Finding velocity and work involving friction Work Energy
In summary: Yes, you are correct. In this scenario, the work done by static friction is negligible since the distance over which it acts is very small. So, in your calculation of net work, it is not necessary to include the work done by static friction.
AddversitY
There are three boxes stacked on top of each other. Each of the boxes has a mass of 250 kg. There is a chord attached to the bottom box applying a force of 7,000N. The coefficient of static and kinetic friction are: μs = .950 and μk = .900. What is the work net if the boxes are pulled 5 meters? What is the change (change) in velocity of the boxes if they're moved 5 meters?
Work = mass*acceleration*distance
Work = F*d
friction = μ * Normal Force
Total mass of the boxes is 750kg. I'm guessing I have to find the Work done by friction and subtract it from the work done by the force.
The amount of work done to the box is 7,000N*5m which is 35,000 J.
The work done by kinetic friction is μk*Normal Force
= .900*(750kg*cos(0°))
= 675 N * 5m
= 3,375 J of work against the boxes as they slide 5 meters.
The work done by static friction is μs*Normal Force
= .950*(750kg*cos(0°))
= 712.5 N
= 712.5N* <--------------So far is this right? What do I do next from here if this is right since static friction doesn't cover any distance?
Work = F*d
yes
that's the work done on the boxes by the applied force, yes
= 675 N * 5m
you forgot to multiply the total mass by 9.8 to get the normal force
= 712.5 N
Does static friction between the floor and boxes apply here if the boxes are moving?
PhanthomJay said:
yes that's the work done on the boxes by the applied force, yes you forgot to multiply the total mass by 9.8 to get the normal force Does static friction between the floor and boxes apply here if the boxes are moving?
From what I have researched they do not. The static friction can be discarded since static friction moves over a negligible distance. Here's my new attempt to solve for the work done on the boxes as they are pulled 5m.
There are two forces acting upon the boxes. The rope and friction, friction is the resistive force.
The work done by the rope is as follows:
Wr = F*d
= 7,000N*5m
= 35,000 J
The work done by friction is as follows:
Wfriction = μk*N
= .900*750kg*9.8m/s^2*cos(0°)*5m
= 33,108.75 J
μs is disregarded because it has no effect on the work because the distance = 0 in its equation.
So, since friction is resistive force it is subtracted: 35,000 J - 33,108.75 J = 1,891.25 J ^Final answer. Is this correct?^
No how would I begin to calculate the change in velocity of the boxes if they moved 5 meters?
I can assume that initial velocity is 0.
So, Wnet = .5(m)(v)^2 - .5(m)(vinitial)^2
1,891.25 J = .5(750kg)(v^2) - .5(750kg)(0)^2
1,891.25 = 375*v^2 - 0
5.0433333 = v^2
v = 2.25 m/s
Does that seem right?
Your explanation is wrong. Static friction is present only when things are static i.e. when the two surfaces are not sliding relative to each other. In the situation where the two surfaces are sliding relative to each other, kinetic friction is the type of friction that is present.
Wr = F*d
= 7,000N*5m
= 35,000 J
Wfriction = μk*N
= 33,108.75 J
Yes, this is the total (or net) work done, but round it off to 1900 J (2 significant figures)
5.0433333 = v^2
v = 2.25 m/s
looks good!
I do not understand. In my scenario, I am attempting to calculate work. I am dealing strictly with distance. It definitely creates a resisting force. Is that not irrelevant when dealing with work, though, since distance would equal 0?
I don't understand what you're asking. All I did was explain: 1. under what conditions static friction is present and 2. under what conditions kinetic friction is present. I didn't say anything about your particular scenario.
"The static friction can be discarded when solving for work since static friction moves over a negligible distance."
Is this now correct statement now?
I just doesn't make any sense at all to say "the static friction moves", because the static friction is a force. An object can move under the influence of a force. A force itself cannot "move." It's not meaningful to say that.
What actually happens is that since the force that the person is applying (using the cord) is larger than what static friction can supply, static friction is overcome immediately, and the boxes begin moving. Since the boxes are now moving, the only form of friction that is present is kinetic friction. One can speak of the work done by kinetic friction because this force is present while the displacement is occurring.
I understand it now. Thank you!
1. What is the definition of velocity?
Velocity is a measure of the speed and direction of an object's motion. It is a vector quantity, meaning it has both magnitude (speed) and direction.
2. How do you calculate velocity?
Velocity can be calculated by dividing the displacement of an object by the time it took to travel that distance. This can be represented by the formula v = d/t, where v is velocity, d is displacement, and t is time.
3. How is work defined in terms of physics?
In physics, work is defined as the product of force and displacement. It is a measure of the energy transferred to an object when a force is applied and the object is moved in the direction of the force.
4. How do you calculate work involving friction?
To calculate work involving friction, you need to consider the force of friction, which is the force that opposes motion between two surfaces in contact. The work done by friction can be calculated by multiplying the force of friction by the distance the object moves in the opposite direction of the force.
5. What is the relationship between work and energy?
Work and energy are closely related concepts in physics. Work is the energy transferred to an object when a force is applied, while energy is the ability to do work. The work-energy theorem states that the work done by all the forces acting on an object is equal to the change in the object's kinetic energy.
