Understanding Time Dilation in Einstein's Special Theory of Relativity
In summary, Einstein's section 4 of special theory discusses the concept of time dilation and its effects on two synchronous clocks. He states that if one of the clocks is moved in a closed curve with constant velocity and then returned to its original position, it will be slower by a small amount compared to the stationary clock. This means that a clock at the equator, due to its constant motion, will tick over at a slower rate than a clock at the pole. This concept is further supported by the example of an astronaut making an out-and-return trip into space. Therefore, it can be concluded that the clock in motion will experience time dilation relative to the stationary clock.
  • #141
cos said:
I believe that to be a correct assumption. My interpretation of what is 'real' or 'physical' or 'actual' or 'normal' is what takes place in an observer's reference frame not what appears to be taking place from the point of view of a person who is moving relative to that reference frame i.e. a point of view that is frame dependent.
Isn't this second person also "an observer", so isn't what they measure in fact "what takes place in an observer's reference frame"? (this point is independent of the other point that you refuse to discuss, namely that there is no need to have a physical observer actually at rest in a given frame in order to consider how things look from the perspective of that frame, and that in SR this perspective is just as valid as the perspective of any other frame).
cos said:
There is NO reciprocal time dilation IN Einstein's section 4!
His equatorial clock 'goes more slowly' (i.e. ticks over at a slower rate) than the polar clock! The polar clock does not, reciprocally, 'go more slowly' than the equatorial clock!
As has been discussed, that's probably because he was talking about total time elapsed over an entire orbit. Unless Einstein wished to deny the selfsame theory he had set out in sections 1-3 (which would be a silly way to read him), of course he would not deny that at a given instant, the polar clock ticks more slowly than the equatorial clock in the instantaneous inertial rest frame of the equatorial clock at that instant.
cos said:
Einstein's closed curve section 4 depiction could be applied to one observer (A) stationary alongside and some distance from B.
A accelerates and, continually firing his lateral rocket, moves in a closed curve around B and, having extinguished his main drive system, is then orbiting B at v.
In that section Einstein also discusses the simpler example where A and B are initially at rest with respect to one another, then A is moved at constant velocity (i.e. constant speed in a straight line rather than a curve) towards B. Why aren't you willing to consider things from the perspective of A's inertial rest frame during the phase where A is moving towards B? Is A not an inertial observer?
  • #142
So, do I understand this correctly? If A and B are in relative motion you would describe A in terms of A's rest frame and B in terms of B's rest frame and call that "real" etc. Any description of A from B's rest frame or B from A's rest frame would be "illusion" etc. Is that correct?
I assume this is correct in the case where A and B are both inertial observers, but what about non-inertial observers? You didn't seem to like non-inertial frames earlier, so would you hold to the same definition of "real" in the case that one or both of A and B are non-inertial?
  • #143
Jesse; re: post 136
In your scenario, there is a C rest frame in which A and B, separated by 60 ls (light seconds), are moving to the right at .6c, with A in the lead. A changes to zero speed in the C frame ( change made arbitrarily brief and ignored). A's clock reads t. At a previous time, using the synchronization convention of sending a signal from half the distance between A and B to both, the B clock is ahead of the A clock by xbg = 45 sec, with x=60,b=.6, g=1.25.
The separation x is not 48 because when both were moving at .6c, they were equivalent to one object, therefore as long as each has the same velocity, their spacing is constant at 60 ls. That is their rest frame spacing, and is what they would measure at any other common speed. Only outside observers measure the separation between them differently.
(This is where you recite postulate 1.)
A's clock now reads t, B's clock reads t+45.
Now is when A and B see the spacing differently, because of the speed difference.
A sees B move to him in 60/.6 = 100 sec.
Because of time dilation, B's clock advances .8*100 = 80 sec.
A's clock now reads t+100, B's clock reads t+125.
The clock that experiences the least amount of time is not the one with the smallest reading, but the one with the longest path.
"Third"? I only mentioned two frames:
According to the relativity police, when both A and B move at .6c, it must be in reference to a specific frame! Follow your own rules!
In defense of cos, your responses are long and cluttered, with side excursions to things that aren't relevant to the original question, and are actually distracting. Post 1, was a simple example with two clocks at one (approx.) location, with one moving away and returning. The question was essentially, can Einstein's statement about the time difference be taken literally.
There was no question regarding other frames or what ifs. When people ask basic questions, they need answers in terms they can understand, not a course in 4-dimensional donut theory.
Referring to post 1:
If it isn't obvious that one clock is moving relatively to the other (no other clocks are mentioned), and the difference in time readings is attributed to the motion of the 'moving' clock, and Einstein is not known to lie about scientific experimentation, then there's a problem with comprehension, and getting meaning from the context of the writing.
If I offer you $1000, and deliver it in 100's, would you reject it just because you were expecting it in 50's?
I still recommend a good dictionary as your first information source.
  • #144
In the thread "Twin paradox negation" at the end of 2008 the original discussion deteriorated into the present discussion regarding section 4 clocks. It was eventually locked by jtbell in #220 with the words
------It looks like neither side is going to budge and the participants are simply getting testier and testier, so there is no useful purpose in continuing this discussion. -------
Matheinste.
