Kreat-Impulse
- 1
1. This problem is part of an engineering model I am working on for a class. I am ultimately trying to model the torque applied to a bottle as a function of the static/kinetic coefficient of friction between it and the rubber cone it is being torqued by (The reason for this being bottle caps and jar lids are not all made of the same material, so the c.o.f. will change)
The rubber cone is glued to a gear connected to the pawl of a ratchet configured for a 4:1 mechanical advantage. For every time a force is applied to the ratchet, there will be an impulse generated on the gear and thus the rubber cone causing it to turn and producing friction between it and the bottle cap (which will hopefully, or theoretically, turn the bottle cap).
My question is how to calculate this frictional moment.
2. Torque is given by Tau=Force x Radius=I x alpha
where I is the moment of inertia of (in this case) the center of mass, and alpha is the angular acceleration.
The applied force to the ratchet (and thus the torque), the surface area of contact between the cone and the bottle cap, the dimensions, mass, and inertial properties of the cone and bottle cap are all known. The variable is the coefficient of friction.
3. My guess would be that you would integrate the Torque over the surface area of contact and multiply that by the coefficient of friction.
In the end my frictional moment looks like:
M(f) = (mu)*tau*A = (mu)*F*r*pi*d*t
where mu is the c.o.f., F is the force applied to the ratchet, r is the radius of the gear glued to the cone, d is the diameter of the bottle cap, and t is the width of the surface contact area.
Thanks for you input.
Kreat-Impulse
Kreat-Impulse
