Myelin increases resistance across the cell membrane
In summary, myelin significantly increases resistance across the cell membrane and decreases capacitance, resulting in a 5,000-fold increase in resistance and a 50-fold decrease in capacitance. This decrease in capacitance can be explained by the myelin sheath wrapping around the neuron multiple times, acting as a series of capacitors. This also explains why myelin speeds up the action potential, as it only occurs at the nodes of Ranvier where the myelin sheath is absent and the full depolarization can take place. De-myelination can significantly decrease the speed of the action potential and can only be observed in pathological conditions.
  • #36
http://sfbay.craigslist.org/forums/?act=Q&ID=102572102
Biology news on Phys.org
  • #37
somasimple said:
50 turns of myelin (50*d) and a length that is 2000 time longer (2000*A). :zzz:
Yes, myelin allows the total capacitance of an internode and a node to be roughly the same even though the internode is ~1000 longer than the node.
  • #38
somasimple said:
DaleSpam,
Give the results in our example.
Your question is rather ambiguous the way it is worded. Length of what? What "result" are you asking to have explained?
  • #39
A visual perhaps?
Time constant for internode is, at least, 120 longer in that case.
  • #40
You're right. Normally a cylindrical capacitor must be computed that way but biologists do not.
http://butler.cc.tut.fi/~malmivuo/bem/bembook/21/21.htm [Broken]
It does not change the length segment problem.
  • #41
somasimple said:
A visual perhaps?
Time constant~RC, so if you include R (membrane resistance)?
  • #42
  • #44
Are you serious?
I do not contest... numbers.
  • #45
somasimple said:
Are you serious?
Yes - but only "same order of magnitude" - Koch: Even though the length of the interaxial node is typically 1000 times larger than the node, its total capacitance has the same order of magnitude.
But Koch is talking about the frog axon: made up of 250 myelin layers
  • #46
Someone is wrong: Is it Mathematics or Pr C Koch?:redface:
Edit: 250 turns does not change anything since 250 < 1000
  • #47
Order of magnitude means correct to within a factor of <10 (I usually think ~3-4)
So I think we need better numbers, and from the same species - not some squid, some frog, and some rabbit ...
Edit: not squid - that's not myelinated :redface:
  • #48
But Rm varies inversely to Cm and they are linked...
You may test a simple linear function:
Rm=f(C)=-a(C)+b
  • #49
Rm=f(C)=-a(C)+b
Yes, that's why I said:
atyy said:
Edit: But there is something very fishy with this explanation. Time constant Tm~RmCm. What's the point of decreasing Cm, but increasing Rm by the same amount?
Edit: Another part of the puzzle. Space constant Lm~Rm/Ra
There are other equations in Koch's book where Cm enters, for example in the frequency-dependent length constant, but it always enters in the combination RmCm, so if the primary job of myelin is to change capacitance, I don't see how it affects anything.
That's why I was thinking about the length constant (frequency-independent component) ~Rm/Ra, where Ra is the axial resistance. The length constant determines how signals decay over distance, so to conduct in the internode where sodium channels are low, and signals cannot be actively boosted, the length constant has to be increased, perhaps by increasing Rm with myelination. Unfortunately, this increases the time constant ~RmCm - unless you decrease the capacitance by the same amount, which I think myelin does. However, most expositions do not feature the length constant, and they also say that the job of myelin is to increase the time constant, not to keep it the same. So I don't understand what's going on.
  • #50
If you reject Cm then you reject the whole theory...
I do... but I can't say anything on this site without being thunder lightened by modos.
  • #51
Yes, and no. I think the decrease in Cm is required to offset the increase in Rm, so that the time constant remains the same. There are no outright contradictions between what I'm saying and the standard explanations. BUT there are enough differences in emphasis that I should look at the equations carefully and see whether the apparent lack of contradiction between the two explanations is due to a real similarity in the underlying mathematics, or just due to chance. But those details are not in Koch's book.
Maybe to be careful, you should say "at least one modo (singular)". :rofl:
  • #52
I can't. It is out of my capacitance and resistance.:rofl:
  • #53
:rofl::rofl::rofl:
  • #54
with the function:
The minimal value found with 250 turns is a Time Constant that is multiplied by a factor 20.
the worst is... 1250
  • Biology and Medical
  • Electrical Engineering
  • Electromagnetism
9K
20K
44K
