Heat transfer by conduction in a truncated cone
In summary, the truncated cone 30cm high made of aluminum has a problem because the heat transfer rate is negative. The heat transfer rate is negative because the upper surface is maintained at 540 deg C while the lower surface is maintained at 93 deg C.
Kincaid
1. The problem statement
A truncated cone 30cm high is made of Aluminum. The dia at the top is 7.5cm, and 12.5cm at the bottom. The lower surface is maintained at 93 deg C, the upper surface at 540 deg C. the other surface is insulated. Assuming 1 dimensional heat flow, calculate the rate of heat transfer in watts.
2. Homework Equations
Conduction equation:
q/a=k(dt/dx)
3. The Attempt at a Solution
I have the k value from a textbook at 204 w/(m C)
Made the assumptions that k is not a function of x or t and that the rest of the cone is perfectly insulated besides the top and the bottom.
That being the case I simply plugged in the values using
q=k*(A1*T1-A2*T2)/x where T1 is the high temperature and T2 is the low temperature. x is the thickness.
I'm not sure if this involves some kind of integration though. I fear I may be oversimplifying the problem.
This question was asked previously in the forum but was unanswered.
Thanks for the help.
K
Perform a heat balance on the cone. Since the sides of the cone are perfectly insulated, the cone does not generate energy nor does it store energy, so the amount of heat entering the cone must balance the amount of heat leaving the cone.
Thanks
Matt
So then can it be said that
q1=k1A1T1
and
q2=k2A2T2
and the overall heat transfer is equal to q1/x?
Or are you saying that q=0?
Or do I need to use constant specific heats to solve this question to get the change in enthalpy and use that to get q?
I'm afraid this has just confused me further.
No. q is not equal to zero.
This is what I am saying,
Ein - Eout = 0 therefore Ein = Eout
No this is not needed.
Sorry to have confused you further. I will work on this later today.
Thanks
Matt
Let me give you a push in the right direction.
First let's find an expession for the area of the cone as a function of x.
let r1 = radius of the small end
let r2 = radius of the large end
let h = height of the cone
Then the function will be
r(x) = r1 + ((r2 - r1) / h)*x
The area as a function of x is A(x) = PI*r(x)^2
Therefore
A(x) = PI*(r1 + (((r2-r1)/h)*x)^2
Now using Fouriers law for one-dimensional heat conduction
Q' = -A(x)*k*(dt/dx)
Rearanging yields
Q'*(dx/(A(x)) = -k*dt
Now integrate the above function between 0 and h on the left hand side and integrate the right hand side between Th and To where Th = temperature on upper surface and To the temperature on the lower surface.
Remeber Q and PI are constant so they stay outside of the integral on the left hand side.
Think you can take it from here?
PS - This problem is stated in a slightly misleading manner because it is really a 2-dimensional problem and to bring it into a 1-dimensional problem the equation for the area as a function of x is required.
Thanks
Matt
Likes 1 person
Thanks so much. This makes it really clear.
Because the area is constantly changing as we move through the cone we must transform the area into terms of one of the available variables, in this case the height. Once this is done we can take the integral with respect to that variable in order to determine the values of the area at each individual point. This allows us to state the rate of heat flow through the cone as a whole instead of as a cylinder as I was doing before.
I don't know if I've verbalized the mathematics correctly but I feel I understand it much better.
Thanks
K
For the most part you are on the correct track. Again, sorry to have mislead you with the heat balance method.
I have the final answer, so when you complete the integrations and substitutions we can compare my result with yours.
Thanks
Matt
I think I must have made a mistake somewhere because I end up with a negative heat transfer which doesn't make sense.
My integration of dx/A(x) yields (1/PI)*(h/(r2-r1))*(r1+(r2-r1)*x/h)^-1*(-1) between 0 and h. This yields (1/PI)*(h/(r2-r1))*(1/r2)*(-1).
Multiplying this to the opposite side where the integration of -k(dT) between T1 and T2 yields k(T1-T2) gives me an answer of -1.49 kW.
Am I missing a sign somewhere or have I made a graver mistake?
I neglected the 0 part of the integration. I now have a value of 2.24 kW which makes more sense.
You have the right hand side integrated correctly.
The mistake is on the left hand side.
You are not far off though. Here is what I have. (Do you see your mistake?)
1/PI * (h/(r2-r1)) * (r1 + *((r2-r1)/h)*x)^-1 evaluated between 0 and h
Thanks
Matt
Looks like you have corrected yourself.
I have a final result of 2.216 kW.
The difference is simply the value of k that I used was 202 W/(m-C) as opposed to your value of 204 W/(m-C).
Glad to have helped you out.
Thanks
Matt
I am so thankful for your help on this. I feel like I have a much better understanding of the material now as well.
Thanks again
K
Where did you find this question? If it's possible, I'd like to know which book this comes from and the answer to it as well. Thank you!
1. How does heat transfer occur in a truncated cone?
Heat transfer by conduction in a truncated cone occurs when there is a temperature difference between the two ends of the cone. The heat energy is transferred from the region of high temperature to the region of low temperature through the solid material of the cone.
2. What factors affect heat transfer by conduction in a truncated cone?
The rate of heat transfer by conduction in a truncated cone is affected by several factors, including the thermal conductivity of the material, the surface area of the cone, and the temperature difference between the ends of the cone. The thickness of the material, as well as any insulating layers, can also impact the rate of heat transfer.
3. How does the shape of a cone affect heat transfer by conduction?
The shape of a cone can impact heat transfer by conduction in several ways. A truncated cone has a larger surface area compared to a regular cone, which can increase the rate of heat transfer. Additionally, the tapering shape of a cone can cause uneven distribution of heat, leading to variations in the rate of heat transfer along the length of the cone.
4. Is heat transfer by conduction in a truncated cone an efficient method of heat transfer?
Heat transfer by conduction in a truncated cone can be an efficient method of heat transfer, especially if the material has a high thermal conductivity and the temperature difference between the ends of the cone is significant. However, other factors such as the surface area and thickness of the material can also impact the efficiency of heat transfer.
5. How can heat transfer by conduction in a truncated cone be controlled or manipulated?
There are several ways to control or manipulate heat transfer by conduction in a truncated cone. This can be achieved by changing the material of the cone to one with a higher or lower thermal conductivity, altering the temperature difference between the ends of the cone, or adding insulation to reduce heat transfer. The shape and dimensions of the cone can also be modified to affect the rate of heat transfer.
9K
  • Mechanical Engineering
