Alternate ways to show a line is a tangent to a curve
In summary, the conversation is discussing how to prove that the line x+2y=7 is a tangent to the circle x^2+y^2-4x-1=0 and whether there are any other methods besides showing that there is only one point of intersection. Some suggested methods include using calculus to show that the line and the tangent line at the single intersection point are one and the same, or showing that the line is perpendicular to a radius and has a distance equal to the circle's radius from the center. However, it is agreed that the most efficient way to prove the line is a tangent is by showing that there is only one point of intersection.
rock.freak667
6,223
31
Show that [itex]x+2y=7[/itex] is a tangent to the circle [itex]x^2+y^2-4x-1=0[/itex]
One way would be to solve simultaneously by substituting for x or y and getting a perfect square showing that there is only one point of intersection. Is there any other way to do this? I was thinking about the idea that the angle made by a tangent and a radius is 90 degrees and that the product of the gradients of perpendicular lines is -1. Are such thoughts correct ones?
With calculus you can show that the given line and the line tangent to the circle at the single intersection point are one and the same. But all you need to do is prove that there is only one intersection
Yes they are, however all you are showing is that the straight line is perpendicular to a radius, you arent showing if it actually touches the circle or not, and if it does, how many points.
So there is no other way to show it is a tangent than only showing that there is only one point of intersection?
You could also show that the distance to the line on a line from the center of the circle that is normal to your line has length equal to the radius of the circle. But that's the same thing as showing there is only one intersection and takes a lot more words to express.
1. What is a tangent line?
A tangent line is a line that touches a curve at only one point, and has the same slope as the curve at that point.
2. How do you determine if a line is a tangent to a curve?
A line is a tangent to a curve if it touches the curve at only one point and has the same slope as the curve at that point. This can be determined by graphing the line and the curve and visually inspecting the point of intersection, or by using calculus to find the derivative of the curve and evaluating it at the point of intersection.
3. Are there different ways to show that a line is a tangent to a curve?
Yes, there are different ways to show that a line is a tangent to a curve. One way is to graph the line and the curve and visually inspect the point of intersection. Another way is to use calculus to find the derivative of the curve and evaluate it at the point of intersection. Additionally, you can use the Pythagorean theorem to show that the distance between the point of intersection and the curve approaches zero as the two points get closer together.
4. Can a line be a tangent to a curve at more than one point?
No, a line can only be a tangent to a curve at one point. A line that touches a curve at more than one point is called a secant line.
5. Why is it important to identify tangent lines to curves?
Identifying tangent lines to curves is important in many fields of science and mathematics. In physics, for example, tangent lines to position-time graphs represent instantaneous velocity. In engineering, tangent lines to curves represent the slope of a graph and can be used to analyze the behavior of a system. In mathematics, tangent lines are used to approximate the behavior of a curve and are essential in the study of derivatives.
  • Calculus
