Can a Simple 80x Telescope Reach Maximum Resolution?
  • Stargazing
  • Thread starter jijopaul
  • Tags
    Telescope
In summary: The simplest, most affordable telescope for maximizing resolution is a refractor. The larger the aperture, the higher the resolution.
jijopaul
what will be the configurations for a simple 80x telescope?
i need to optimize it to the maximum resolution.
Astronomy news on Phys.org
first you need to decide if you want to build a refractor --- lenses only or a
reflector --- mirror and lens ( eyepiece) mix
in general, the larger the f ratio the greater the resolution eg f10 higher res than f5
Dave
I don't think the f-ratio has anything to do with resolution of the image except in the fact that slower f-ratios tend to have less aberrations in the lenses and mirrors since they are curved less sharply than faster f-ratios. Perhaps I'm misunderstanding something, Dave?
First there are no "simple telescopes" that can maximize resolution so it's not possible to answer your question. There is also no such thing as a 80x telescopes except in the promotional material of entirely useless garbage telescopes (although then you are more likely to see 600x). We could help better if you explain more thoroughly what you are trying to do. This includes among other things:
* What is the purpose of this telescope?
* Are you going to make it yourself?
* What is your experience with using telescopes?
You are quite right. The only truly important thing is aperture, the rest is just details in comparison. Important details mind but details nevertheless.
Unless you are an expert at optical figuring and testing, a refractor is a near impossible challenge for a fledgling ATM. Nor is it cheap. High quality optical glass is difficult and expensive to obtain, and you have multiple surfaces that require coatings - also not inexpensive.
Building your own scope to perform well at 80X is trivial. The easiest way to start is with a refractor, IMO. Newtonians might be a little cheaper but not much in the smaller size scopes and they are fairly complicated to build since you need to fold the lightpath at a right angle. Two mirrors, each attached to an adjustable base and aligning all this with a focuser mounted to a tube at just the right distance from the end. Not extremely difficult but certainly harder than mounting the focuser one end of the tube and the objective on the other!
I've built several refractor telescopes. I currently use an 80mm f15 that makes 80 power with a 10mm eyepiece. This gives an exit pupil of 1mm which is fairly comfortable and the large f-ratio helps minimize chromatic aberration. With a light yellow filter it's almost a planet killer for not much money. I bought the objective and adjustable cell used for about $150 and mounted it in 4" PVC from Home Depot. Painted the inside with flat black and fitted it with a spare crayford focuser I had left over from a donor scope. It's great at high powers and handles 80X easily.
I have another 60mm f16.7 telescope I built entirely from parts I purchased online. $20 for the objective and cell, $15 for the threaded tube and $99 for the Crawmach crayford focuser. It's my favorite grab and go scope which I use at every public star party I attend.
Finally, I've just finished a 127mm Surplus Shed f9.4 refractor made from an objective/cell I purchased for $150 (now it's $210) a tube from Hastings Irrigation ($75 delivered for the 6" tube and 7" dew shield) and an old Jaegers focuser I've had for some time. It performs great at 80X with a 15mm eyepiece and the 1.8 mm exit pupil at that mag is very comfortable to use.
It's some money, but not a lot. Of course, if you think that anything like $135 is a lot of money for a telescope, it's expensive! And the prices I've outlined are for the optical tube only... you still need a mount and some way to attach the OTA to it. It too can be done cheaply... build a pipe mount from some 1-2" metal threaded pipe and fittings and a little wood and hose clamps. Used gear can be employed if you prefer. It seems that someone is always wanting to sell off their old gear when they upgrade.
Here is a step by step build for a 127mm telescope. Here is one for a 60mm f16.7.
Likes 1 person
I should have commented on aperture as being significant larger aperture higher resolution
but still in scopes I own and scopes I have used, I have always seen a sharper image/better resolution in a hi f ratio scope eg my 2 scopes 10" f4.5 and my 9.25 " f 10
for splitting double stars and planetary features the f10 blows the f4.5 out of the water
I can only go by years of observations :wink:
Dave
I agree with you Dave. It's been my experience that longer focal lengths give better resolution but only when you compare radically different focal lengths like you have at 4.5 vs. 10. But f6 vs f8? That's more dependent on aperture and quality. Quality probably more than anything.
So, you are saying a home made refractor is an easy project? I disagree.
