What type of op-amp is being used in this circuit?
  • Thread starter Femme_physics
  • Tags
    Op-amp
In summary, the conversation was about a circuit problem involving an op-amp and unknown resistors. The conversation discussed various approaches to solving the problem, such as using Kirchoff's Voltage Law and knowing the input and output voltages. The conversation also clarified the function of the zener diode and the role of the power supply in the circuit. The final conclusion was to take the exercise and try to solve it.
  • #36
  • #37
Femme_physics said:
Oh yea, you'll get 2 flowers
Only 2? :redface:
  • #38
Femme_physics said:
I think I got it... full solution here:
It looks very well presented. Good work. https://www.physicsforums.com/images/icons/icon14.gif
Is the determination of Ra, Rb and Rx the full requirement for this exercise? Is this particular brand/number of OP-AMP one that you can tell us anything about, i.e., have you studied its data sheet? Otherwise, we are going to be left wondering what the exact purpose of it is.
P.S. To your classmates keeping watch on this thread...what will the teacher think when you all submit identical homework https://www.physicsforums.com/images/icons/icon5.gif
  • #39
I still don't understand a few things. In the original drawing, we see a current that goes INTO the op-amp, but it is not an inverter, so what gives? This is still confusing to me.
Thank you, but my classmate disagrees with me. He says that we don't know that "I" that goes down, which I marked as "Iamp", because it splits to the op-amp and to the ground. Do you see what I mean?
I didn't know what to tell him, maybe you can answer that?
Yes.
I don't recall our teacher going over it. All I got in my notebook is inverter, follower, comparator, differential, and summing.
How do you know it's homework? :)
My classmates don't keep a watch of this thread...they're not even aware of the forum. Only my classmate who emailed me his solution that I posted here is aware of this forum (and that I'm using it) but he isn't registered here. Which, is a shame, because you guys are terrifically helpful, although I doubt my classmates would have the patience for the long, detailed, somewhat slow and thorough procedure that goes via solving exercises online.
Regardless, I doubt any of my classmates solved it, though they really should, but they have like 50+ exercises to hand out to the teacher so most if not all are going to neglect it. My teacher will probably excuse them if they haven't solved a few hard exercises in our textbook.
I like Serena said:
LOL
  • #40
Now that you've worked out all the currents and voltages, do you have any clue what the circuit does? And what would you need to change to adapt it to a different output value?
  • #41
I actually didn't work out everything, as per the last post before that I made...still need to figure something out. I will answer this question as soon as I got it :)
  • #42
How do you know it is not an inverter? Or how could you tell whether it is? It has either no inputs, or it has two, depending on how you want to view it. If you say it has two, then one input is non-inverting, the other is inverting.
In amplifiers, the term "inverting" has two meanings. One is that if the input is +x volts, the output will be -x volts. That behaviour isn't possible here, for the simple reason that the OP-AMP output cannot go negative because the OP-AMP isn't powered by a negative supply; it is powered by only a single positive supply, that's the 25v.
The other meaning of "inverting" is that if the input level should rise slightly it will cause the output to fall. So if the input rose, say, from 3.4 volts to 3.5, and the output was correspondingly noted to fall from 2.3 to 2.0 volts, we could say we have an inverting amplifer of gain x3.
No. But I conjecture that you are seeing the labelling arrows denoting Vout on the op-amp output and mistakenly concluding it represents a short circuit to ground https://www.physicsforums.com/images/icons/icon4.gif I ascribed to it a current of zero since we are told nothing about a load there. Consider it an open circuit; if it isn't, we would have been told.
What is the number written on the op-amp in your first schematic?
  • #43
Why is Ra connected to the output of the op-amp, and not to the +25V supply? (obviously one would have to change the value of Ra to keep the current through the Zener at 2mA)
  • #44
No. But I conjecture that you are seeing the labelling arrows denoting Vout on the op-amp output and mistakenly concluding it represents a short circuit to ground I ascribed to it a current of zero since we are told nothing about a load there. Consider it an open circuit; if it isn't, we would have been told.
You mean that Vout = 12V?
And well, yes, it could be a short circuit to the ground, it could be anything..-- we did make the assumption so figure it's illegal to touch it.
My classmate raised the point that we can't really tell so shouldn't assume (and also didn't like the fact the result is not a round number :P - but it's inconsequential right?), and thought it can't be solved that way. I thought it's better to make assumption if there appears to be no other way...but...well, that's why I ask you guys, just in case :)
True, we can't really tell. Can we? It's rather confusing. BUT according to the fact the current goes into the op-amp, that's our key in telling it's an inverter, right?
  • #45
It definitely could not be a short circuit to ground; this would contradict the specification that Vout = 12V.
It's obviously the circuit's output, but (in the absence of information to the contrary) just regard it as a node where we can measure a voltage.
Unless we can identify something to call an "input" we can't compare input vs. output to see whether there is a inversion or not! (Suppose you have an arrangement where the input current is negative so flows "out" of the input, then a non-inverting amplifier would have output current flowing "in" as here.)
The safest description is to just say the circuit uses an op-amp with negative feedback, and leave it at that. You can't lose marks for saying nothing wrong. :smile:
  • #46
We needs to know!
