Why would high-voltage transmission cables disturb a car's radio reception?
In summary: FM radios. So the radio waves from the high voltage line will pass through the FM radio without interference.
I Like Pi
91
i was wondering why would high-voltage transmission cables disturb a car's radio reception with static?
Could it be because of the frequency of the voltage? Or something in terms of frequency?
Thanks :smile:
The "front end" circuits of radios amplify small signals, which are basically varying electric fields. Because signal strengths can vary depending upon a number of factors in the environment surrounding the radio antenna, they incorporate what is called automatic gain control, or AGC, which varies the amplification of the received signal in order to produce a nearly constant level of signal to the following stages of the radio. Otherwise, the volume of sound that you listen to would irregularly be going loud and soft.
High tension power lines produce an electromagnetic field that surrounds them. If the radio is close by, that field can be so large that even with very selective tuning in the radio's front-end, enough power from that power line signal can get through to the AGC that it thinks there is a very strong radio station signal. It clamps down on the amplification, so the actual radio signal is then "lost" in the background noise that is mostly the 60Hz field from the power wires.
The frequency is the same as your household 120 VAC: 60 Hz.
High voltage lines should not interfere with radio reception. If it does there is something wrong. High voltage transmission lines require very good insulators. If the insulator should begin to break down sparking can occur. A spark will produce a broad spectrum of radio frequency waves that you will detect with an AM receiver. It should not have much effect on FM radio. You can also get the same effect if you or someone nearby uses power device that produces sparks (eg. a motor with a commutator and brushes).
AM
1. Why do high-voltage transmission cables affect a car's radio reception?
High-voltage transmission cables emit electromagnetic fields, which can interfere with the radio frequency signals that are used to broadcast radio stations. As a result, this interference can cause static or distort the radio reception in a car.
2. How close does a car have to be to high-voltage transmission cables for radio reception to be affected?
The distance at which high-voltage transmission cables can affect a car's radio reception may vary, but typically it can occur within a few hundred feet. The closer the car is to the cables, the stronger the interference will be.
3. Can high-voltage transmission cables only affect AM radio or can they also impact FM radio?
High-voltage transmission cables can affect both AM and FM radio frequencies. However, AM radio may experience more interference due to its lower frequency and the fact that it uses amplitude modulation, which makes it more susceptible to electromagnetic interference.
4. Can the car's antenna or radio equipment be modified to reduce interference from high-voltage transmission cables?
No, modifying the car's antenna or radio equipment will not eliminate the interference caused by high-voltage transmission cables. The only solution is to avoid driving near the cables or choose a different radio station with a stronger signal.
5. Are there any health risks associated with the electromagnetic fields emitted by high-voltage transmission cables?
There is currently no scientific evidence to suggest that the electromagnetic fields from high-voltage transmission cables pose a health risk to individuals in cars. However, if you have concerns, it is best to avoid prolonged exposure to the fields by limiting your time near the cables.
