New Reply
Mu of a Beam
Share Thread Thread Tools
Sep25-12, 06:23 AM   #1
Mu of a Beam
http://www.personal.psu.edu/kar5230/...ete%20Beam.pdf
I'm stuck with a formula above. It says that to calculate for Moment of a beam... use the formula
Mu= w L^2 / 8
now given w = 1000 lb/ft, L=20 feet... then Mu= w L^2/8 = 1000(20)^2/8 = 50,000 lb-ft
(although it's written as 500,000 lb-ft in the site.. i think it's wrong?)
Anyway. my question is.. i have spent half a day doing conversion from lb-ft to Kilonewton-meter and I can't seem to get it right.
I found out the following formula for converting between the two units:
1 kN - m = 737.56 ft-lb
1 kN/m = 68.52 lb/ft
Now in the above example given w = 1000 lb/ft, L=20 feet
1000 lb/ft = (14.59 kn/m x 6^2) / 2 = 525 kn-m/8 = 65.65 Kn-m
Now converting Kn-m to ft-lb...
65.65 KN-m x 737.56 ft-lbs / 1 KN-m = 48424 ft-lb or (lb-ft I assume this is the same).
Now why can't it be equal to the 50,000 lb-ft in earlier calculation??
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Sep25-12, 06:49 AM   #2
Math 2012
Recognitions:
20 feet = 6.096 meters, not 6.
Sep25-12, 07:31 AM   #3
Quote by AlephZero View Post
Thanks. I have spent a day trying to find out even going to this particular Theorem in math which says some equations just can't be solved. So 0.1 is significant.. :)
Sep28-12, 09:27 PM   #4
Mu of a Beam
I'm trying to determine the deflection of the above beam. An engineer told me that deflections of beams from 6 meter to 7 meter is non-linear and high that is why many in constructions limit beam span to 6 meters for economy. What do you think of this. Anyway. Let's prove it by formula/calculations. On the following page is online calculator to solve for deflection.
http://civilengineer.webinfolist.com/str/sdcalcuf.php
Supposed span of beam is 6 meters, w of beam is 4.23 Kn/m, distance of deflection measured is at middle, Modulus of Elasticity is 57000x sqrt (fc=21) or 261206, what is the formula or how do you determine the Moment of Inertia so I can input it to the online calculator above, thanks?
New Reply
Thread Tools
Similar Threads for: Mu of a Beam
Thread Forum Replies
Beam bending problem, calculate deflection of a beam Engineering, Comp Sci, & Technology Homework 7
Relative intensity of reference beam to object beam in optical holography Classical Physics 0
Finding the force exerted on a beam when the temp of the aluminum beam is increased Introductory Physics Homework 4
[Vibration analysis] Timoskenko beam Vs.Euler-bernoulli beam ? Mechanical Engineering 2
Do you calculate the amount of load a beam can take based on when the beam cracks? Materials & Chemical Engineering 6
