Mass of Jupiter given a Moon's mass, orbital velocity and distance.
In summary, a user is seeking help with a homework problem involving the mass of Jupiter and the velocity of its moon Europa. They are unsure of which equation to use and are concerned that the given information may be a distraction. After receiving a hint from another user and realizing a calculator error, they are able to obtain a solution that is close to the result given by Google. They also note that the question may have been posted by someone in their class.
contrivance
Hello all, been meaning to make an account here and participate but haven't been around to it. So sorry that my first post is asking for homework help! :|
The planet Jupiter has a moon Europa (m = 5x10^22kg) that is orbiting at a velocity of 14,000m/s at a distance of 7x10^8m measured from the center of Jupiter to the center of the moon. What is the mass of Jupiter?
According to the lecture notes for class, we have the law of universal gravitation [itex]F=\frac{Gm1m2}{r^2}[/itex] and then the formula for "Velocity of a satellite in orbit" [itex]V=\sqrt{\frac{GM}{r}}[/itex]. There's more things like field theory, etc but may not be relevant.
I can't seem to get a good result, google says the mass of Jupiter is 1.898x10^27kg although when I plug the numbers into the velocity formula and solve for M, i keep getting a mere 205604.
This exact same question is posted on yahoo answers, but the first guy's solution is something beyond my course, and everyone else just doesn't seem to be right.
I'm stuck, not sure what formula/equation I need to use and what throws me is that with all the given information I'm not sure if it's all needed or if it's there for distraction.
I would really like just a quick hint to get me in the right direction instead of an entire work through :)
The first guy uses Kepler's third law. The others use essentially your method. Their results are correct within the accuracy of the original data.
Here's a hint:
Dividing by a-b means the same as multiplying by ab
I see, this makes sense now. Well after all this stress last night I discovered I was making a calculator error. putting too much information in at once and forgetting to put parenthesis where needed to get the correct result. I see that our result isn't actually that far off from Google's and my professor has been known to round given information up or down significantly.
I solved for [itex]M[/itex] in the Velocity equation and ended up with about 2.0x10^27 as others did.
What's funny about that Yahoo answer post is I just noticed it was posted three days ago so it might have been posted by someone in my class.
Thanks friends!
I would suggest starting by reviewing the equations and concepts related to orbital motion and gravity. It seems like you may be mixing up some of the equations and variables. The first equation you listed, F=\frac{Gm1m2}{r^2}, is the law of universal gravitation, which relates the gravitational force between two objects (in this case, Jupiter and its moon Europa) to their masses and the distance between them. The second equation, V=\sqrt{\frac{GM}{r}}, is the formula for the velocity of a satellite in orbit, which relates the mass of the central object (Jupiter) to the velocity and distance of the orbiting object (Europa).
To solve for the mass of Jupiter, you will need to use both of these equations and the given information about Europa's mass, velocity, and distance from Jupiter. I would suggest setting up the equations with the known values plugged in and solving for the unknown variable (in this case, the mass of Jupiter). It may also be helpful to double check your calculations and make sure you are using the correct units for each variable. Good luck!
1. How does the mass of Jupiter affect a moon's orbital velocity?
The mass of Jupiter has a direct impact on a moon's orbital velocity. According to Newton's law of universal gravitation, the force of gravity between two objects is directly proportional to their masses. Therefore, the greater the mass of Jupiter, the stronger the force of gravity, resulting in a higher orbital velocity for its moons.
2. Can the distance between Jupiter and its moons affect their orbital velocity?
Yes, the distance between Jupiter and its moons also plays a role in determining their orbital velocity. According to Kepler's third law of planetary motion, the square of the orbital period of a planet or moon is directly proportional to the cube of its semi-major axis, which is equivalent to its distance from the planet. This means that the further a moon is from Jupiter, the slower its orbital velocity will be.
3. How does a moon's mass affect its orbital velocity around Jupiter?
The mass of a moon does not have a significant impact on its orbital velocity around Jupiter. This is because the orbital velocity is primarily determined by the mass of the planet it is orbiting and the distance between them, as explained by Newton's law of universal gravitation and Kepler's third law of planetary motion.
4. Can the orbital velocity of a moon change over time?
Yes, the orbital velocity of a moon can change over time due to various factors such as gravitational interactions with other moons or planets, tidal forces, and changes in the shape of the planet's orbit. However, these changes are typically small and occur over long periods of time.
5. How can the mass of Jupiter be calculated if the mass, orbital velocity, and distance of one of its moons is known?
The mass of Jupiter can be calculated using the equation for orbital velocity, where the mass of the planet is equal to the cube of the distance between the planet and its moon, divided by the square of the moon's orbital velocity. However, this calculation assumes that the moon's mass is much smaller than Jupiter's, which is usually the case for natural satellites. To account for the moon's mass, more complex equations and data must be used.
