Induction Coil Failure with increaseing inductance as coil is unwound
In summary, the coil failed because of a short, and the damage progressed due to the heat generated by the short.
GreenENGR
I have a 13 layer 130mH induction coil that failed and now registers 6.64mH. During the failure analysis the coil was unwound layer by layer and the induction dropped in steps of 0.7-1.5mH to a value of 1.3mH until the 8th layer was removed the the inductance increased to 5.4mH. Then the 9th layer was removed the inductance increased again to 18.5mH. There was also wire with the enamel damaged in the 8-10 layers in the middle of the layers. Does anyone know how the induction of the coil increased when the damaged layers were removed?
Could the short in the coil caused one of the layers to reverse polarity generating an opposing magnetic field to reduce the inductance?
You look to have the right idea...When one winding is shorted to another - even at relatively high impedance - the shorted winding develops current when the inductor is energized - in response to the induced magnetic field.
Probably the best way to think of this is a transformer, consider the case of the secondary winding being open circuited - no current so it has no effect on the primary & it looks just like a plain inductor. - as you add load or short circuit the secondary, current flows in the secondary, effectively lowering the inductance of the primary.
Thank you that helps!
Indeed previous posts have answered the question.
If you're relatively new, i would add that's a mighty significant phenomenon to be aware of.
The shorted turns are indeed like a shorted secondary which, in presence of AC excitation to the coil, will develop substantial current.
So they heat up and the damage progresses, feeding on its own heat.
In AC motors and solenoids it leads quickly to catastrophic failure.
In the DC solenoids that move control rods in some nuclear reactors, the excitation is DC from rectified 3 phase which contains some ripple. That ripple adds an AC component to the mostly DC excitation, so we get similar failures,. But they take years to progress to 'catastrophic' level and are easily detectable in early stages by inductance measurement at annual shutdown.
So I've told you nothing new but perhaps underscored the value of your observation.
Good luck in your career!
old jim
I can offer a few possible explanations for the observed increase in inductance when the damaged layers were removed from the coil.
One possible explanation is that the damaged layers were creating a short circuit within the coil, which would disrupt the flow of current and result in a decrease in inductance. When these damaged layers were removed, the flow of current could resume and the inductance would increase again.
Another possibility is that the damage to the enamel on the wire was affecting the electrical resistance of the coil. As the resistance increases, the inductance would also increase. Therefore, removing the damaged layers would decrease the resistance and result in a higher inductance.
It is also worth considering the possibility of a reversed polarity within one of the layers. This could have been caused by a short circuit or other electrical malfunction. When this layer was removed, the opposing magnetic field would also be removed, resulting in an increase in inductance.
Ultimately, further analysis and experimentation would be needed to determine the exact cause of the observed increase in inductance. It is important to carefully examine all aspects of the coil, including the damaged layers and any potential short circuits, in order to fully understand the failure and potential reasons for the change in inductance.
1. What is an Induction Coil?
An Induction Coil is an electrical component that is used to create high-voltage pulses from a low-voltage direct current (DC) supply. It is composed of two coils of wire, the primary and secondary, wound around a core of magnetic material.
2. How does an Induction Coil work?
An Induction Coil works on the principle of electromagnetic induction, where a changing magnetic field in the primary coil induces a current in the secondary coil. The ratio of the number of turns in the primary and secondary coils determines the voltage and current output of the coil.
3. What causes Induction Coil Failure with increasing inductance as the coil is unwound?
As the coil is unwound, the number of turns in the primary and secondary coils decreases, resulting in an increase in inductance. This increase in inductance can lead to a higher voltage output, which can cause damage to the coil, especially if it exceeds the maximum voltage rating of the coil.
4. How can Induction Coil Failure be prevented?
To prevent Induction Coil Failure, it is important to use a coil with the appropriate voltage rating for the intended application. In addition, the number of turns in the primary and secondary coils should be carefully selected to avoid an excessive increase in inductance as the coil is unwound.
5. Can an Induction Coil be repaired if it fails due to increasing inductance?
In some cases, an Induction Coil can be repaired if it fails due to increasing inductance. This may involve rewinding the coil with the appropriate number of turns or replacing the coil altogether. However, prevention is always better than repair, so it is important to carefully select and use the right coil for the intended application.
  • General Discussion
