Second derivatives to find max and min values then sketch graph
In summary, the function is increasing on the interval (-2,16), decreasing on the interval (2,16), and has an inflection point at (0,0).
Nawz
32
Sketch the graph of each function. List the coordinates of where extrema or points of inflection occur. State where the function is increasing or decreasing, as well as where it is concave up or concave down.
9. f(x)=x3-12x
f(x)=x3-12x
f'(x)=3x2-12
f''(x)=6x
Critical Points: (2,-16) and (-2,16)
f''(x)=6x=0 , which makes x = 0 which gives the inflection point (0,0)..
I got all three of those points on the graph. I don't understand the concave up or concave down part and where the function is increasing or decreasing.
Once you have the three points i don't understand why you have to put them into the second derivative to find the increasing or decreasing. You can see it by just looking at the graph and plugging in a few points.
You should be able to use the first derivative to tell whether a function is increasing or decreasing, and the second derivative to tell when it's concave up and concave down
Points of inflection occur where the second derivative is equal to zero which occurs at zero.
Take the first derivative and set it equal to zero to find the critical points. (only the x values) Once found, plug them into the second derivative function and only look at the sign of the answer. If it's positive then the function is concave up at that point ie a candidate for the min, if it's negative then it's concave down ie a candidate for the max.
The function is increasing where the first derivative is positive and vice versa for the opposite.
Calculus was developed centuries before graphing calculators or even ordinary scientific calculators. If you are taking a test in which a calculator is not permitted, you can still draw a very reasonable graph of a function using the first and second derivative.
For an arbitrary function, f''(a) = 0 does not necessarily imply that there is an inflection point at (a, f(a)). For example, the graph of f(x) = x4 has no inflection points, even though f''(0) = 0.
Similarly, g'(a) = 0 does not necessarily imply that there is a max or min at (a, g(a)). The graph of g(x) = x3 has no extreme points even though g'(0) = 0.
A function f is increasing on any interval for which f'(x) > 0, and is decreasing on any interval for which f'(x) < 0.
A function f is concave up on any interval for which f''(x) > 0, and is concave down on any interval for which f''(x) < 0. A function has an inflection point at a point where the concavity changes from concave down to concave up, or from concave up to concave down.
This is an oversimplification that is not always true. For example, g(x) = x4 has no inflection points.
Just find the gradient of point + or - 0.001 of the stationary point and the nature will seem obvious
1. What are second derivatives used for in finding maximum and minimum values?
The second derivative is used to determine the concavity of a function. This information is then used to locate the critical points of the function, which are the points where the first derivative is equal to zero. By analyzing the concavity of the function at these points, we can determine whether they are maximum or minimum values.
2. How do you calculate the second derivative of a function?
The second derivative is calculated by taking the derivative of the first derivative. In other words, you take the derivative of the slope of the original function. This can be done by using the power rule, product rule, or chain rule, depending on the complexity of the function.
3. Can a function have multiple maximum or minimum values?
Yes, a function can have multiple maximum or minimum values. This can occur when the second derivative is equal to zero at multiple points, indicating that the concavity of the function changes from positive to negative or vice versa. In this case, each of these points can be considered a maximum or minimum value.
4. How do you graph a function using second derivatives?
To sketch a graph using second derivatives, you first need to find the critical points of the function by setting the first derivative equal to zero. Then, use the second derivative to determine the concavity of the function at these points. If the second derivative is positive, the function is concave up and the point is a minimum value. If the second derivative is negative, the function is concave down and the point is a maximum value. You can then plot these points on a graph and connect them with a curve to create the overall shape of the function.
5. Are there any limitations to using second derivatives to find maximum and minimum values?
Yes, there are limitations to using second derivatives. This method only works for functions that are continuous and differentiable, meaning they have no sharp corners or breaks in their graph. Additionally, this method may not work for more complex functions, such as those involving trigonometric or logarithmic functions, as the derivatives of these functions may be difficult to calculate.
