Quantum Infinite Potential Well - Probability of Ground-State Energy
In summary, the conversation discusses a particle in an infinite potential well, with a given wave function. The normalization constant is found and the probability of measuring the ground-state energy is discussed. The expectation value for the Hamiltonian operator is also mentioned. The conversation ends with a question about finding the wave function of the ground state, which can be solved using the Schrödinger equation.
ARasmussen
A particle in the infinite potential well in the region 0 < x < L is in the state
[tex]\psi(x) = \begin{cases}
Nx(x-L) & \text{ if } 0<x<L \\
0 & \text{ if } otherwise
\end{cases}[/tex]
a) Determine the value of N so that the state is properly normalised
b) What is the probability that a measurement of the energy yields the ground-state energy of the
well?
c) What is the expectation value for the Hamiltonian operator for this state?
[tex]\int_{0}^{L}\left | \psi(x) \right |^{2} dx = 1[/tex]
[tex]prob(E_1) = \int_{0}^{L}\left | <\! E_1|\psi(x)\! > \right |^{2} dx[/tex]
[tex]<E_1|=\frac{\hbar^{2}\pi^{2}}{2mL^{2}}[/tex]
For part a, I used the first equation to solve for N, and I got [tex]\sqrt{\frac{30}{L^{5}}}[/tex]. Part b is where I began to get confused.
Given the equations above for prob([tex]E_1[/tex]), and [tex]<E_1|[/tex], I'm unable to figure out how to find the probability that the energy state is in the ground state.
Any hints?
Thanks
You found the normalization constant correctly, but the last two of your equations aren't correct. The energy E1 of the ground state [itex]|\phi_1\rangle[/itex] is equal to [itex]E_1 = \hbar^2\pi^2/2mL^2[/itex].
The amplitude that the particle is in the ground state [itex]|\phi_1\rangle[/itex] is given by
[tex]\langle \phi_1 | \psi \rangle = \int \phi_1^*(x)\psi(x)\,dx[/tex]
where [itex]\phi_1(x)[/itex] is the wave function of the ground state. The probability P that the particle is in the ground state is equal to the modulus of the amplitude squared: [itex]P = |\langle \phi_1 | \psi \rangle|^2[/itex].
Thanks for the reply. How would I go about finding the wave function of the ground state?
The infinite square well problem is likely already solved in your textbook or your notes, and you can just look up what the eigenstate wave functions are. If not, you need to solve the Schrödinger equation with the appropriate potential and boundary conditions.
for your question!
For part b, you can use the second equation to find the probability that a measurement of the energy yields the ground-state energy. The <E_1| term can be substituted with the given value of <E_1|, and then <\! E_1|\psi(x)\! > can be substituted with the given \psi(x) function. The resulting integral can then be solved to find the probability.
For part c, the expectation value for the Hamiltonian operator can be found using the formula <\psi|H|\psi>, where H is the Hamiltonian operator. In this case, the Hamiltonian operator for the infinite potential well is given by H = -\frac{\hbar^{2}}{2m}\frac{\partial^{2}}{\partial x^{2}}. You can substitute this into the formula and use the given \psi(x) function to solve for the expectation value.
What is a Quantum Infinite Potential Well?
A Quantum Infinite Potential Well is a theoretical model used in quantum mechanics to describe the behavior of a particle confined to a certain region with infinite potential energy barriers on either side. It is often used to explain the behavior of electrons in an atom.
What is the Probability of Ground-State Energy in a Quantum Infinite Potential Well?
The probability of ground-state energy in a Quantum Infinite Potential Well is the likelihood that a particle will be found in the lowest possible energy state within the well. This probability is determined by the wave function of the particle, which describes the probability of finding the particle at a particular location within the well.
How is the Probability of Ground-State Energy Calculated?
The probability of ground-state energy in a Quantum Infinite Potential Well can be calculated using the Schrödinger equation, which describes the time evolution of the particle's wave function. The ground-state energy can also be determined by solving the Schrödinger equation for the lowest energy state.
What Factors Affect the Probability of Ground-State Energy?
The probability of ground-state energy in a Quantum Infinite Potential Well is affected by the width and depth of the well, as well as the mass of the particle. A wider or deeper well will result in a lower probability of finding the particle in the ground-state energy due to the increased energy levels available to the particle.
How Does the Probability of Ground-State Energy Change as the Particle's Mass Increases?
As the mass of the particle increases, the probability of ground-state energy in a Quantum Infinite Potential Well decreases. This is because a heavier particle has a shorter de Broglie wavelength, which means it is less likely to be confined to the lower energy levels in the well. As a result, the particle is more likely to have a higher energy state, leading to a lower probability of being in the ground state.