  • #145
phyti said:
Jesse; re: post 136
No, I specified that A and B had an initial separation of 60 ls in frame #1 where they were initially at rest before A accelerated (read post #64 again, where I said 'Suppose for example A and B are a distance of 60 light-seconds apart in the "stationary" frame K', which Einstein had defined as the frame where A and B were initially at rest). In frame #2 where A and B are initially moving at 0.6c, the initial separation between them is not 60 ls, it is 48 light-seconds, due to length contraction.
No, if the two clocks were synchronized using the Einstein synchronization convention in the frame #1 where they were at rest, then in the frame where they are both moving at 0.6c, they will be out-of-sync by 36 seconds. Where do you get the idea that they will be out-of-sync by xbg? Maybe this relates to your misunderstanding about which frame they are 60 light-seconds apart in--it's true that if two clocks were a distance of x apart in the frame where they are moving at speed b, and the clocks are synchronized in their own rest frame, then in the frame where they're moving at speed b they'll be out-of-sync by xbg/c^2 (and we're using units where c=1 here). However, if two clocks are a distance of x apart in their own rest frame, and they are synchronized in their rest frame, then in a frame where they're moving at speed b they'll be out-of-sync by xb/c^2, and again I had specified that the 60 light-second separation was in their own rest frame. You can verify that xb/c^2 is the correct formula in this case using the Lorentz transformation. Suppose that in frame #1, A is at rest at position x=0 before accelerating, and B is at rest at position x=60. A accelerates at time t=0, and at that moment A reads 0 seconds and B reads 0 seconds. As long as each clock is at rest its reading matches with coordinate time; for example, at coordinate time t=-10, A reads -10 seconds and B reads -10 seconds. After A accelerates to 0.6c, its reading no longer matches with coordinate time in this frame, but B's continues to do so since it remains at rest; at t=10 seconds B reads 10 seconds, and at t=36 seconds B reads 36 seconds.
So, the event of B reading 36 seconds happens at position x=60, time t=36 in this frame, while the event of A reading 0 seconds (and instantaneously accelerating) happens at x=0, t=0 in this frame. Now we transform to frame #2 which is moving at 0.6c relative to frame #1; in this frame A and B were initially moving at 0.6c in the -x' direction, then A came to rest while B continued to move at the same speed and eventually caught up with A. If we know the coordinates x,t of an event in frame #1 and we want to know the coordinates x',t' of the same event in frame #2, then with gamma = 1.25, the Lorentz transformation equations are:
x' = 1.25 * (x - 0.6c*t)
t' = 1.25 * (t - 0.6c*x/c^2)
If you plug in x=0 and t=0 into this transformation, for the event of A reading 0 seconds and accelerating, you get x'=0 and t'=0 in frame #2. Now plug in the event of B reading 36 seconds, which has coordinates x=60 and t=36 in frame #1. This gives:
x' = 1.25 * (60 - 0.6*36) = 1.25 * (60 - 21.6) = 1.25 * 38.4 = 48
t' = 1.25 * (36 - 0.6*60) = 1.25 * (36 - 36) = 0
So, you can see that the event of B reading 36 seconds happens at t'=0 in this frame, and is thus simultaneous with the event of A reading 0 seconds which also happens at t'=0 in this frame. And you can also see that the spatial separation between A and B at this moment is 48 light-seconds in this frame.
We could also show that at any moment prior to A's acceleration, it's still true in this frame #2 that B is 36 seconds ahead and that the two clocks are 48 light-seconds apart. For example, consider the event of A reading -100 seconds, which in the unprimed frame #1 happens at x=0 and t=-100. In the primed frame #2 the coordinates of this event are:
x' = 1.25 * (0 - 0.6*-100) = 1.25 * (60) = 75
t' = 1.25 * (-100 - 0.6*0) = 1.25 * (-100) = -125
I claim that in frame #2, this event is simultaneous with the event of B reading -64 seconds. In the unprimed frame #1, B reads -64 seconds at x=60, t=-64, so in the primed frame #2 the coordinates of this event are:
x' = 1.25 * (60 - 0.6*-64) = 1.25 * (60 + 38.4) = 1.25 * (98.4) = 123
t' = 1.25 * (-64 - 0.6*60) = 1.25 * (-64 - 36) = 1.25 * (-100) = -125
So you can see that in frame #2 these events are indeed simultaneous, since they both happen at t'=-125. You can also see that the distance between A and B at this moment is 123 - 75 = 48 light-seconds, just as before.
The frame where both are moving at 0.6c is by definition not their "rest frame"! I specified that they had a separation of 60 light-seconds in the frame #1 where they were both initially at rest until A accelerated. This means that in the frame #2 where they were both moving at 0.6c until A accelerated, their separation is 48 light-seconds. Either you just misunderstood what frame the 60 light-second figure was supposed to refer to, or you are misunderstanding something more basic about the term "rest frame" and how length in the rest frame is related to length in other frames by the length contraction equation.
1) the frame where A and B were initially at rest, then after A accelerated it was moving at 0.6c while B remained at rest
2) the frame where A and B were initially moving at 0.6c, then after A accelerated it came to rest while B continued to move at 0.6c
Of course it's in reference to a specific frame, the second of the two frames I mentioned--that's the primed frame #2 in the Lorentz transformation above, and also the one I put in bold in the quote from the previous post. So what is the third frame that you think is needed? Perhaps you are suggesting there needs to be a third object C which is at rest in frame #2...but this would be the same mistake cos made, in SR there is absolutely no need to have an object at rest in a given frame in order to analyze things from the perspective of that frame, a "frame" is just a coordinate system for assigning space and time coordinates to events. In any case, even if we do introduce an object C which is at rest in frame #2, there are still only two inertial frames to consider, because A and B would share the same inertial rest frame before A accelerated, and A and C would share the same inertial rest frame after A accelerated.
