Register to reply
Sound wave attenuation
by silversurf
Tags: attenuation, sound, wave
Share this thread:
silversurf
#1
Nov27-13, 01:08 PM
P: 26
Why does water attenuate sound waves more than air? Is it because of it's bulk modulus? This is what I understand. Speed through a medium is determined by the elastic component over the inertial component. Since water has a much greater bulk modulus (elastic component) than air, it makes the wave travel faster in water. What I don't understand is how is it that the speed is faster yet it's attenuation is also greater. Since a sound wave travels faster through water than air shouldn't it also be more resistant to attenuation?
Phys.Org News Partner Physics news on Phys.org
Step lightly: All-optical transistor triggered by single photon promises advances in quantum applications
The unifying framework of symmetry reveals properties of a broad range of physical systems
What time is it in the universe?
davenn
#2
Nov27-13, 03:45 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,651
hi silversurf
you are coming from an incorrect assumption
attenuation of sound in water is much less than in air for a given freq
here's just one example from some tables
Attn in Air dB/km @ 1kHz = 14dB/km @ 10% RH; 5.3 dB/km @ 90% RH ( Relative Humidity)
Attn in seawater dB/km @ 1kHz = 0.07 dB/ km @ 0 deg C 0.05 dB/km @ 30 deg C
http://www.kayelaby.npl.co.uk/genera...2_4/2_4_1.html
hence why whale song can be heard over huge distances
cheers
Dave
tiny-tim
#3
Nov27-13, 03:49 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
Quote Quote by davenn View Post
that's why the whales left the land, to live in the water!
davenn
#4
Nov27-13, 04:08 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,651
Quote Quote by tiny-tim View Post
haha
D
sophiecentaur
#5
Nov27-13, 05:38 PM
Sci Advisor
Thanks
PF Gold
sophiecentaur's Avatar
P: 12,185
Quote Quote by silversurf View Post
It is true that water attenuates the level of sound that you can hear, when you are immersed in water. This is not due to losses in the transmission through the water but in how well the sound power is matched from the source into the water medium and then how well it is matched to your ears.
You mention modulus. This (and the density), affects the impedance of sound waves in a medium (high in water and low in air). Your ears evolved to match sound in air, using very flimsy diaphragms and tiny levers (the ossicles). The displacement in air (for a given power level) is much greater than that in water and the movement at the entrance to the cochlea will be very much less for waterborne sound. I imagine that dolphins have a similar problem hearing sound when they are out in the air - for the converse reason.
Register to reply
Related Discussions
Sound attenuation barrier height (trigonometry) Precalculus Mathematics Homework 2
Electromagnetic wave attenuation Classical Physics 17
Question about sound attenuation or absorption General Physics 0
Sound attenuation Introductory Physics Homework 1
Sound attenuation General Physics 2
