- #1
PeachBanana
- 191
- 0
The figure shows a model of a crane that may be mounted on a truck. A rigid uniform horizontal bar of mass = 90.00 kg and length = 5.200 m is supported by two vertical massless strings. String A is attached at a distance = 1.600 m from the left end of the bar and is connected to the top plate. String B is attached to the left end of the bar and is connected to the floor. An object of mass = 3000 kg is supported by the crane at a distance = 5.000 kg from the left end of the bar.
Throughout this problem, positive torque is counterclockwise and use 9.807 m/s^2 for the magnitude of the acceleration due to gravity.
Find the tension in string A.
This problem let's you use hints and it suggested I use the following equation with having the Tension in String "B" as the origin.
Tension A(1.6000m) - (90.00 kg)(9.807 m/s^2) 1/2(5.200 m) - (3000 kg)(9.807 m/s^2)(5.000 m) = 0
I don't understand the "1/2" part in front of the length mass one. Is that because of where it is placed or its moment of inertia?