  • #47
It's not clear to whom you direct your question, M Quack. Are you offering to guide Femme_physics deeper into the workings of this intriguing circuit? Or are you the first of her classmates to discover you can tap into Femme_physics online homework solutions, and you're angling for bonus marks?? http://img593.imageshack.us/img593/2293/starwarssmiley010.gif
  • #48
I'm not on the same homework assignment :-) I am not an expert in electronics but I've been able to work out the resistances and currents, and I have a fair idea what the circuit is about. So for guiding deeper into the workings of the circuit, there a people better qualified.
But I have become curious (professional disease among physicists). I have a vague idea why one would set up Ra is show, but I am not sure. The way it is done now (ignoring the currents indicated), would there not be a second operating point at V+=V-=Vout=0V, not currents flowing except into the op-amp?
  • #49
Ah, that old qurious disease. Is that what they call Q Fever? :smile:
You think that if the output of the op-amp were to be momentarily shorted to ground, it will stay there? Maybe you are right, or maybe not. How would you go about trying to show that 0v is a stable point, without actually constructing the circuit?
  • #50
Grrrr. now you've got me. I'll think about it. But now I have to help a friend move house.
My first idea is that the Zener will behave asymmetrically with respect to noise and might build up an input voltage that way. Btw, this was my point about feeding Ra from +25V. You have less control over the current through the Zener, though if there are variations on the +25V line.
  • #51
A technique sometimes used in power supplies is to feed the zener from the regulated line so that the current into the zener is exceptionally stable. I don't know whether that thinking was behind the reason for doing it here.
  • #52
The circuit is definitely a non-inverting amplifier, gain = +2.4V/V. If you were to change the input from +5V to say + 5.5V you would get 2.4*5.5 = +2.64V output.
If the output goes up when the input goes up, that's a non-inverting configuration. It has nothing to do with the direction of current at the input or output.
  • #53
Femme_physics, I notice in your calculation of V(-) you used an erroneous formula for the resistive divider involving Rb:
So Rb and Rx will need to be recomputed. Circuit parameters do evaluate to nice round figures now. https://www.physicsforums.com/images/icons/icon6.gif
http://img804.imageshack.us/img804/1388/writer.gif "... so I think you should return the flowers..."
  • #54
Actually, your formula is perfectly correct! I was relying on memory and in my mind had Rb and R1 swapped around. :(
  • #55
True, but that's only half the story...
The circuit is also definitely an inverting amplifier, gain = -1.4 v/v. Using the lower end of R1 for input, if you change the input voltage from 0v (ground) to -0.5v, the output rises from +12v to +12.7v. Viewed this way, the zener functions to bias the op-amp so as to allow operation from a single polarity power supply.
  • #56
Q-Fever...OK, this is an attempt to see if the working point at V+=V-=Vout=0V is stable.
Note that my knowledge about electronics is very limited and that this may be a completely wrong way of looking at the problem.
Let's assume the following:
The op-amp as a huge open-loop gain G such that Vout=G(V+ - V-) + Vs/2. G will be something like 10^4 or 10^6. Vs/2 is the midpoint between the supply and ground.
Looking at the characterstic curve of the Zener diode: Around 0V, the Zener diode behaves like a resistor with a fairly large impedance Rz. I guess Rz>RI/4 (you will see later why). Let's say Rz=6.5 kΩ just to have a number.
Now assume V+=ε, a small voltage and V-=0 (it works the same way with V=-ε or V+=ε1 and V-=ε2).
You then get Vout = G ε + Vs/2, which leads to
V-=RI/(Rb+RI)*(Gε+Vs/2)=0.42 (Gε+Vs/2)
V+=Rz/(Ra+Rz)*(Gε+Vs/2)=0.65(Gε+Vs/2)
V+ - V- = (0.65-0.42)(Gε +Vs/2) which is larger than the starting point (which was ε), so the situation is unstable and Vout will drift up until the Zener no longer behaves as a
resistor. For a very small value of ε the constant offset Vs/2 on the output voltage dominates. It does not even matter if ε is positive or negative
For this to be the case RI cannot be too large, RI < Rb/Ra Rz.
For those who wonder if the assumption Vout=G(V+ - V-) + Vs/2 is compatible with the "normal" operation of the circuit:
Assume V+=5V and V-=5v-ε, Vout=12V and G=10000.
Then you get G(5V - (5V-ε))+Vs/2 = Gε + 12.5V = 12V, i.e. ε=-0.5V/G=-50μV which can be neglected.
At the operating point with Vz=5V, the Zener diode has a very steep characteristic curve, i.e. a very small impedance. If Vout changes, the change in V+ will be much smaller than that in V-, so that the negative feedback dominates and Vout is stabilized.
So, NascentOxygen, am I thinking along the right lines here? (I've just made it up, don't be too polite if it's all BS).
  • #57
I guess that's right. Op-amps usually are powered by double supplies, so your Vs/2 term is unusual, but I can't see it could be anything else.
looking at the characterstic curve of the Zener diode: Around 0V, the Zener diode behaves like a resistor with a fairly large impedance Rz. I guess Rz>RI/4 (you will see later why).
That's right.
resistor.
So there is no stable state with Vout=0. In practice, you usually won't get the op-amp delivering an output equal to either supply rail, in any case, so you wouldn't be able to obtain Vout=0.
You analysis is spot on. Below the zener breakdown, the amplifier has more positive feedback than negative. This could send Vout towards 0 but nothing happens that would keep it there, and any noise that sends Vout towards +Vs will succeed, owing to a nett positive feedback.
Well done!
  • #58
Thanks for checking.
