Mechanical principles - Stess and modulus of elasticity
In summary: So, in summary, the mechanical principles of stress and modulus of elasticity were discussed in relation to a steel towing bar. The bar had a length of 2.2m and a diameter of 45mm, and was expected to carry a maximum load of 210 kN. The safety factor was 4, and for the steel, the ultimate tensile strength (UTS) was 540 MNm^-2 and the modulus of elasticity was 200 GNm^-2. The actual towing capacity of the bar was calculated to be 132.04 MNm^-2, which was found to be acceptable as it met the required safety factor. The extension of the bar under the maximum proposed load was determined to be 1.45
veedub1955
Mechanical principles - Stress and modulus of elasticity
A 2.2m long steel towing bar of solid circular section diameter of 45mm is expected to carry a maximum load of 210 kN. The safety factor is 4; and for the steel the UTS is 540 MNm-2 and the modulus of elasticity is 200 GNm-2
i) Calculate the actual towing capacity of the bar and state whether the proposed limit is acceptable
ii) Determine the extension of the bar under the maximum proposed load
i) σ = Load / Area
Proposed limit acceptable= SF = UTS / σ
ii) Change in length = (σ / Modulus of elasticity) / Length
Hi I have worked out what I think is right but I have trouble writing the correct units, I will put what i have worked out could someone check if I am right please, thank you very much:-
i) σ = Load / Area = 210kN / ((∏(45 x 10-3) / 4)
840x10-3 / 6.362x10-3 = 132.04 (now I think this is MNm2)
Proposed limit acceptable = SF = 540 / 132.04 = 4.09
So the proposed limit in this case is acceptable as it is over the required Safety Factor of 4
ii) Change in length = (132.04 / 200) x 2.2
= 0.66 x 2.2 = 1.45mm (??)
If the load is in Newtons and the area is in m^2, what are the units of load/area?
Hint: it's not MNm^2.
If P/A is in MNm^-2 and E is in GNm^-2, then what are the units of (P/A)/E?
Do MN and GN cancel without using any other factors?
Hi steamking this is where i draw a mental block, i don't know why but I am working on it
1st point putting it like that is it Nm^2?
2nd point do you mean that both ^-2 cancel each other out leaving MNm and GNm?
Thanks, I keep telling myself i will get this!
My point is, if you divide a force by an area, a la P/A, the units must be N/m^2 or alternately, Nm^-2 (You do know there is a difference between a positive and a negative exponent, don't you?)
On the second point, what is the difference between 1 MN and 1 GN? How many MN are in 1 GN? In other words, your calculation of the change in length omits a factor of 1000, although the final answer is correct.
Thankyou very much for taking the time in showing me where i am going wrong SteamKing, that definitely makes more sense, I am going to go and do some more examples to make sure its sinked in whilst its still fresh! Thanks again
1. What is stress?
Stress is a measure of the internal forces acting on a material per unit area. It is typically measured in units of force per unit area, such as pounds per square inch (psi) or Newtons per square meter (N/m^2).
2. How is stress calculated?
Stress is calculated by dividing the force applied to a material by its cross-sectional area. This calculation is known as the stress formula: stress = force/area.
3. What is modulus of elasticity?
Modulus of elasticity, also known as Young's modulus, is a measure of a material's stiffness or ability to resist deformation under stress. It is a ratio of stress to strain and is typically measured in units of force per unit area, such as psi or N/m^2.
4. How is modulus of elasticity determined?
Modulus of elasticity is determined by performing a tensile test on a material and measuring the stress and strain values at different points. The slope of the stress-strain curve at the elastic region is equal to the modulus of elasticity.
5. What is the relationship between stress and modulus of elasticity?
There is a direct relationship between stress and modulus of elasticity. As stress increases, so does the strain, and thus the modulus of elasticity increases. This means that materials with a higher modulus of elasticity are stiffer and more resistant to deformation under stress.
13K
