| New Reply |
Need hlep with a triangle question (Trigonometry) |
Share Thread |
| Nov4-12, 07:42 PM | #1 |
I'm doing some trigonometry, and right now I'm given this equilateral triangle,
http://i.imgur.com/WOPCk.png So how would I go about to find side AP, AQ, and PQ? I think I have a grasp of what it is, but not sure how to execute. I know you have 60 degree angle for ABC and all sides are 3, but not sure how to go about finding the rest of the stuff. Would I maybe make side AP 3 - x and BP x and then AQ as 3-y and QC as y? |
| Nov4-12, 08:34 PM | #2 |
Lengths AP, AQ, PQ could be pretty much anything, for the information you have given. Have you missed some of the details of the question out?
| Nov4-12, 08:50 PM | #3 |
So the whole question is....
An equilateral triangle ABC has been creased and folded so that its vertex A now rests on BC at D, such that BD = 1 and DC = 2. Find the length of A) AP B) AQ C) PQ That's all it says, so I drew a diagram of it, since u know the angles of ABC and the outer line. |
| Nov4-12, 09:18 PM | #4 |
Isn't angle PDQ 60 degrees because it was formed by folding the original triangle?
Line PA and line PD are also the same, as should AQ and DQ for the same reason above. |
| Nov4-12, 10:05 PM | #5 |
| Nov8-12, 12:09 PM | #6 |
I visualize the triangle PAQ spinning on an axis that intersects point Q and that is parallel to line BC. So PAQ is the vertical flip of QDP. I think, both angles are equal in every way. I picture a quadrilateral, where all the angles that make up the two unknown, bigger, angles in the quadrilateral are equal to 60 deg. I see that all the angles in the triangles in ABC are 60 degrees now.
DQ = 2 units DQ = AQ = 2 units As I continue it seems that all the unknown lines' lengths except QC and BP, which are 1 unit each, are equal to 2 units. In my attempt to answer the posed question, I suspected that this thread might be a slightly elaborate prank. However, I continued to work through the problem in case it was not. I think it's possible that the validity of the question and given info by the original poster can be verified by someone who can translate the given info into a representation on the xy plane. If my work here is erroneous, feel free to inform me. |
| New Reply |
Similar discussions for: Need hlep with a triangle question (Trigonometry)
| Thread | Forum | Replies | ||
| Trigonometry, area of triangle | Precalculus Mathematics Homework | 10 | ||
| Solve a Triangle using Trigonometry | Calculus & Beyond Homework | 6 | ||
| Trigonometry Triangle Help | Precalculus Mathematics Homework | 2 | ||
| Please hlep me with this ELECTRICAL FORCE QUESTION. | Introductory Physics Homework | 6 | ||
| Right angle triangle trigonometry | Introductory Physics Homework | 4 | ||
