Find basis for vector space consisting of linear transformations
In summary: Assuming finite)In summary, To find a basis for V, we can use the linearity of the transformation T to rewrite the given condition as T(u)=0 for a specific vector u. We can also start by finding a basis for the space of all linear functionals satisfying the given condition, which will be helpful in finding a basis for V. Additionally, a transformation can be completely determined by what it does to the basis vectors, and L(W) has the same dimension as W.
p3forlife
Find a basis for V.
Let W be a vector space of dimension 4. Let beta = {x1, x2, x3, x4 } be an ordered basis for W. Let V = {T in L(W) | T(x1) + T(x2) = T(x4) }
L(W) is the set of linear transformations from W to W
We know that V has dimension 3, since T(x4) can be expressed in terms of T(x1) and T(x2). So V has the general form of {T(x1), T(x2), T(x3), T(x1) + T(x2)}
But I'm lost as to how I can find a basis for V when nothing is said explicitly.
Hi p3forlife! :smile:
Hint: what is the matrix for a general T?
what is the restriction on the matrix if T(x1) + T(x2) = T(x4)? :wink:
So the matrix for a general T will look like:
[T] = [a11 a12 a13 a14]
[a21 a22 a23 a24]
[a31 a32 a33 a34]
[a41 a42 a43 a44]
where a11 + a12 = a14
a21 + a22 = a24
a31 + a32 = a34
a41 + a42 = a44
but i can't get any farther than this unfortunately.
[a21 a22 a23 a24]
[a31 a32 a33 a34]
[a41 a42 a43 a44]
ok, let's do this slowly and logically …
the basis for V must be smaller than any basis for L(W) …
can you find a basis for L(W)? :smile:
It may also help to use the linearity of your transformation [tex]T[/tex]. You should be able to rewrite your condition as [itex] T(u)=0[/itex] for some specific vector [itex]u[/itex].
I am also not so sure of your dimension argument. Doesn't [tex]L(W)[/tex] start with dimension 16?
Remember that (when acting on the left on a column vector) each row of a matrix is a linear functional mapping [tex]W \to [/tex] the real numbers.
You can start with that simpler problem of finding a basis for the space of all linear functionals satisfying the given condition. Its answer should be very helpful in this problem.
Okay, so finding a basis for L(W)...
Since beta = { x1, x2, x3, x4} is a basis for W, if you do a linear transformation from W to W, the basis should be { T(x1), T(x2), T(x3), T(x4)} ?
Sorry...I'm striking a blank about this problem.
I don't think you understand what the elements of L(W) are …
and a basis isn't attached to a particular T … it has to be the same basis for all T in L(W).
How would you define a particular element of L(W)? :smile:
So L(W) means you take an x in W, you apply a transformation, then you get T(x), where the set of all T(x) is the range of W.
ah, no …
T (a typical member of L(W)) is the transformation. :smile:
Argh...sorry this is taking so long :S
So since L(W) is the set of all linear transformations from W to W, it means that V is a subset of a W, since there is the restriction of T(x1) + T(x2) = T(x4)
In L(W), we start off with 16 dimensions, since each of T(xi) for i = 1, 2, 3, 4 has 4 elements, and 4 times 4 is 16. But, in V, since T(x1) + T(x2) = T(x4), we can take off 4 dimensions from 16, giving us 12 dimensions.
So in order to satisfy T(x1) + T(x2) = T(x4),
choose T(x1) = 1, T(x2) = T(x3) = 0, T(x4) = 1. So then the basis for V has to be in terms of x1, x2, x3, x4, so we have the matrix:
x1 0 0 x1
x2 0 0 x2
x3 0 0 x3
x4 0 0 x4
0 x1 0 x1
0 x2 0 x2
0 x3 0 x3
0 x4 0 x4
0 0 x1 0
0 0 x2 0
0 0 x3 0
0 0 x4 0
Is this what you mean by a matrix for a general T?
p3forlife said:
… But, in V, since T(x1) + T(x2) = T(x4), we can take off 4 dimensions from 16, giving us 12 dimensions.
Yes, but you haven't said why it's 4.
You can't put x1 etc in your matrix …
the elements of the matrix are numbers, and x1 is a vector. :frown:
A general matrix is
a11 a12 a13 a14
a21 a22 a23 a24
a31 a32 a33 a34
a41 a42 a43 a44
where the a's are all numbers,
and the vector x1 + x2, for example, is
So how would you write, using vectors and a matrix, T(x1) + T(x2) = T(x4)? :smile:
Hint: A transformation can be completely determined by what it does to the basis vectors.
The way he described it L(W) does not have the same dimension as W. L(W) is not the dual space of functionals W* (which does have same dimension as W if it's finite)
but rather [tex]L(W)=W\otimes W^*[/tex] which has the square of the dimension of W.
1. What is a vector space?
A vector space is a mathematical structure that consists of a set of objects, called vectors, that can be added together and multiplied by scalars (numbers) to produce new vectors. These operations must satisfy certain properties, such as closure, associativity, and distributivity, to be considered a vector space.
2. What are linear transformations?
Linear transformations are functions or mappings that preserve vector addition and scalar multiplication. In other words, the output of a linear transformation will always be a linear combination of the input vectors. They are often represented by matrices, and they play a crucial role in linear algebra and many other branches of mathematics.
3. How do you find a basis for a vector space consisting of linear transformations?
To find a basis for a vector space consisting of linear transformations, you need to first determine the set of all possible linear transformations that can be applied to a given set of vectors. Then, you can use techniques such as Gaussian elimination or the method of finding null spaces to find a set of linearly independent transformations that span the entire vector space.
4. Why is finding a basis for a vector space important?
Finding a basis for a vector space is important because it allows you to represent any vector in the space as a linear combination of the basis vectors. This can help simplify calculations and provide a deeper understanding of the vector space and its properties. Additionally, a basis can be used to determine the dimension of a vector space, which is a fundamental concept in linear algebra.
5. Can a vector space have more than one basis?
Yes, a vector space can have more than one basis. In fact, any vector space has an infinite number of possible bases. However, all bases for a given vector space will have the same number of elements, which is known as the dimension of the vector space. This means that any two bases for a vector space are equivalent and can be used interchangeably to represent vectors in the space.
