New Reply
thickness of graphene
Share Thread Thread Tools
Jan23-13, 10:07 AM   #1
Hello,
I was just wondering what the theoretical thickness of single layer graphene is?
Thanks in advance for any feedback.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Study provides better understanding of water's freezing behavior at nanoscale
>> Iron-platinum alloys could be new-generation hard drives
>> Promising doped zirconia
Jan23-13, 10:46 AM   #2
A single layer of graphene would be one atom thick, carbon.
Jan23-13, 10:47 AM   #3
Do you know the answer in Angstroms?
Jan23-13, 10:50 AM   #4
1 Angstrom is .0000000001 meters, carbon is 1.54 Angstroms
Jan23-13, 10:52 AM   #5
a carbon atom is not the same thing as graphene. do you know the thickness of graphene in Angstroms?
Jan23-13, 11:01 AM   #6
Admin
Quote by kevinisfrom View Post
This paper might give some clues
http://arxiv.org/pdf/0812.0690.pdf
Jan23-13, 11:02 AM   #7
A carbon atom is not the same thing as graphene but a "sheet" of carbon atoms is. 1 layer thick sheet of graphene is one atom thick. Wrap it in a cylinder, you have a carbon nanotube, put it in a ball you have a buckyball, stack one sheet of graphene on one sheet of graphene you have graphite. I could be wrong, I am no expert.
Jan23-13, 11:16 AM   #8
Hi Greg, thank you for the reply. Your link is an experimental paper. I was hoping for the theoretical value of graphene's thickness, and also the interlayer spacing between graphene sheets in graphite.
Jan23-13, 11:16 AM   #9
There are sp2 bonds between C atoms. It's different from an isolated atom.
Jan23-13, 11:44 AM   #10
Hello,
Thickness is a confusing quantity. You should define how you relate thickness of something with actual length between two particular points in that something.
Again this depends on what is the definition of thickness.
AFM depends on Coulombic repulsion to measure thickness. Its hard to tell exactly where is the surface of the layer. Or how do you define the surface of the layer.
Quote by NeedBranes View Post
True in a sense. The "thickness" of graphene is one carbon atom "thick".
Jan23-13, 11:49 AM   #11
Thanks for the replys. I know there is a widely accepted theoretical value for the thickness, considering all the atom-atom interactions and whatnot. It's just a number. I understand there is a lot to consider when doing AFM scans, but there should be a simple answer to this question theoretically. I knew it once, but have since forgotten.
Jan23-13, 12:05 PM   #12
I can give a very naive answer. Try C-C bond length/2 as the radius of the atom. Then the thickness becomes just C-C bond length. Of course it complicates with the nature of bonds or other elements etc.
Also, you can use non-bonding p-orbital electrons of sp2 for rough thickness calculation. Just take the mean radius of their orbital. But then again it will register different in AFM as after bonding with AFM tip, the electronic configuration might change.
New Reply
Thread Tools
Similar Threads for: thickness of graphene
Thread Forum Replies
DOS of graphene General Physics 0
Building a graphene shell or other graphene hollow structures on the PC Atomic, Solid State, Comp. Physics 0
Graphene visibility vs. SiO2 thickness Atomic, Solid State, Comp. Physics 0
two dirac cones are described by two bi-spinors of different chirality Atomic, Solid State, Comp. Physics 5
DFT and Graphene Atomic, Solid State, Comp. Physics 6