But his whole question is about where there is a real physical truth about which clock is "actually" ticking slower at a given moment. I specifically mentioned that of course there was a real physical truth about which clock ticked more in total over the course of the two clocks departing and returning, but he made clear that he did not just want to talk about total time elapsed or average rate of ticking over the course of an extended trip, he wanted to talk about the relative rate of ticking at a single instant or a very brief time-interval. And if he doesn't understand that there is no single correct answer to the question of which clock is ticking slower at a given instant--that different inertial frames disagree about which is ticking slower at a given instant (because they disagree about which clock has a greater instantaneous velocity at that instant), and that all frames' perspectives are considered equally valid, and that to try to say there's a single correct answer is equivalent to introducing some notion of absolute time, which is the opposite of what relativity says. So, I think bringing up different frames is pretty critical to making sure he's not misunderstanding something very basic about SR.
Again, if you read cos' subsequent posts, it's clear he's not just talking about total time elapsed on each clock, he wants to talk about whether we can say one clock is ticking slower at any given moment. And the answer in relativity is "not in any frame-independent sense; different frames have different opinions about which clock is ticking slower at a given moment, and all inertial frames are considered equally valid in SR."
  • #146
cos said:
Einstein was, in my opinion, stating that the equatorial clock "..must go more slowly..." than the polar clock (i.e. that the equatorial clock is ticking over at a slower rate than the polar clock) on the basis that the equatorial clock is moving relative to the 'stationary' (in an otherwise empty universe) polar clock in the same way as the clocks aboard the aircraft in the Hafele-Keating experiment were 'going more slowly' (i.e. ticking over at a slower rate) than the laboratory clocks.
Right, assuming we ignore gravity.
OK, you're simply using a definition of "real" that others on this forum do not. No problem.
Right, because the equatorial clock does not stay in a single inertial frame. The standard time dilation equations can't be used in the non-inertial frame that the equatorial clock remains at rest in.
Not if we're still ignoring gravity. Without gravity, A would have to continuously fire his rocket in order to maintain a circular path around B.
From B's point of view A is moving (thus incurring time dilation) but from A's point of view B is not moving! (B could be spinning on it's axis thereby consistently presenting its face to A whereupon A determines that B is not moving whilst he, on the other hand experiencing g forces determines that he is centripetally accelerating).
B has, from A's point of view, remained at rest as Einstein stipulated he does.
Well, notice that in the non-inertial frame that A is at rest in while circling B, the relative velocity between the two clocks is zero. Both clocks are stationary with respect to this rotating reference frame.
This would be similar to a spinning wheel in deep space with negligible gravity, and a clock in the center, and a clock attached to the rim. If we're referring to the non-inertial reference frame in which the "rim" clock is at rest, then there is no relative motion between the clocks. Both clocks are at rest in this frame. The standard SR time dilation equations can't be used. This doesn't mean there is no time dilation, it just means that you can't use the standard SR equations to analyze non-inertial reference frames. We could use the gravitational time dilation equations to calculate the difference in the rates of each clock in this frame, and we'd get the same answer as we would by considering the center clock at rest in an inertial frame and the circling clock as in relative motion. That's no coincidence.
An (accelerating) observer at rest with and local to the circling clock would observe the center clock to run faster than his own, since he is accelerating toward the center clock continuously.
  • #147
Al68 said:
Right...
Having made the comment "Right" can I take it that you agree that an equatorial clock is ticking over at a slower rate than a polar clock ("...under otherwise identical conditions.")?
We have a large wheel in space that, initially, is not spinning; ignoring any effects of the wheel's mass a clock at the center would be ticking over at the same rate as an identical clock at the rim.
The wheel starts spinning. According to Einstein's section 4 depiction - the rim clock (A) that is now moving around the central clock (B) is then 'going more slowly' (i.e. ticking over at a slower rate) than B which has, according to Einstein, remained at rest.
An observer located at the center of the wheel sees clock A ticking over at a slower rate than his own clock (and, obviously, at a slower rate than it was before the wheel started spinning).
Having read and accepted Einstein's section 4 STR depiction of a clock that is made to move in a closed curve relative to another clock (and which will, as a result, incur time dilation relative to the 'at rest' clock) observer B realizes that clock A is ticking over at a slower rate than it was before the wheel started spinning due to the fact that it is now moving whilst he has remained at rest.
I am of the opinion that observer B could be aware of the fact that if he were to move to the rim of this wheel his own clock would then also be ticking over at a slower rate than it is whilst he remains at the center of the wheel; that the 'law' of physics that caused A to start ticking over at a faster rate than it was before the wheel started spinning will also apply to his clock.
I am of the opinion that he does not "observe the center clock to run faster than his own, [because] he is accelerating toward the center clock continuously." but he observes the central clock to be running faster than his own clock for the simple reason that it, having remained at rest, is physically ticking over at a faster rate than his own clock.
The observer I depicted moves to the rim thus then sees the clock at the center of the wheel ticking over at a faster rate than his own clock however on the basis that he can find no reason whatsoever as to why that clock would now be ticking over at a faster rate than it was before he moved to the rim of the wheel he can only(sensibly) conclude that his clock has slowed down in the same way as did clock A when the wheel started spinning.
