Calculating Flight Angle and Thrust Force of a Gliding Plane with Engine Failure
In summary: Then the pilot has an engine failure and the plane glides at a constant glide angle (which is the direction of flight below the horizontal) 6.80 degrees towards a safe landing at this constant speed of 138 km/h experiencing a drag force of 1330 N that opposes the direction in which the plane is moving.In summary, the plane experiences a drag force of 1330N and a thrust force of 1330N when flying with an engine failure.
Hendrick
43
A plane of mass 1220 kg has an engine failure when flying with an airspeed of 138 km/h at an altitude of 2960 m on a calm day. It then glides at a constant glide angle (which is the direction of flight below the horizontal) 6.80 degrees towards a safe landing at this constant speed of 138 km/h experiencing a drag force of 1330 N that opposes the direction in which the plane is moving.
(b) Suppose the pilot instead had managed to get the airplane engine started such that he was able to apply full throttle and the airplane climbed along a straight line angled above the horizontal so that it gained altitude at a steady rate of 4.07 m/s. Assuming he was again flying with an airspeed of 138 km/h determine:
i)The thrust force of the engine (that acts in the direction the plane is moving)
g = 9.81 m s-2
F = ma
sin theta = Opp/Hyp
The flight angle above the horizontal the plane is flying is 6.09 degrees
.1|...\ 2
1 =
Code:
F_gravity
2 =
Code:
F_thrust
3 = horizontal
Using: sin theta = Opp/Hyp
Hyp = Opp/sin theta
= (1220*9.81)/sin(6.09)
= 112811.2053 N
Actual answer is 2600N
HI
draw a free body diagram first
as plane is moving with const. velocity
thrust (in direction of plane)= air resistance + component of gravity in d direction opposite the movement of plane
thrust= 1330 + M X g X cos(90-6.09)
= 1330 + 1220 X 9.81 X sin(6.09)
=1330+1270
=2600 N
i guess no problems now Hendrick !:biggrin:
When the plane is gliding at constant velocity there are three forces not two.
1. Weight vertically down
2. Drag in the opposite direction to the motion of the plane
3. Lift from the wings, perpendicular to the motion of the plane.
Your wrong answer seems to have forgotten about the lift.
For the second part, the magnitude of the lift force is the same as the first part, because the airspeed is the same.
ohh...
why they never teach all this at high school?
but this time that doesn't add any problem to my answer as it will eventually be zero
neways...Thanks to you ! for correcting me
pcdagr8, when you resolved the forces in the direction the plane is travelling, you got the right answer, because the component of the lift force in that direction is 0.
But Hendrick didn't do that.
Anyway, when you draw a free body diagram it's usually best to include ALL the forces :smile:
pcdagr8 said:
HI
=1330+1270
=2600 N
Hi, thanks very much, you really helped me calculation wise.
Would you be able to show me the vector diagram you used to calculate it? I've tried recreating it but everything seems wrong...
Hi,
With engine failure (gliding descent):
....../ F_lift (perpendicular to plane)
....../ (angle between horizontal and plane is glide angle at 6.38 degrees)
......~~~~ <---(horizontal)
F_thrust<-----../plane/..------> F_drag (1330N)
......| F_weight
......V
Without engine failure (steep climb)
.....\ F_lift (perpendicular to plane)
F_thrust<-----...\plane\..------> F_drag
.....~~~~ <---(horizontal) (angle above the horizontal the plane is flying is 6.09 degrees)
......| F_weight
......V
Would you be able to show me the vector diagrams which produce the calculation which pcdagr8 showed?
--Thanks
The OP first says the flight angle above the horizontal the plane is flying 6.09 degrees.
I don't understand how he obtained this value :confused:
I mean, if we draw a triangle, its hypotenuse is the thrust force, its opposite side is the force of gravity. So to find the angle we have to use this
[tex]sin \theta = \frac{mg}{F_{thrust}}[/tex]
[tex]=sin^{-1}\frac{11968.2}{4.07}= 54.22[/tex]
So, why is it that I got 54.22° and not 6.09°? Can anyone show me how to work out the flight angle?
1. What is the definition of thrust force?
The thrust force of an engine is the force generated by the propulsion system that propels an object forward. It is the force that pushes an object in the opposite direction to the exhaust gas expelled from the engine.
2. How is the thrust force of an engine calculated?
The thrust force of an engine is calculated by multiplying the mass flow rate of the exhaust gas by the difference in exhaust gas velocity between the inlet and outlet of the engine. It can also be calculated by multiplying the mass flow rate by the exhaust gas velocity.
3. What factors affect the thrust force of an engine?
The thrust force of an engine is affected by several factors, including the mass flow rate of the exhaust gas, the exhaust gas velocity, the design and efficiency of the engine, and the surrounding atmospheric conditions.
4. How does the thrust force of an engine affect the motion of an object?
The thrust force of an engine is responsible for the forward motion of an object. The greater the thrust force, the greater the acceleration and speed of the object. The direction of the thrust force also determines the direction of the object's motion.
5. Can the thrust force of an engine be increased?
Yes, the thrust force of an engine can be increased by increasing the mass flow rate and/or the exhaust gas velocity. This can be achieved by optimizing the design and efficiency of the engine, as well as adjusting the surrounding atmospheric conditions.
  • Other Physics Topics
