The P.D of a charged capacitor should be more than the charging source .
In summary, when charging a capacitor, the potential across the terminals will be higher than that of the charging source.
dE_logics
742
The P.D of a charged capacitor should be more than the charging source...
That's cause the charge felt by the cell on its terminals might be less that the net charge (depends on what level of charging is the capacitor in), as a result charge accumulation continues until the plates are saturated with charge and it finally gets exposed to the terminals of the battery. After this level of saturation, we can be ensured that the P.D by virtue of the net charge stored in each plate will be more than that of the charging source's. That's cause, there much of the charge on the plates which are being mutually held by each other and cannot be felt by the terminals of the charging source.
If the plates are dismantled at this stage, the potential difference gained by the individual pates will be equal and having more potential than the charging source (cause now the net charge can be exposed and felt).
How am I wrong?
Are you all not getting it?
No. Can you provide a diagram or some equations (or both?)?
When you charge a capacitor the charge continues to flow until the pd across the capacitor terminals becomes equal and opposite to that of the supply terminals.Are you saying that during charging the capacitor can get an even higher voltage?.The voltage across the capacitor can be increased by disconnecting it from the battery and then reducing its capacitance for example by pulling the plates further apart.
You mean, in a fully charged capacitor, the P.D across the terminals will be higher than that of the charging source?
Not without help. Disconnect the voltage source without dissipating the charge across the capacitor and then you can manipulate the voltage across the capacitor. This is done by moving the plates or inserting a dielectric. But in each of these cases you are doing work that gets put into the system. So the increase in the potential does not come free. If you do these things with the voltage source still connected then the potential will go back to what it was before (after the transients work out the charge distributions again).
Yes of course...thanks for the confirmation.
1. Why does the P.D of a charged capacitor need to be greater than the charging source?
The P.D (potential difference) of a charged capacitor needs to be greater than the charging source in order to create a flow of charge from the source to the capacitor. This allows the capacitor to store electrical energy, which can then be released when needed.
2. How is the P.D of a charged capacitor determined?
The P.D of a charged capacitor is determined by the amount of charge stored on the capacitor and the capacitance of the capacitor. The formula for P.D is Q/C, where Q is the charge and C is the capacitance.
3. Can the P.D of a charged capacitor ever be equal to the charging source?
No, the P.D of a charged capacitor can never be equal to the charging source as this would result in no potential difference and therefore no flow of charge. The P.D must always be greater than the charging source.
4. How does the P.D of a charged capacitor affect the stored energy?
The P.D of a charged capacitor directly affects the amount of stored energy. The higher the P.D, the more energy the capacitor can store. This is because the P.D is directly proportional to the amount of charge stored on the capacitor.
5. What happens if the P.D of a charged capacitor is too low?
If the P.D of a charged capacitor is too low, then the capacitor will not be able to store enough energy. This can result in a weaker or slower discharge of the capacitor when it is being used. It is important to have a sufficient P.D for the desired purpose of the capacitor.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