He should be able to realize that the 'law' of physics that caused clock A to start ticking over at a slower rate when the wheel started spinning applies equally to his clock - his reference frame.
He is unable to carry out any experiment to confirm that his clock is ticking over at a slower rate than it was prior to his relocation - his heart-beat has also slowed down as have his mental processes however his intelligence has (presumably; hopefully) not been impaired.
  • #148
Note to Al68: keep in mind that cos seems to be trying to lead people into saying that the equatorial clock is ticking slower at every instant, not just over the course of an entire orbit, and not just visually when an observer next to one of the clocks looks at the other. I'm sure you'd agree that at any given moment, we can pick an inertial frame where the equatorial clock's instantaneous velocity is smaller than the polar clock's, and that it would therefore be the polar clock that is ticking slower at this moment in this frame (which is just as good as any other inertial frame).
  • #149
cos
The complication in considering rotating frames is that this is an advanced topic in special relativity, halfway towards the mathematics of general relativity.
I'm going to modify your scenario slightly and consider a wheel rolling along a road. As always we ignore gravity.
Clock A is fixed to the wheel rim.
Clock B is fixed to the wheel centre.
Clock C is fixed to the road.
If the wheel is stationary, all 3 clocks agree that they are ticking at the same rate as each other. Now let the wheel roll.
We consider what is happening just at the moment that the wheel rolls over clock C in such a way that clocks A and C are momentarily at the same place.
From the point of view of inertial clock B, A and C are both ticking at the same rate as each other, both slower than B.
From the point of view of inertial clock C, A is ticking at the same rate as C, B is ticking slower than A and C.
From the point of view of accelerating clock A, C is ticking at the same rate as A, B is ticking faster than A and C.
Now how do you explain those 3 points of view in terms of "physically ticking", whatever that means?
  • #150
Yes, in the rest frame of the polar clock, and in the accelerated frame of the equatorial clock, if we ignore gravity. Note again that this is not standard time dilation between inertial frames. Both clocks are stationary in the "rotating" reference frame. Relative velocity between the clocks is zero in this frame.
That's right.
Yes.
Yes, in the center observers rest frame. But not for an observer stationary at clock A. In his non-inertial frame, clock A runs at the same rate it always did, and the center clock B started running at a faster rate when the wheel started spinning.
Yes, if you're referring to the inertial frame in which clock B is spinning, and clock A is in relative motion. If you're referring to the rotating reference frame in which both clocks are stationary after the wheel starts spinning, then the difference in clock rates is not due to relative motion, since there is none. In the rotating frame, the difference in clock rates is due to proper acceleration. This is simply a matter of which perspective you choose, the result is the same.
No single clock changes its own rate in its own rest frame ever. If it does, then it doesn't qualify as a good time keeper in SR. That being said, if clock B were moved to the rim, it would run slow relative to a third clock "C" that was at the center and remained there.
In the frame of clock A, both clocks are at rest. Both clocks are stationary in the accelerated frame of clock A.
He has plenty of basis. He is no longer in an inertial frame. He can't use the standard time dilation equations in his frame. Light doesn't even travel at c in his accelerated reference frame. The standard lorentz transformations do not apply in this frame. He can prove to himself that he is not at rest in an inertial frame by the simple fact that if he releases his clock into freefall it will not stay near him. The clock must be accelerated to stay in the frame.
Again, any clock that changes its own rate in its own frame does not qualify as a valid clock in SR.
Well, his heartrate may very well be different under different circumstances. But if he has a watch that chimes every hour according to his clock A before the wheel started spinning, it will chime every hour according to clock A afterward as well.
  • #151
Hi JesseM,
Sure, but if I understand cos correctly, he wants to analyze things from the accelerated rest frame of the equatorial clock, ignoring gravity. Basically the one reference frame in which both clocks are stationary.
  • #152
In all 3 of those points of view the word "physically" can be placed in front of every "ticking".
On the basis that the wheel is initially at rest then starts rolling along the road your clock C is then Einstein's section 4 STR clock B (to differentiate let's call his clock B') which remains at rest whilst your clock B (Einstein's A') ticks over at a slower rate than it did before it accelerated ergo your clock C (Einstein's B') ticks over at a faster rate than your clock B (Einstein's A') not at a slower rate as you present above.
I won't bother dissecting the rest of your depictions; it's tiresome and uneccessary but perhaps I could save both of us a lot of work -
A person is located at the center of a stationary (neither moving nor spinning) hypothetically zero-mass disc in an imaginary otherwise empty universe. There is, at the rim of this disc, a large clock (A) identical to his own clock (B).
The disc starts spinning; according to Einstein's section 4 depiction - clock A (now moving in a closed curve around the stationary clock B) will tick over at a slower rate than B.
The person located at the center of the wheel will see clock A continuously ticking over at a slower rate than his own clock and on the basis that observation (determination) creates reality he is fully entitled to be of the opinion that clock A is ticking over at a slower rate than his own clock.
He has every right to anticipate that if he then moves to the rim of the disc his clock will be subjected to the same 'law' of physics that caused clock A to tick over at the slower rate than his own clock when A started moving thus that when he moves to the rim his clock will also be ticking over at a slower rate than a clock at the center of the disc.