Well not if you're grinding the lenses yourself or something...
yup, close ratios, aperture reigns, I agree with you :)
DAve
I'm going to make it myself. I haven't got any experience in making telescopes. Refracting is prefered
Just wanted to thank you for those links. Those are beautiful. The second one appears it may be using a modified Surveyors stand. Do you know if this is so? or that it is a workable solution?
There is nothing simple about making a refractor primary. You have two surfaces to grind and polish for each lens and you need no less than two lenses to construct a useful primary. That is a lot of grinding and polishing, and, I haven't even addressed test stand issues. You also end up with four surfaces that need coated. Its no accident large refractor primaries are expensive.
Back in seventies there was a hobbyist club in Warsaw where they were grinding manually their own mirrors for Newtonian telescopes. I believe their estimates were around 2000 hours of work for the 150 mm telescope (but I admit I am not sure if it was just grinding, or everything combined). Eyepieces were bought separately, mirrors were sent for coating in some industrial settings.
Technically process is not that complicated, if memory serves me well number of scopes they made was counted in hundreds. And from what I see there are tutorials on the web. I am far from saying it is trivial, but it is definitely a possible DIY project.
Chemisttree is clearly talking about buying the lenses, not making them:
" I bought the objective and adjustable cell used for about $150 and mounted it in 4" PVC from Home Depot."
Dave
Not quite.. the grater the apature the higher the resolution up to about 12" then atmospheric disterbances blur the image so much that hight apatures beyond 12" doesn't make much difference, image just gets brighter. increased f ration equals high magnification for the same eye piece. magnification = f ration devided by eye-piece focal length
building a simple acromatic refractor cheap
for an entry level telescope and a first build scope. you build a 3" refractor for under $100. first you will need to log onto the Suplus Shed and look up telescopes. perchase an 80mm(3.1") acromatic lens. focal length is 900mm (Item No: L3002 Price: $39.00 ) I've used thens lenses myself and the are great value. this is about an f11. then buy a 80mm focuser (Item No: L3630
Price: $17.95 ) this is a basic mostly plastic focuser. it takes the standard 1.25mm eyepieces. now to get 80x you will need about a 12mm eye-piece. this one is a kilner 12.5mm eye-piece(Item No: L14426 Price: $11.00) then get a length of 90mm pvc pipe (from home depot or were ever) the 80mm focuser fits exactly into this. unfortunatly the objective lens housing doesn't, so you need to also buy a 100mm to 90mm adapter and a coupler.(about $10). I lined the pipe with a piece of black velvet, this seemed to work quite well on my 4" scope and is resonably cheap and easyier than painting it. now you put all of that together and use small pk screws as gruber screws to hold it all together. and you should have a resonable 3" f11 refractor for about $85
email me and I can send you some more detailed build informtion with fotos.
I hand ground an 8 inch Newtonian for a college physics project. Definitely a lot of of hard work. Afterward, I took it to the Adler Planetarium in Chicago where they put the coating on.
the refractor that i mentioned above i have just finished building today. gets quite good results. grinding a mirror to much hassel for me. and if it is your first build and you don't have many tools. for he scope above, sofar i have only used a hacksaw.
1. How does the resolution of a telescope affect its ability to view objects?
The resolution of a telescope refers to its ability to distinguish between two closely spaced objects. A higher resolution means that the telescope can see finer details and smaller objects.
2. Can a simple 80x telescope reach maximum resolution?
No, an 80x telescope cannot reach maximum resolution. The maximum resolution of a telescope is determined by its aperture or lens diameter. A larger aperture allows for higher resolution, and an 80x telescope typically has a smaller aperture compared to more advanced telescopes.
3. What are the factors that affect the resolution of a telescope?
The resolution of a telescope is affected by its aperture, atmospheric conditions, and the quality of its optics. A larger aperture allows for higher resolution, while atmospheric conditions such as turbulence can decrease resolution. Additionally, the quality of the telescope's optics, such as the precision of its lenses, can also impact resolution.
4. Can a simple 80x telescope still provide clear and detailed images?
Yes, an 80x telescope can provide clear and detailed images, but it may not have the same level of detail as more advanced telescopes with larger apertures. The quality of the optics and atmospheric conditions also play a role in the clarity of the images produced by the telescope.
5. Is it possible to improve the resolution of a simple 80x telescope?
Yes, it is possible to improve the resolution of an 80x telescope by using additional tools such as eyepieces with different magnifications or a Barlow lens. However, the maximum resolution of the telescope will still be limited by its aperture.
  • Astronomy and Astrophysics
