Heat Transfer->find k alum. experimentally
  • Thread starter lvll1988
  • Tags
    Heat
In summary: Your Name]In summary, when trying to find the thermal conductivity of aluminum using a thermocouple, it is important to consider factors such as thermal contact resistance and temperature difference to achieve accurate results. Conducting multiple trials and using thermal paste can also help improve accuracy. Additionally, comparing results to known values can validate findings.
lvll1988
Hi,
we have a project where we have to find the thermal conductivity of a aluminum bar using a thermocouple.
An idea was to use the specific heat of ice water. By putting a heated rod into the ice and calculate the energy needed to melt the ice. (Or use the Q=mc(dT) equation). But after, how to relate this transferred energy from the rod and use it to find k?
Another idea was to have boiling water in a beaker, and put the bottom of the isolated bar to the beaker. By doing the q from glass = q from bar, we would be able to find the k of aluminium. However, we were told that the contact resistance between the glass and the rod would lose a lot of data...
Any idea?
Thanks,
Tom D.
Science news on Phys.org
Hello Tom D.,
Thank you for sharing your project with us. It sounds like you have some good ideas for finding the thermal conductivity of aluminum using a thermocouple. I would like to offer some suggestions and advice to help you in your project.
Firstly, using the specific heat of ice water to find the thermal conductivity of aluminum is a good idea. You can use the equation Q=mc(dT) to calculate the energy needed to melt the ice and then relate it to the transferred energy from the rod. However, there are a few additional factors you need to consider in order to accurately determine the thermal conductivity.
One important factor is the thermal contact resistance between the aluminum rod and the ice. This can significantly affect the amount of energy transferred and can lead to inaccurate results. To minimize this, make sure the surface of the rod is smooth and clean, and try to minimize the time the rod spends in contact with the ice.
Another factor to consider is the temperature difference between the heated rod and the ice water. The larger the temperature difference, the more accurate your results will be. You may need to adjust the initial temperature of the rod or the temperature of the ice water to achieve a suitable temperature difference.
In regards to your second idea of using boiling water, the contact resistance between the glass and the rod can indeed affect your results. One way to minimize this is to use a thin layer of thermal paste between the rod and the glass. This will help to improve the thermal contact and reduce the resistance.
Overall, I recommend conducting multiple trials and taking an average of your results to ensure accuracy. You can also compare your results to known values of thermal conductivity for aluminum to validate your findings.
I hope this helps and good luck with your project!
1. How do you find the thermal conductivity (k) of aluminum experimentally?
One way to find the thermal conductivity of aluminum experimentally is by using the guarded hot plate method. This method involves sandwiching a sample of aluminum between two plates of known thermal conductivity and measuring the temperature difference across the sample. By knowing the dimensions and thermal conductivities of the plates, the thermal conductivity of aluminum can be calculated using Fourier's law of heat conduction.
2. What equipment is needed for an experimental determination of aluminum's thermal conductivity?
The equipment needed for an experimental determination of aluminum's thermal conductivity includes a guarded hot plate apparatus, a temperature sensor (such as a thermocouple), a power source, and a data acquisition system. It is also important to have a well-insulated environment to minimize any external heat transfer.
3. How does the temperature difference affect the accuracy of the experimental determination of aluminum's thermal conductivity?
The temperature difference across the sample is a crucial factor in the accuracy of the experimental determination of aluminum's thermal conductivity. A larger temperature difference results in a more accurate measurement, while a smaller temperature difference can lead to errors due to heat loss to the surroundings.
4. Are there any limitations to using the guarded hot plate method for determining the thermal conductivity of aluminum?
While the guarded hot plate method is a commonly used and reliable technique for determining thermal conductivity, it does have some limitations. This method may not be suitable for materials with low thermal conductivity or for samples with uneven surfaces. Additionally, the accuracy of the results can be affected by factors such as temperature gradients within the sample and thermal contact resistance between the sample and plates.
5. How does the thermal conductivity of aluminum compare to other common metals?
Aluminum has a relatively high thermal conductivity compared to other common metals, such as iron and copper. Its thermal conductivity is approximately 237 W/mK, while iron and copper have thermal conductivities of 80.4 W/mK and 401 W/mK, respectively. This makes aluminum a good choice for applications where efficient heat transfer is important, such as in heat sinks and heat exchangers.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
