KatamariDamacy
- 61
Why photons can't go any slower than the speed of light, in vacuum? Or if they could, then why they don't?
Nugatory said:Photons are light, so of course the speed they move at is the speed of light.
But if you're asking why light moves at one particular speed (##2.998\times{10}^8## m/sec, the number we usually call ##c##) and never faster or slower... Light is electromagnetic waves traveling through space, and the speed at which these wave move can be calculated from the laws of electricity and magnetism; this calculation was first done by James Maxwell in 1861.
KatamariDamacy said:Yes, but none of that explains "why".
For some waves, but by no means all, the speed of propagation is dependent on the amplitude. Water waves are an example where the speed depends on the amplitude, sound waves in a rigid material are an example where it does not. In all cases, if you know the underlying equations you can solve them to find the speed-amplitude relationship; the solution to Maxwell's equations are waves whose speed does nor depend on the amplitude.Also, doesn't it speed of propagation for all the other kinds of waves depends on their wavelength or amplitude?
Nugatory said:Nobody can answer a "why?" question. You ask "Why is A true?", I answer "Because B", and then you can reasonably ask "But why B?" and the only thing that will end the cycle is mutual fatigue .
In this case, we don't know why the laws of electricity and magnetism are what they are. We what these laws are, because we've observed electricity and magnetism in experiments and found that they always obey Maxwell's equations.
For all waves, the speed is related to the frequency and wavelength by the relationship "speed equals wavelength times frequency". That holds true for light as well; the higher frequency waves have shorter wavelengths.
KatamariDamacy said:So although we don't know why gravity exist or why it has those proportions that it does, we still can explain planetary orbits, explain the speed of falling objects, terminal velocity, or escape velocity. Similarly I think there is reasonable hope this particular question can too have such explanation.
Nugatory said:I'm don't understand how you're happy cutting off one chain of "Why?" questions with the answer "Because that's what we find when we apply Newton's equations" but not happy cutting off the other chain of questions with "Because that's what we find when we apply Maxwell's equations".
bcrowell said:"Why" questions can have answers, but to decide what would be a satisfying answer, you have to decide what you consider to be fundamental and what you consider to be derived. The modern attitude is that the c in SR is not defined as the speed of light, it's just a conversion factor between time and space. What's fundamental is not Einstein's 1905 postulates (which single out light as if it had some special role) but the Lorentz transformation, which describes the properties of spacetime.
If you accept these foundations, then there is a reason light travels exactly at c, which is that massless particles always travel at c.
KatamariDamacy said:However, combined or derived concepts can have "why" explanation, which is really only just a relation with other concepts. So although we don't know why gravity exist or why it has those proportions that it does, we still can explain planetary orbits, explain the speed of falling objects, terminal velocity, or escape velocity. Similarly I think there is reasonable hope this particular question can too have such explanation. In other words, even though the origin remains a mystery, it should still be relative to something.
Nothing wrong here. As bcrowell explained, we're talking about a union of space and time here, called spacetime. That means space can be measured in the same units as time. But how long is a second of space or a meter of time? There must be a fundamental conversion factor "c" that tells you how many meters you have per second. That fundamental "c" obviously has the dimensions of a velocity.Although possible, I'd say it's logically or mathematically wrong to qualify any kind of velocity as "fundamental" property.
Drakkith said:It does have an explanation, which was given in post #2 and expanded on throughout the thread. Whether you like that explanation is another matter.
ChrisVer said:@Katamari:
Because if they would go any slower, they would have to be in some other mean and not the vacuum. So when you ask why it travels at c in vacuum, the answer is because it's in vacuum. If it was anywhere else, then the velocity is:
[itex]u= \frac{1}{\sqrt{\epsilon \mu}} [/itex]
where [itex]\epsilon, \mu [/itex] the dielectric constant and magnetic constant of the mean material.
Why is that? because that's how waves work, and the electromagnetic waves follow the Maxwell eqs too...
It is related to Maxwells equations since light is an electromagnetic wave.KatamariDamacy said:Basically I'm just asking what is the speed of light related to, and how.
bcrowell said:Well, there have been two completely different explanations discussed in the thread.
It is related to the invariant speed of the Lorentz transform since it is massless.
These: http://en.wikipedia.org/wiki/Maxwell's_equations#Conventional_formulation_in_SI_units (see also: http://en.wikipedia.org/wiki/Maxwel...s.2C_electromagnetic_waves_and_speed_of_light )KatamariDamacy said:What equation(s) are you talking about?
No. That is not due to any equation or any physics. That is purely due to our choice of units. You can make it be any number you want by choosing different units. Often, we even use units where it is a dimensionless 1.KatamariDamacy said:Isn't there any equation that tells us _why does the speed of light have that particular number, and not less or more?