Being located on the rim of the disc he would observe that the central clock is ticking over at a faster rate than his own clock however for him to assume that his clock has not been subjected to the same 'law' of physics as was clock A but that the central clock's rate of operation increased he, presumably being a scientist, should ask himself what indeterminable force - what phenomenon - caused the central clock to physically undergo an increase it's rate of operation?
It is my understanding that the idea of the central clock's rate of operation increasing (i.e. time contraction) was, for Einstein, an anathema.
Your depiction of a wheel rolling along a road complies with sections 1 through 3 of STR.
My depiction of a disc rotating in space complies with section 4 of STR.
  • #153
"Thus, while the static observers in the cylindrical chart admits a unique family of orthogonal hyperslices T = T0, the Langevin observers admit no such hyperslices." http://en.wikipedia.org/wiki/Born_coordinates
Is quoted statement correct, and if so, is it applicable to this discussion?
  • #154
This is correct, but doesn't depend on whether or not the wheel was previously spinning or not.
Also correct, but it's not just his opinion, it is objectively true in his rest frame.
Also correct, if he also accelerates continuously to stay stationary with clock A (and clock B) after he gets to the rim. (if he instead just moves to the rim and becomes inertial, the central clock will run slow relative to his, as he would be moving in a straight line tangent to the rim, in inertial motion, and would soon be far away.)
The fact that he is now accelerating toward the central clock (just like clock A is) caused the central clock's rate to increase relative to his, the central clock's rate doesn't change in its own frame, or in any absolute sense. If this observer's clock is running slower than the central clock then the central clock is running faster than his. The "increased" rate of the central clock is only a relative increase-relative to the observer's clock. The observer never sees his own clock change its rate of ticking. The central clock doesn't tick faster than it used to in any sense whatsoever, except relative to the observer's clock.
And again, no clock ever changes its own rate of operation in its own frame. Any clock that does is "broken" in SR.
And it's still important to note that in the rotating rest frame in which clock A is stationary, clock B is also stationary, and the relative velocity between them is zero. Obviously we can't attribute the time dilation to velocity in this frame, because there is none. But attributing the time dilation to gravitational time dilation in the accelerated frame is mathematically equivalent to attributing it to relative velocity in the inertial frame in which the central clock is stationary and the rim clock is in relative motion.
  • #155
You do not need to continuously refer to the fact that we ignore gravity nor do you need to point out, 'again', that this is not standard time dilation between reference frames.
Relative velocity is not zero in the picture referred to. The equatorial clock is moving in a closed curve around the polar clock as is Einstein's analogous clock that is made to move in a closed curve around an at rest clock.
An observer located alongside clock A is not moving relative to clock A but is orbiting clock B.
When the wheel starts spinning that person is then subjected to a g force thus knows that his is no longer an inertial reference frame.
The central clock is not 'running at a faster rate' when the wheel starts spinning.
It is, from that person's point of view, ticking over at a faster rate than his own clock but to suggest that the central clock is ticking over at a faster rate than it was before the wheel started turning requires 'something' - some force or phenomenon - that has physically created this faster rate of operation however that observer has no reason whatsoever to be of the opinion that the central clock (other than appearing to be spinning on its axis which could be eliminated by it's being mounted on a free-spinning base) is moving.
There is no discernible force that has engendered a suitable equal and opposite reaction.
Al68 said:
Yes, if you're referring to the inertial frame in which clock B is spinning, and clock A is in relative motion. If you're referring to the rotating reference frame in which both clocks are stationary after the wheel starts spinning, then the difference in clock rates is not due to relative motion...
I am of the opinion that it should be blatantly obvious that I am referring to the frame wherein clock A is in relative motion not to the rotating...(etc.)
That's precisely what I said!
The central observer sees clock A orbiting around him; he is obviously of the opinion that clock A is moving; he moves to A's location and, for some reason, decides that he and clock A are no longer moving?
My depiction is not in relation to what clock A determines but what the previously centrally located observer (having moved to A's location) determines.
How does the fact that he is no longer in an inertial frame provide a reason for the central clock ticking over at a faster rate than it did before he moved to the rim?
How would using the standard time dilation equations provide him with an identification of an indeterminable force?
Light emanating from the central light clock does reach him at c in precisely the same way that light from the sun reaches us at c.
I'm not sure to which frame you are referring however Einstein pointed out that the slower rate of operation of the clock on the rim is in accordance with the equation .5tv^2/c^2.
Having moved from the centre of the wheel to it's rim he already knows that he is not at rest in an inertial reference frame.
In section 4 Einstein pointed out that a clock that moves to another clock's location does change it's own rate. It, according to Einstein, 'goes more slowly' than it did before it started moving.
In sections 1 through 3 of SR "...any clock that changes its own rate in its own frame does not qualify as a valid clock in SR." however in section 4 Einstein introduced a clock that does 'change it's own rate' - by moving!
And your reason for making that comment was...? I really don't believe that it contributed anything.
Is it not feasible that because his seconds are shorter than they were before he started moving that his hours are also shorter?
  • #156
If my understanding is correct then I think this entire thread is pretty easy to resolve.
What you describe as "real" is what is usually called "proper" (e.g. an observer's proper time is the time displayed on a clock carried by the observer which is thus at rest in the observer's frame). As you mention, proper quantities (proper time, proper length, proper acceleration, proper mass, etc.) are not frame dependent. This is one good reason for classifying "proper" quantities as "real".
Now, looking at the scenarios of interest here, we know that between when A and B start and when they meet A accumulates less proper time than B. This is a frame-invariant fact and involves only descriptions of each clock in its own rest frame. All frames agree on this, and this is what you would call "real".
