to negative.
On rare occasions you need to remember that electrons are actually flowing the other way.
It all makes sense now. I don't understand why my professor never mentioned this. Thank you so much for helping me clear this up.
I have another question related to this. Does this mean that in the situation you described with the resistors dropping the voltage by 100 volts, that at every point in the circuit, there would be 20 volts of potential energy available? I'm trying to understand how there can be a higher voltage near the positive end and a lower voltage near the negative end and yet there still be 20 volts available at all points to supply a light at any point it is placed at in the circuit. Doesn't voltage decrease as you move along the circuit? If you could describe what happens to voltage as it moves along the circuit in your described situation, I would really appreciate it.
Each resistor or lamp has a voltage across it that depends on its resistance and the current flowing in it.
So, if you had two 50 ohm resistors, each with 1 amp flowing in them, and a 20 ohm lamp with 1 amp flowing in it, then the resistors would have 50 volts across them, wherever they were, and the lamp would have 20 volts across it, wherever it was.
So, the voltage drop would move if you moved the components, but the lamp would still get 20 volts to operate.
It is only the potential difference across the battery that matters. Try to forget the Physics concept of "high" and "low" potential. The two terminals of a battery are equally important and neither has an inherently higher potential than the other.
After doing a bit more studying and reading your explanation, I believe I have a better grasp of the concept. Thank you so much for helping me do this. My big issue was realizing circuits work in unison and I was thinking too much on an individualistic level.
I do have a question about something I thought of related to Kirchhoff's Voltage Rule. In our situation, we had 120V going in and there was a voltage drop of 120V with the 2 resistors and the light. Now if the voltage drop were larger than the voltage the battery provides, would there would be no flow of current? On the other end of the spectrum, what happens when the battery provides more voltage than the circuit needs. Or can this even happen? I assume it would violate Kirchhoff's rule in a closed circuit, but what about other types of circuits?
No, the voltage across the lamp and resistors has to add up to the supply voltage.
The current in the circuit just depends on the voltage and the resistance, so the voltages across the resistor and lamp will vary depending on the current through them.
Thank you so much for all your help. I really appreciate the time you took to explain this to me.
I would assume also that if you had two 50 ohm resistors and a bulb 'supposed' to run at 20 oms that if only say 110 volts were supplied then the bulb would only receive 10 volts instead of 20. Likewise if only 100 volts were supplied it wouldn't light at all.
What i can't really wrap my head around is how can a resistor placed in a circuit after a load affect the load (assuming DC at least). If you had a light bulb in a 120V circuit, I assume it would have 120V across it so that by the end of the circuit, there were 0V. If i added a second bulb in series, they would both (assuming likeness of bulbs?) then have 60V across them, so that by the end of the circuit the potential was 0. But how does that first bulb 'know' that there is a second bulb to come after it. Why doesn't it simply use up all 120V instead of 'saving' 60v for the second (forgive my inaccurate analogous terminology).
In order to try to get you on a different track thinking-wise I will pose this question: How does a mousetrap 'know' how to catch a mouse?
Simon777 said:
Now if the voltage drop were larger than the voltage the battery provides...
Simon, I think therein lies the problem with your conceptualisation of electricity.
An electrical component that has resistance and is carrying a current will have a voltage drop across it. It is the current flowing through the component and its resistance that defines the voltage drop. All components in a series connection experience the same current through them.
You do not need to know anything more than just the resistance and the current to define the voltage drop. e.g. a 100 Ohm resistor with 1 A running through it will have a voltage drop, V=IR, = 100 V.
Now you might ask what determined the current flowing around a circuit. That's easy, it is determined by the source voltage and the total (summed) resistance., V=IR again, so let's say each of your resistors are 100 Ohms, the bulb is 200 Ohm, and the source is 100 V, so the current, I=V/R, = 100 V/400 Ohm = 0.25 A. You can now inspect each of the resistances with just the 0.25 A current flowing to determine the voltage drop across each. Take the resistors, 100 Ohm x 0.25 A = 25 V.
So you see that the source voltage determines the current, and the sum total of voltage drops across each resistive load must equal the source voltage, by the very definition of the voltage and the current drawn by the load.
I=V[source]/[resistance 1 + resistance 2 + etc..]
voltage drop across resistance X = {I x resistance X}
Sum total of voltage drops = {I x resistance 1} + {I x resistance 2} + {I x etc..} = V[source]
(All this relates to ohmic resistances, not reactive components, like capacitors and inductors, with AC currents .)