KatamariDamacy said:Maxwell's equations, like any other, carry some meaning and reasons within them, every property is somehow related to some other property. Basically I'm just asking what is the speed of light related to, and how.
ChrisVer said:So when you ask why it travels at c in vacuum, the answer is because it's in vacuum. If it was anywhere else, then the velocity is:
Nugatory said:Among other things, they show that a decreasing magnetic field will produce an increasing electric field nearby and that a decreasing electric field will produce an increasing magnetic field nearby.
Well, you have to be careful what you mean by different. The numbers for the electric and magnetic properties are also just due to the units you use. So you have to decide if that is what you mean by different, and if not then you have to think about what you do mean.KatamariDamacy said:So then if these electric and magnetic properties happened to be different, the speed of light would be different as well, right?
Nugatory said:You accept Newton's ##F=Gm_1m_2/r^2## as an explanation of planetary orbits, escape velocity, the speed of falling objects, and the like... But there is no equation anywhere that tells you why ##G## has the particular numerical value that it does. We determined it by observation, seeing what happens to falling objects. There is no why behind its value.
Similarly, Maxwell's equation contain constants relating the strength of electric and magnetic fields, and the values of these constants were discovered by observation. But once you accept those particular values the way you've accepted the value ##G##, the value of the speed of light follows as logically as the speed of a falling object follows from the value of ##G##.
bcrowell said:This seems like a very unsatisfactory explanation to me. Then you would have to have a completely different explanation for why gluons travel at c, and why gravitational waves travel at c.
KatamariDamacy said:Isn't that same equation valid for vacuum as well?
ChrisVer said:Well this explanation is the "classical" one given from studying the EM waves in Electrodynamics... it's not a pure answer though,so I tried to make you happy with my next post.
And it can also explain why light travels with different velocities in different materials and not only vacuum ...
The rest you are saying for gluons is answered by relativity itself since they are massless..
ChrisVer said:Now for the photons, they travel at c because they are massless. That's due to the fact that (since they are massless) the 4-momentum squared would have to be zero [itex]p^{\mu}p_{\mu}=0 [/itex] and that should be true for any reference frame...
So in any case it should be: [itex]p^{\mu}= (E/c, \vec{p}) [/itex]
and always [itex] c^{2}|\vec{p}|^{2} = E^{2} [/itex]
The velocity in this case is [itex]v=c=1[/itex] (when you go to the appropriate units)
because the velocity is given by [itex]\beta=v/c=|p|/E=1[/itex]
And that is true for every reference frame just because [itex]p^{\mu}p_{\mu}[/itex] is a lorentz invariant quantity (is the same for all ref frames).
Even if photons go through any material, they remain massless (we can consider an exception for Superconducting materials) so they always travel at c... what happens is that they can be scattered or absorbed/re-emitted and so on, so the light propagates slower...
https://www.physicsforums.com/showthread.php?t=565739
bcrowell said:Comparing this with my #9, it seems like we're on the same track, but approaching the argument in different ways. In your approach, you seem to be taking [itex]v=p/E[/itex] as given. What foundational principle do you use to show that this is an identity? Note that you can't get this identity by dividing [itex]p=m\gamma v[/itex] by [itex]E=m\gamma[/itex], because those are indeterminate forms in the case of m=0.
I think many people have noticed it. In fact, it is something that we occasionally talk about here and sometimes try to get people to calculate on their own:KatamariDamacy said:The simplicity of it strikes me as profound, and it's amazing because even though the relation is rather obvious no one seems to have paid any attention to it before.
KatamariDamacy said:...I was hoping there is more that can be said about it.
KatamariDamacy said:q2/(4πεR2)=μq2v2/(4πR2)
v0=1/√(ε0μ0),
The simplicity of it strikes me as profound, and it's amazing because even though the relation is rather obvious no one seems to have paid any attention to it before. Unfortunately, as usual, it's not quite clear what it really means or whether it is a part of the reason or just a consequence itself. Still, it actually tell us more about the whole thing, not much perhaps, but it's something.
Can anyone make some more sense out this relation and explain why would these two forces "need" to be balanced in an electromagnetic wave, and whether this could be a part of the reason for the speed of light or just a consequence of it and a side-effect itself?
DaleSpam said:I think many people have noticed it. In fact, it is something that we occasionally talk about here and sometimes try to get people to calculate on their own:
https://www.physicsforums.com/showthread.php?t=719625
https://www.physicsforums.com/showthread.php?t=589457
If you are interested in that, then I would definitely focus on the Lorentz transform stuff more than the magnetic/electric properties stuff. The Lorentz transform part is probably more fundamental anyway.
