Solving Series Circuit with 10Ω Resistor, Coil and Capacitor
In summary, a series circuit is an electrical circuit where all components are connected in a single loop with the same current flowing through each component. A 10Ω resistor is a type of electrical component that resists the flow of electric current with a resistance value of 10 ohms. The coil or inductor in a series circuit stores energy and can regulate the flow of current. A capacitor in a series circuit stores and releases electrical energy and helps to filter and smooth out the current. To solve a series circuit with a 10Ω resistor, coil, and capacitor, one would first calculate the total resistance, use Ohm's law to calculate the voltage drop, and apply Kirchhoff's laws to calculate the total current and voltage
pishkil
A series circuit consisting of a 10 ohm resistor, a coil and an ideal capacitor is connected across a 200 V, 60 Hz power supply. The current drawn is 8 A. The voltage across the coil is 120 V and its power factor is 0.8 lagging. Determine (a) the voltage across the capacitor, and (b) the resultant voltage across the resistor and the coil.
V = I*Z; V(resistor) = I*R
Phasor angle(coil) = PHI = cos^-1(0.8); wherein ^-1 indicates inverse.
Solving first V(resistor):
V(resistor) = I*R
" = 8 A(10 ohms)
V(resistor) = 80 V
Phasor angle(coil) = PHI = 36.87 degrees
Here's the phasor diagram:
https://www.physicsforums.com/attachment.php?attachmentid=42443&stc=1&d=1325682519
By using cosine law to solve for V(RL):
V(RL)^2 = V(resistor)^2 + V(coil)^2 - 2V(resistor)V(coil)cos(180 - PHI)
V(RL)^2 = 80^2 + 120^2 - 2(80)(120)cos(180 - 36.87)
V(RL) = 190.16 V => (b)
Now solving for THETA(the phasor angle of V(RL)) by using sine law:
sin(THETA)/V(coil) = sin(180 - PHI)/V(RL)
Solving for THETA:
THETA = 22.25 degrees
Then by using vector component method in order to solve for V(capacitor) and the ideal capacitor's capacitance:
x-comp y-comp
V(RL) 190.16cos(22.25) 190.16sin(22.25)
V(C) V(C)*cos(-90) V(C)*sin(-90)
V(source) 200cos(BETA) 200sin(BETA)
Using summation of x-comp to solve for angle BETA:
190.16cos(22.25) + V(C)*cos(-90) = 200cos(BETA)
BETA = 28.36 degrees (must be negative since BETA's value must be always between the value of THETA and -90 degrees)
Using summation of y-comp to now solve for V(C):
190.16sin(22.25) + V(C)*sin(-90) = 200sin(-28.36)
V(C) = 167.01 V => (a)
So am I doing the right thing? If not, please show your solution. Thanks!
I am uncertain about the components in your circuit!
If the supply voltage is 200V and the power factor is 0.8 then the voltage across the resistance should be VsCos∅ = 200 x 0.8 = 160V
But the current is given as 8A and the resistance as 10Ω which means a voltage of 80V across the resistance. Does the coil have resistance itself?
Also... your phasor diagram should have only 3 arrows
A vertical (+y direction) to represent Vl
A vertical (-y direction) to represent Vc and
A horizontal (+ x direction) to represent Vr (this would be total R which makes me think your coil has a resistance other than the 10Ω stated in the question.
Hope this helps you
Hope this helps you
The problem statement is a bit sneaky. It states that there is a coil rather than an inductor, and then says that there is an ideal capacitor. From that I think we should gather that the while the capacitor is ideal the coil is not; it will have some resistance. This is backed up by the statement assigning a power factor to the coil. The coil inductance and resistance can be calculated from the given information.
The coil does have some resistance and so it is useful to do that part of the calculation first and then put the values obtained into a main calculation.
This diagram might explain the process:
http://dl.dropbox.com/u/4222062/series%20cct%205jan.PNG
that makes more sense ! I got sensible answers.
Does anyone know the correct answers?
I have solutions, but I wonder about giving them before the OP works them out?
Could I send them to you via PM?
@vk6kro, are my answers incorrect? if so, could you please show to us the final answers? i am also in doubt of my answers.
No, your answers are not corrent.
Did you understand the diagrams I posted above?
First you need to work out the size of the resistance of the coil and the inductive reactance of the coil.
Then you should put those values into the main part of the problem.
The diagrams actually show you how to do it. Try to follow a logical procedure and you should get it.
As a check, you should get 132 uF for the capacitor size.
What is a series circuit?
A series circuit is a type of electrical circuit in which all components are connected in a single loop, with the same current flowing through each component.
What is a 10Ω resistor?
A 10Ω resistor is a type of electrical component that resists the flow of electric current in a circuit, with a resistance value of 10 ohms.
What is the role of a coil in a series circuit?
A coil, also known as an inductor, is a passive electrical component that stores energy in the form of a magnetic field. In a series circuit, it can be used to regulate the flow of current and create a delay in the circuit.
What is the purpose of a capacitor in a series circuit?
A capacitor is an electrical component that stores energy in an electric field. In a series circuit, it can be used to store and release electrical energy, filtering out certain frequencies and smoothing out the overall current in the circuit.
How do you solve a series circuit with a 10Ω resistor, coil, and capacitor?
To solve a series circuit with a 10Ω resistor, coil, and capacitor, you would first calculate the total resistance of the circuit, which is the sum of the individual resistances. Then, you can use Ohm's law (V=IR) to calculate the voltage drop across each component. Lastly, you can use Kirchhoff's laws to calculate the total current and voltage in the circuit.
