The Doppler Effect and Electromagnetic Waves
In summary, a distant galaxy emitted light that had a wavelength of A on Earth, but the light had a wavelength of B on the Earth. The question asked if the galaxy was receding from the Earth or approaching the Earth. The answer turned out to be the galaxy is receding from the Earth. I'm not sure I understand why though.
BoogieL80
39
I had a question. I did a problem where a distant galaxy emitted light that had a wavelength of A. On earth, the light had a wavelength of B. B ended up being greater than A. The question asked if the galaxy was receding from the Earth or approaching the earth. The answer turned out to be the galaxy is receding from the earth. I'm not sure I understand why though. I do understand that the frequency of light is less on Earth than in the galaxy, but get a little lost after that.
HINT: Wavelength varies inversely with frequency.
I understand that, but I still don't understand why that would mean the galaxy is receding from earth.
Take a plane for example, as the distance from the plane increases, the wavelenght of the sound wave increases. Since there is more distance for the wave to cover, it "spreads out". If you were to superimpose wave B over A, you would notice that the frequency (of B) has decreased. and the wavelength has increased.
So if wavelength B>A, this can only mean that the source of the light is receding.
You said you understood why the frequency is lower so I assumed that you did. If so, then all you need is a relationship between frequency and wavelength to complete the picture.
Tide, he said he understood THAT the frequency was lower ...
since wavelength was longer.
How a difference in frequency or wavelength arises from relative velocity
is simple for waves that travel in a material (like sound or water waves).
It is a bit trickier for "waves" that have no frame to propagate relative to.
While a car moves away from us through the air , the sound waves back
(that eventually reach our ears) travel through the air at the same speed
as the sound waves forward. So each sound wave back is farther from the sound source (car) than its simultaneously-made sound wave forward.
But I can't explain this for EM waves without knowing WHAT BoogieL knows
about reference frames and relativity.
lightgray,
Thanks. I missed that on first reading.
Boogie,
Suppose a source of radiation moves at constant speed. Over the course of one full period of oscillation an interval of time will have elapsed and an observer will see on full wavelength of the light emitted. The start of the wave will have traveled a distance [itex]c \Delta t[/itex] while the source will have moved [itex]v \Delta t[/itex] during that period so the wavelength an observer sees will be
[tex]\lambda ' = (c - v) \Delta t[/tex]
Classically, [itex]\Delta t[/itex] is just the period of oscillation or [itex]\lambda / c[/tex] so
[tex]\lambda ' = \frac {c-v}{c} \lambda[/tex]
which gives you the basic idea behind the Doppler shift. However, Einstein tells us that since the source and observer are moving relative to each other, their measures of time are different so we have to adjust for that and replace [itex]\Delta t[/itex] with
[tex]\frac {\lambda}{c \sqrt {1-v^2/c^2}}[/tex]
from which
[tex]\lambda ' = \lambda \sqrt{ \frac {1-v/c}{1+v/c}}[/tex]
Note that this is 1-dimensional and a simple geometric adjustment is necessary if the source is approaching or receding at an angle with repect to the observer.
Thank you.
1. What is the Doppler Effect?
The Doppler Effect is the change in frequency or wavelength of a wave in relation to an observer who is moving relative to the wave source.
2. How does the Doppler Effect apply to sound waves?
The Doppler Effect can be observed in sound waves when a source of sound is moving towards or away from an observer. As the source moves closer, the frequency of the sound waves increases, making the sound appear higher in pitch. As the source moves away, the frequency decreases and the sound appears lower in pitch.
3. How does the Doppler Effect apply to electromagnetic waves?
The Doppler Effect also applies to electromagnetic waves, such as light and radio waves. When a source of electromagnetic waves is moving towards or away from an observer, the frequency of the waves will shift, resulting in a change in the color of the light or the frequency of the radio waves.
4. What is the difference between the Doppler Effect for sound waves and electromagnetic waves?
The main difference between the Doppler Effect for sound waves and electromagnetic waves is the speed at which they travel. Sound waves travel at a much slower speed compared to electromagnetic waves, so the Doppler Effect is more noticeable in sound waves. Additionally, sound waves require a medium to travel through, while electromagnetic waves can travel through a vacuum.
5. How is the Doppler Effect used in real life?
The Doppler Effect has many practical applications, such as in radar technology, where it is used to detect the speed and location of moving objects. It is also used in medical imaging, such as Doppler ultrasound, to measure blood flow and detect abnormalities in the body. Additionally, the Doppler Effect is used in astronomy to measure the speed and distance of celestial objects.
  • Classical Physics
