What is exactly meant by wave nature,does the particle move like a
In summary, a particle behaves like a wave when it's traveling between two points, and behaves like a particle when it's at rest.
prudhvi mohan
what is exactly meant by wave nature,does the particle move like a wave or it moves along path of a wave or something other?(talking about macro sized particles)
Hi there,
This is probably one of the most difficult concept to grab at first.
Einstein, Schrödinger, and others have shown that matter and energy is very closely related. From the most famous equation from Einstein E=mc2, you can see that matter can be transformed to energy, and vice-versa. Ok, for now no problem. We can see the difference between matter and energy.
But what can also come from this and other equation is that matter, sometimes, behaves like energy (or a photon), and that energy, sometimes, behaves like matter. This dual behavior only shows that to be able to completely understand and model different events, we need to consider one or the other or both.
Hope this helps. Cheers
can u suggest me a book? I did end my+2 grade with lotmany doubts in this area
fatra2 said:
Hi there,
Well surely this shows that matter and energy is one and the same? :)
Hi there,
Not one, but that there is a duality principle. From my understanding, this implies that both can be used to explain the behavior of nature.
But they are very different otherwise, from one another.
Cheers
fatra2 said:
Hi there,
Cheers
Obviously they are different... one is a condensed energy that forms the structures of matter whilst the other is a energy not in a condensed state. Yet they are ultimately the same. Duality principle only exist when you choose to address the state of energy either as energy or as matter. In truth there is no duality as both are one and the same thing.
what is exactly meant by behaving like a wave explain it a little more elaborate manner?
OK. think of a particle whilst its stationery... what do you see? a stationery particle, right? Now think of this particle setting off on a jouney to a distant galaxy. So let's say it's going to travel from Galaxy A to Galaxy B. When it arrives at Galaxy B it becomes a stationery particle again because it occupies a given space, yet whilst traveling from Galaxy A and Galaxy B is was in a state of wave-function. Why? because between Galaxy A and Galaxy B it was 'moving' which prevented it from attaining a given point in space-time that could be measured and calculated. Thus a particle is only a particle when it is stationery, because it occupies a given space-time that can be measured. When it's not a particle it is a wave because it can be anywhere, there is NO SET point that it occupies. When you go a step further, it is neither the wave or the particle and it's both. Tricky? lol
came back to the first question again!
prudhvi mohan, Andrey answered your question already. You might not have gotten what he meant, so I'll try to rephrase.
I'll use photons for this, rather than just the term particle. When a photon travels through space it travels in a wave. The exact position of the photon in unknown. We can determine a probable range of locations of the photon. Once the photon strikes something, for example a piece of photographic paper, the wave collapses and the exact position can be determined.
We use both the wave and the particle descriptions because individually neither description accurately describes our observations.
1. What is exactly meant by wave nature?
The wave nature of a particle refers to its ability to behave like a wave, exhibiting properties such as interference, diffraction, and superposition. This is a fundamental concept in quantum mechanics and helps explain the behavior of subatomic particles.
2. Does the particle move like a wave?
No, the particle does not physically move like a wave. Rather, the wave nature of a particle describes its probability of being found at a certain location. This is known as the wavefunction, and it is a mathematical expression that describes the behavior of the particle.
3. How does the wave nature of a particle differ from classical physics?
In classical physics, particles are described as solid objects with definite positions and velocities. However, in quantum mechanics, particles have both wave-like and particle-like properties. This means that their behavior cannot be fully described using classical physics and requires a different set of principles and equations.
4. Can a particle have both wave and particle properties at the same time?
Yes, according to the principles of quantum mechanics, a particle can exhibit both wave-like and particle-like properties simultaneously. This is known as wave-particle duality and is a fundamental concept in understanding the behavior of subatomic particles.
5. How does the wave nature of a particle impact our understanding of the universe?
The wave nature of particles has revolutionized our understanding of the universe, particularly at the subatomic level. It has helped explain phenomena that could not be explained using classical physics, leading to the development of new technologies such as transistors and lasers. It also plays a crucial role in fields such as quantum computing and quantum cryptography.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