So basically, voltage in the components is dependent on the supply which is why it never exceeds or is less than the voltage of the supply when all the voltages of the components are added.
So voltage is the amount of energy packed into 1 coulomb of charge therefore at a given component the energy it contains per 1 coulomb can vary from another component because it has to keep the same current flow, but if resistance is high and it's harder for charge to flow, more energy is needed.
An analogy that helped me think of why current must be the same is thinking of people in line. It doesn't matter how fast a single person moves, they have a person in front of them and a person behind them so they all move in unison and therefore at the same speed. In a series this same logic should apply to the charges moving through it.
Thank you for helping me think this through and understand it better.
I think that there are 0volts at the end of the circuit is tripping me up. Or perhaps in my understanding of current and volts:
I know this is true but how eludes me. I was to understand that with no voltage, you cannot have current. It would be like having a water pipe with no pressure, and therefore no movement. So how is there consistent current (consistent 'speed') throughout a circuit in series if there is no voltage past the last load/resistor.
You need to remember that the DC conditions refer to the steady state - after everything has settled down. At switch-on, an EM pulse travels along / through the circuit and establishes the conditions that will obtain in the long term. The various Potential Differences around the circuit eventually establish themselves. Nothing 'needs to know' what it should do in advance.
(I notice that there are two people asking here.)
Anyway, to settle this one...
The total resistance is 120 ohms so if you drop the voltage to 110 volts the current will drop to 0.9167 amps.
{ 110 volts divided by 120 ohms is 0.9166666 amps }
So the voltage across the lamp will be (I * R) or (0.9167 * 20) or 18.333 volts where it was 20 volts before.
And the voltage across each of the resistors will be 45.833333 volts.
If you add up 18.3333333 + 45.833333 + 45.833333 you get 110 volts.
The power supply doesn't "know" about the individual resistors any more than it would feel guilty about electrocuting you. The total resistance is what determines the total current.
The thing that helped me, and someone correct me if I'm wrong, is that we just ignore all wires otherwise you'd have to think about how the voltage is shared between the components AND all the wires. To calculate how much voltage is in a wire you multiply it's resistance by the current going through it. Wires have such a small resistance though that we ignore them. Think of voltage as a property that pops up because of the current and resistance present instead of thinking it as a separate entity.
The reason for the 0V at the very end is due to the battery, the wire actually has a voltage just like any other component as a result of the current going through it and the resistance of the wire. The battery is like an elevator that takes charges and raises them to a state of higher potential (say 12V if it was a 12V battery). You need this difference in potential to keep the current flowing.
I'm not quite sure if you can say it goes from 0V up to 12V. It goes from whatever voltage it was in the wire touching the battery and is boosted up to 12V if it was a 12V battery. This 12V is only in the battery however and the voltage changes in the wire leaving the battery. The voltage in the wire leaving the battery is determined by the current that goes through it and its resistance. Remember that the current the battery provides is related to the total resistance of the entire circuit. If you have a lot of high resistance components, then the current will be slower. Less total resistance means faster current. Then again, I'm new at physics so don't take my thinking as the absolute truth until others confirm it.
1. What is resistor voltage drop?
Resistor voltage drop is the decrease in voltage that occurs across a resistor in a circuit. It is a result of the resistance of the resistor, which impedes the flow of current and causes a voltage drop.
2. How is resistor voltage drop calculated?
Resistor voltage drop can be calculated using Ohm's law, which states that the voltage drop across a resistor is equal to the current flowing through it multiplied by the resistance of the resistor. This can be represented by the equation V = I * R, where V is the voltage drop, I is the current, and R is the resistance.
3. What factors affect resistor voltage drop?
The main factor that affects resistor voltage drop is the resistance of the resistor. Other factors that can also impact the voltage drop include the current flowing through the resistor, the type of material the resistor is made of, and the temperature of the resistor.
4. How does resistor voltage drop impact a circuit?
Resistor voltage drop can impact a circuit in several ways. It can cause a decrease in the overall voltage of the circuit, which can affect the operation of other components. It can also result in a decrease in current flow, which can impact the performance of the circuit.
5. How can resistor voltage drop be minimized?
To minimize resistor voltage drop, one can use resistors with lower resistance values, which will result in a smaller voltage drop. Additionally, using multiple resistors in parallel can also decrease the overall voltage drop in a circuit. It is also important to consider the power rating of the resistor, as using a resistor with a higher power rating can help reduce the voltage drop.
  • Electrical Engineering