However, as soon as you begin comparing the rate of one clock to another clock then you are talking about "what appears to be taking place from the point of view of a person who is moving relative to that reference frame". This is not "real" according to your definition above, and therefore it should not be surprising that different reference frames disagree on the details since they are all just "illusions" anyway. You simply cannot make any "real" statements about the relative rates of A and B.
  • #157
Relative velocity between the clocks is zero in the rotating reference frame, not any inertial frame.
Not in an absolute sense, or relative to any inertial frame. It does run fast relative to clock A in the accelerated frame of clock A.
He decides he is no longer moving relative to clock A. The relative velocity of both clocks is now zero relative to him.
The central clock didn't change its rate, it always ticked at a faster rate than a clock accelerating toward it in the accelerating clock's frame.
Light from the sun doesn't reach us at precisely c. Light only travels at c relative to inertial reference frames.
Right, in the inertial frame of the center clock. But this equation can't be used in accelerated frames. If it was used, it would say that clock B ticked at the same rate as clock A in A's frame, which is clearly wrong.
It 'goes more slowly' than the stationary clock, not necessarily more slowly that it did before. We could easily say that the "moving" clock is "going faster than it did before" relative to a third clock at rest with it after it starts moving. How does a single clock slow down and speed up at the same time? Because nothing happened to the clock itself, its rate is frame dependent.
The clock never changed its own rate, it always had different rates in different reference frames because its rate was always frame dependent.
Anytime Einstein speaks of a clock running slow relative to another, his assumption is that nothing physical is different about, or happening to the clocks. They are simply both keeping proper time. It is time itself that passes at different rates for observers in relative motion, and their clocks are just tools that record this, assuming that each clock works identically regardless of its own state of motion.
If we define two events, less proper time will elapse for the rim clock than for the center clock between those two events. The clocks just measure this effect, they don't cause the effect by "changing their rate of operation". The effect isn't caused by anything happening to the clocks.
  • #158
Time is the tick rate of the clock, which is a function of the ratio of its speed to light speed. It's also the rate of activity for all material objects composed of basic particles, because light is the mediator of energy transitions. Proper time occurs when the clock and observer have no relative motion, thus the observer cannot detect the change. The clock function is a real, physical effect. Clocks don't measure time since time is a relationship of events. The clock only provides a standard event to measure the rate of activity. An observer with a clock that ticks at half the rate of a 2nd clock merely records twice as many (external to their frame) events in an interval as the 2nd observer. The number of external events remains constant.
  • #159
Al68 said:
The fact that he is now accelerating toward the central clock (just like clock A is) caused the central clock's rate to increase relative to his, the central clock's rate doesn't change in its own frame, or in any absolute sense. If this observer's clock is running slower than the central clock then the central clock is running faster than his. The "increased" rate of the central clock is only a relative increase-relative to the observer's clock. The observer never sees his own clock change its rate of ticking. The central clock doesn't tick faster than it used to in any sense whatsoever, except relative to the observer's clock. And again, no clock ever changes its own rate of operation in its own frame. Any clock that does is "broken" in SR
In section 4 STR Einstein implied that a clock on the rim of the wheel (i.e. a clock that is moving in a closed curve around another clock) will 'go more slowly' (i.e. will tick over at a slower rate) than the 'at rest' clock by a factor of .5tv^2/c^2.
The v in that equation is, of course, the speed at which the moving clock is orbiting the stationary clock.
The traveler would 'see' the stationary clock ticking over at a faster rate than his clock in accordance with that equation yet there is nothing in that equation which refers to his centripetal acceleration toward the other clock!
The traveler 'sees' the central clock 'ticking over at a faster rate than it was before he started moving' thus assumes that it has changed it's own rate of operation ergo that clock is "broken".
No action taken by the traveler - accelerating or decelerating; moving at any uniform velocity toward or away from the stationary clock - has any physical effect whatsoever on that clock's rate of operation! For him to be of the opinion that it is ticking over at a faster rate than it was before he moved to the rim he must be of the opinion that it is his having moved to the rim that has caused the central tick to tick over at a faster rate than it was when he was at that location!
In section 4 Einstein effectively, analogously, wrote that the 'going more slowly' (i.e. time dilation) of the rim observer is dependent upon his rate of travel around the stationary clock. You are, in my opinion, insinuating that from the point of view of your, now, rim observer Einstein was wrong - that the moving clock does not 'go more slowly' (i.e. ticks over at a slower rate) than the stationary clock but that the stationary clock 'goes more quickly' (i.e. ticks over at a faster rate - time contraction) than the accelerated clock.
It is my understanding that the idea of time contraction was, for Einstein, an anathema.
The traveler maintaining an identical distance from the central clock (i.e. being anchored to the rim of the wheel) is analogous to an astronaut whose ship is up against an invisible immovable barrier in space some distance from a clock. He fires his rockets yet cannot move toward that clock. The fact that he fires his rocket does not increase the rate of operation of that clock!
He can pour as much power as he likes into his rocket (analogous to the rim observer increasing his rate of travel around the central clock whilst maintaining a constant distance from same i.e. the wheel is turning faster) but this will have no affect whatsoever on that clock's rate of operation yet in the case of the rim observer, the central clock's rate of operation 'does' increase (in reality, his clock 'goes [even] more slowly' than it did before the rate of spin of the wheel increased).
