Why is the Temperature of Water Low Than Atmosphere?
In summary, the temperature of water is lower than the atmospheric temperature due to evaporative cooling, which occurs when the more energetic molecules of water escape and evaporate into the surrounding air, taking heat energy with them. This process continues until equilibrium is reached, where the partial pressure of water vapour in the air is equal to the saturation vapour pressure of water at that temperature. This is known as the wet-bulb temperature, which is the lowest temperature that can be reached through evaporation. The process of evaporative cooling is governed by both the selection of faster molecules and the transfer of energy, which work together to lower the overall thermal energy and maintain a lower temperature for the water.
anuragkanase
27
Hello guys,
This has been my observation and a general physical significance of water, maybe.
I would like to know, why does the water keep its temperature low from the atmospheric temperature?
For example, the room temperature is 29°C and the water kept in steel bucket may measure somewhat lower, 26°C (Say).
So what are the factors responsible for it?
Thank You.
Science news on Phys.org
At the surface of the water, the more energetic molecules are escaping (evaporating).
If the relative humidity is less than 100%, more are evaporating than are recondensing from the atmosphere. But that is taking heat energy from the water, so the temperature drops.
Equilibrium is restored when the partial pressure of water vapour in the air equals the saturation vapour pressure of water at the temperature of the water.
Thanks a lot. Got it, so the heated water will be evaporated. And the cooler will be remain at bottom. This cycle will be continued... Thanks again.
That's not what was said. It isn't a matter of selection of the warmer molecules, it is a matter of energy transfer. Selection may play a role in which molecules evaporate, but the temperature drops because of the heat of vaporization.
Thanks got the point.
This is evaporative cooling:
Evaporative cooling is a physical phenomenon in which evaporation of a liquid, typically into surrounding air, cools an object or a liquid in contact with it. Latent heat, the amount of heat that is needed to evaporate the liquid, is drawn from the air. When considering water evaporating into air, the wet-bulb temperature, as compared to the air's dry-bulb temperature, is a measure of the potential for evaporative cooling. The greater the difference between the two temperatures, the greater the evaporative cooling effect. When the temperatures are the same, no net evaporation of water in air occurs, thus there is no cooling effect.
http://en.wikipedia.org/wiki/Evaporative_cooling#Physical_principles
Wet bulb temperature is the lowest temperature that can be reached by the evaporation of water only.
http://en.wikipedia.org/wiki/Wet-bulb_temperature
It's both, actually. Energy barrier acts as both the selector for faster molecules, and to reduce the overall thermal energy. Without both of these mechanisms in place, the equilibrium state would be for both water and air to reach the same temperature.
1. Why is the temperature of water lower than the atmosphere?
The temperature of water is lower than the atmosphere because water has a higher specific heat capacity. This means that it takes more energy to raise the temperature of water compared to the atmosphere. Additionally, water has a higher heat of vaporization, which means it requires more energy to change from a liquid to a gas. This results in water having a lower temperature compared to the atmosphere.
2. How does the temperature of water affect the atmosphere?
The temperature of water can have a significant impact on the atmosphere. When water is heated, it evaporates and rises into the atmosphere, where it cools and condenses to form clouds. This process releases heat into the atmosphere, which can affect weather patterns and climate. Additionally, bodies of water can act as a heat sink, absorbing and storing heat from the sun, which can help regulate the temperature of the surrounding atmosphere.
3. Does the temperature of water affect marine life?
Yes, the temperature of water can have a significant impact on marine life. Many marine organisms have specific temperature requirements for survival and reproduction. If the water temperature becomes too high or too low, it can stress or even kill these organisms. Changes in water temperature can also affect the availability of food and nutrients, as well as the behavior and migration patterns of marine life.
4. How does the temperature of water compare to the temperature of land?
The temperature of water is generally lower than the temperature of land. This is because water has a higher heat capacity and can absorb more heat energy before its temperature increases. Additionally, the movement of water, such as ocean currents, can help distribute heat more evenly, whereas land heats up and cools down more quickly. However, the temperature of water can also be affected by the surrounding land, such as in coastal areas where the water may be warmer due to the heat from the land.
5. Can the temperature of water affect global climate change?
Yes, the temperature of water can play a role in global climate change. As mentioned before, water can act as a heat sink, absorbing heat from the sun and regulating the temperature of the surrounding atmosphere. Changes in ocean temperature can also affect weather patterns, such as the El Niño-Southern Oscillation, which can have a global impact. Additionally, the melting of polar ice caps due to rising water temperatures can contribute to sea level rise and alter ocean currents, further impacting global climate patterns.
  • Thermodynamics
  • Astronomy and Astrophysics
