Register to reply
Particle Size Distribution
by squalenepo
Tags: frequency, particle size, percentage
Share this thread:
squalenepo
#1
Apr17-14, 01:13 AM
P: 3
What is the relationship between the Frequency Distribution, Cumulative Distribution and Particle Size?
Phys.Org News Partner Engineering news on Phys.org
Comfortable climate indoors with porous glass
Crash-testing rivets
Customized surface inspection
Baluncore
#2
Apr20-14, 02:50 AM
Sci Advisor
Thanks
P: 1,781
Frequency distribution and cumulative distribution are statistical concepts.
You have a sample of particles that range from a minimum to a maximum size.
You perform a sieve analysis so as to sort or classify them into size ranges.
See; http://en.wikipedia.org/wiki/Sieve_analysis
You then weigh the particles in each class, (size range), and record that data.
By converting the weight falling in each size class to a percentage of the total you eliminate sample size variation.
If you tabulate or plot that data as a bar graph against size class you will have a frequency distribution. Different grinding or transport mechanisms have characteristically different frequency distributions. The comparison of graphed frequency distributions is quick and easy.
If you then compute a running total over the frequency distribution data, you will generate a cumulative frequency distribution, it starts at zero and finally reaches 100%. From that you can quickly identify what proportion of the mass of particles is above or below a particular size.
Register to reply
Related Discussions
Size distribution statistics Atomic, Solid State, Comp. Physics 0
Particle Size Distribution Measurement General Physics 8
Particle size distribution/histogram errors. General Physics 0
XRD data: particle size, cell size etc Atomic, Solid State, Comp. Physics 4
Particle Size VS Atom Size General Physics 5
