How to pick FUSE
by chinrose
Tags: fuse, pick
chinrose
chinrose is offline
#1
Jul14-13, 07:57 PM
P: 5
Hi Guys,
I was finish with my load calculation, and now my problem is what fuse to use. As i surf the net there are lots of Fuse to be found in the market. Although my calculation is base only in theoretical basis, so my question is when to use this following fuse.
1.) Controlled vented power fuse
2.) expulsion fuse unit
3.) Nonvented power fuse
4.) power fuse unit
5.)vented power fuse
i was lost as for theory the use of FUSE is for over-current protection.
Phys.Org News Partner Engineering news on Phys.org
Lifting the brakes on fuel efficiency
PsiKick's batteryless sensors poised for coming 'Internet of things'
Researcher launches successful tech start-up to help the blind
Simon Bridge
Simon Bridge is offline
#2
Jul15-13, 02:26 AM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
Simon Bridge's Avatar
P: 10,990
You want your fuse to protect delicate components against current spikes.
The fuses will have a rated current (at which they "blow") and they will also take some time to blow.
As a side-effect of blowing, hot gasses and solid material will be expelled from where the fuse is.
You have to balance this against what you are protecting.
http://www.electrical-knowhow.com/20...urse-ec-1.html
jim hardy
jim hardy is offline
#3
Jul15-13, 09:07 AM
Sci Advisor
jim hardy's Avatar
P: 3,138
For theory, check Littlefuse's "Fuseology" article.
Register to reply
Related Discussions
Fuse Question Electrical Engineering 6
If a fuse repeatedly blows, it should be replaced by a fuse of one step higher rating Introductory Physics Homework 7
Fuse blows Electrical Engineering 9
fuse wires Introductory Physics Homework 2
Why is the fuse blowing? Electrical Engineering 6