You wrote "If this observer's clock is running slower than the central clock then the central clock is running faster than his." and I have consistently agreed with that comment however for the traveler to be of the opinion that the central clock has undergone a change in it's rate of operation and that it is now ticking over at a faster rate than it was when he was at that location indicates to me not only a challenge to Einstein's section 4 depiction but also an indication of his gross ignorance and stupidity!
Whilst it well may be "...important to note that in the rotating rest frame in which clock A is stationary, clock B is also stationary, and the relative velocity between them is zero." for the observer at the center of the wheel to be of the opinion that when he moves to it's rim he will be stationary is, in my opinion, asinine!
The wheel is spinning at perhaps several hundred thousand Ks a second. Having moved to the rim he feels a tremendous 'force' attempting to pull him away from the wheel - a force to which he was not being subjected at the center of the wheel.
Assuming that he is of the opinion that he is 'stationary' is he not likely to ask himself what is creating this 'pull'?
Is he incapable of realizing either before, during or after his relocation that being on the rim of the wheel he will be moving at the same velocity as was a clock at the rim before he moved?
  • #160
Al68 said:
cosmosco]Relative velocity is not zero in the picture referred to. The equatorial clock is moving in a closed curve around the polar clock as is Einstein's analogous clock that is made to move in a closed curve around an at rest clock.[/quote] Relative velocity between the clocks is zero in the rotating reference frame said:
cosmosco]The central clock is not 'running at a faster rate' when the wheel starts spinning.[/quote] Not in an absolute sense said:
cosmosco]The central observer sees clock A orbiting around him; he is obviously of the opinion that clock A is moving; he moves to A's location and said:
cosmosco]How does the fact that he is no longer in an inertial frame provide a reason for the central clock ticking over at a faster rate than it did before he moved to the rim?[/quote] The central clock didn't change its rate said:
cosmosco]Light emanating from the central light clock does reach him at c in precisely the same way that light from the sun reaches us at c.[/quote] Light from the sun doesn't reach us at precisely c. Light only travels at c relative to inertial reference frames.[/quote] You wrote said:
cosmosco]I'm not sure to which frame you are referring however Einstein pointed out that the slower rate of operation of the clock on the rim is in accordance with the equation .5tv^2/c^2.[/quote] Right said:
cosmosco]In section 4 Einstein pointed out that a clock that moves to another clock's location does change it's own rate. It said:
On the basis that one clock is ticking over at a slower rate than another clock something physical is different about those clocks! They are ticking over at different rates!
If a clock at sea-level is ticking over at a slower rate than a clock on top of a mountain something physical is creating this variation. One of them is in a stronger gravitational tidal area than the other one!
When Hafele and Keating carried out the first leg of their experiment something physical did happen to the clocks in the aircraft! They were 'going more slowly' (i.e. ticking over at a slower rate) than the laboratory clocks. The laboratory clocks remained unchanged!
Clifford M Will pointed out in Was Einstein Right? that the clocks in the aircraft should more correctly have been compared with a (relatively 'stationary') master clock at the center of the planet which (gravitational effects being allowed for) is ticking over at the same rate as Einstein's polar clock.
During that flight Hafele and Keating were analogous to a person moving from a point part-way across the rotating wheel (A') to the rim of that wheel who (erroneously) assumes that his clock is not ticking over at a slower rate than it was when he was at A's location but that A' has started ticking over at a faster rate than it was when he was at that location.
Hafele and Keating could also have been (but presumably were not) of the opinion that their clocks did not slow down when they 'moved to that more distant location on the spinning wheel' but that the laboratory clocks (clock A') ticked over at a faster rate than they did before the flight commenced ergo that the laboratory cloks changed their rate of operation!
According to Einstein - a clock that has been accelerated 'goes more slowly' (i.e.ticks over at a slower rate) than a clock that has remained at rest!
Less proper time elapses for the rim clock than for the center clock because the rim clock is 'going more slowly' (i.e. ticking over at a slower rate) than the center clock!
I have made no suggestion to the effect that the clocks will cause the times between when those events occur to vary.
  • #161
If you are just comparing the rates of the two clocks to one another in given frame, then the contrast you're trying to draw here doesn't make sense--if clock X is ticking slower than Y, then of course Y is ticking faster than X, these are just two ways of saying the same thing (just like there's no difference between the statements 'Dave is taller than Stan' and 'Stan is shorter than Dave'). On the other hand, if you are talking about the rate a clock is ticking relative to coordinate time in a given frame, then it's true that in inertial frames there is no "time contraction"--a clock at rest in an inertial frame ticks at the same rate as coordinate time, while all moving clocks tick slower than coordinate time. But in a non-inertial frame like the rotating frame where the clock at the equator is at rest and ticking at the same rate as coordinate time, it is perfectly possible for a clock to tick faster than coordinate time, so in this sense "time contraction" can occur in non-inertial frames.
In non-inertial frames, G-forces which an inertial observer would attribute to acceleration are instead explained as a consequence of a "pseudo-gravitational field"--see the equivalence principle analysis from the twin paradox page.
  • #162
cos said:
In section 4 STR Einstein used that equation in relation to several accelerated frames!
That's interesting if he did so.
  • #163
You can read section 4 here, nowhere does Einstein refer (explicitly or implicitly) to any non-inertial frames, although he does analyze the time on accelerating clocks from the perspective of inertial frames.
  • #164
Thanks! Very standard stuff (for our times) then.
  • #165
In all but his reference to a clock at the equator he points out that each clock A starts off at rest then moves to another location and although he does not specifically refer to acceleration per se I believe that a relocation of clock A requires acceleration.
  • #166
Yes, if the equation is used in the inertial frame in which the center clock is at rest.
Yes, again in the inertial frame in which the center clock is at rest.
That's because the equation isn't used in the "traveler's" rest frame.
Not if he understands SR.
If A>B then B<A.
The faster rate is relative, not absolute.
Stationary with respect to the rim clock, not in any other sense.
If he's moving at the same velocity as the rim clock, in the center clock's frame, then he is stationary with respect to the rim clock. The "pull" he feels is evidence of proper acceleration, not velocity.
Having moved to the rim and seeing the central clock ticking over at a faster rate than his own clock (i.e seemingly at a faster rate than it was before he moved) the observer can only assume that the central clock has changed it's rate of operation.
That would be like saying that the car driving in front of me "sped up" because its speed relative to me increased when I hit my brakes.
He certainly did not. He used the equation for clocks that have accelerated, not for accelerated reference frames.
Here's a question: Let's call the clock that moves from the center to join the rim clock clock "C". The statement that clock C runs slower at the rim than it did at the center is simply not true in every reference frame. For example, let's say I'm in inertial motion at the rim, local to and momentarily co-moving with the rim clock. In my frame, clock C is running faster than it did at the center. What caused clock C to "speed up its rate of operation"?
  • #167
But again, he's analyzing things from the perspective of an inertial frame, not from the perspective of A's non-inertial rest frame. Do you understand the difference between 1) analyzing an accelerating object from the perspective of an inertial frame, and 2) using a non-inertial frame?
  • #168
That ratio is always zero for the inertial rest frame of the clock.
  • #169
So the observer is located at the center of the wheel; he determines that the rim clock (A) is moving around him at v and, applying Einstein's section 4 STR equation (i.e. "...the equation is used in the inertial frame in which the center clock is at rest."), he calculates the slower rate at which the rim clock is ticking compared to his own clock's rate of operation (i.e. clock B).
Still located at the center of the wheel is he not entitled to be of the opinion that if he moved to A's location that his clock would, then, also be ticking over at the same slower rate than a central clock?
Is he not entitled to be of the opinion that the same 'law' of physics that causes clock A to tick over at a slower rate than B would equally affect his clock?
If he sends another clock, that is synchronous with his clock, out to A's location would he not, then, see that clock ticking over at a slower rate than it was before it moved?
I am of the opinion that this is the very crux of the discussion so at this stage will delay responding to the rest of your post until I receive a response to this message.
I hope that doesn't sound pretentious - it was not intended to be; it is merely an attempt to save both of us some time.
  • #170
There isn't really room for differing "opinions" in SR, there are just statements of fact about what is true in a given frame, no one ever disagrees about what's true in a specific frame. It's certainly true that in the inertial frame where the center of the wheel is at rest, an observer's clock will tick slower if he moves from the center to the edge of the wheel. But without the context of a particular frame, it's meaningless to offer "opinions" about which clock is ticking slower at a given moment.
  • #171
Yes, but it's not just his opinion, it's objective fact in his frame.
Yes, he is.
Yes, he would. But not everyone would. Some hypothetical observers would see that same clock tick at a faster rate than it did before it moved. Because in some reference frames, it "runs slower" and in some frames it "runs faster" than it did when it was at the center.
  • #172
Jesse;
To avoid the complications of too many words, here is a drawing.
Here A and B are initially at rest in the F-frame. When clock F reads 0, A and B clocks read 0, and A and B accelerate (instantly) to speed v. Per synch convention, clock B concludes clock A is ahead by d, for the duration t as indicated on A and B clocks. At the end of t, both decelerate (instantly) to zero in the F-frame. Clock A reads t + d, clock B reads t.
Do you think this scenario is correct, specifically the clock readings?
  • #173
phyti said:
Jesse;
No. If two clocks are initially in sync in the F frame, and then simultaneously in the F frame they both accelerate to velocity v, and later come to rest simultaneously in the F frame, then they will naturally remain synchronized in the F frame because their velocities are the same at every moment in this frame and thus their rate of ticking (=the rate they are accumulating proper time) is also the same at every moment in this frame.
If you want to look at the frame F' in which they are at rest during the phase where they were moving at velocity v in the F frame, then if we look at the prior phase where both were at rest in the F frame, in the F' frame both clocks were moving at velocity v during this phase and the time on B's clock was ahead of the time on A's clock by some constant amount vx/c^2 (where x is the distance between them in the F frame). In frame F' B comes to rest before A comes to rest (another consequence of the relativity of simultaneity), so B is then ticking faster than A and the difference between their readings increases, then A comes to rest too and the difference between their readings remains constant for a bit, and then a little later B accelerates away from rest again before A accelerates away from rest, so during this period A is ticking faster than B and the difference between their readings is decreasing, with the net result that once A accelerates and they are both moving at constant velocity in frame F' again, the time difference between their readings in frame F' will once again have returned to vx/c^2.
  • #174
An illustration, in the F frame (left) and the F' frame (right)
  • #175
Thanks for the illustration DrGreg! Did you use any special graphing program to put those together or just make it in a drawing program? I'd like to find some simple program to put together spacetime diagrams quickly, they'd come in handy on a lot of these threads...
