Shape Shape-shifting strings solids, liquids, and gasses
In summary, the conversation revolved around a theory proposing that strings, in various shapes and states, may explain the different forms of matter such as plasma, hydrogen, helium, and neutrons. This theory suggests that a string in the shape of a torus could represent an atom of hydrogen and that different types of spin could result in two distinct forms of hydrogen. The conversation also touched on the idea that space itself could be a high energy state of helium. However, the validity of these ideas is still questionable and further discussion is encouraged in the Independent Research Forum.
Silvercloud
For your thoughts... a theory of mine...
A Method by which shape shifting strings may explain:
1. Plasma
2. Hydrogen
3. Helium
4. Neutrons
5. Gasses
6. Liquids
7. Solids
Consider the following:
If a string, was a string, in shape, in only one STATE of its existence, then one might readily explain why a solid is a solid, why a liquid is a liquid, and why a gas is a gas, and how it becomes hydrogen, helium, and neutrons..
If the SHAPE of a string occurred, as a string, only as, or in, plasma, and took on other SHAPES, as it changed states, then I propose the following:
1. Plasma is only one STATE of a string, one which is not normal except in suns and similar situations. As plasma, it has the “string” shape.
2. Under less stressful situations, the string could be a closed loop, a torus. This represents an atom of hydrogen. A torus is a shape that can have TWO distinct kinds of spin. It can spin about a central axis, and the “tire shape” can also roll on itself. This establishes the possibility of TWO kinds of spin. A left, and right spinning torus… two distinct kinds of hydrogen, a left, and a right spinning torus. Should two of these opposite spinning tori meet, they would immediately be inclined to form a molecule of hydrogen.
3. If, in a solar flare, one of the tori of hydrogen were to “break”, even temporarily, it might combine with an opposite spinning torus of hydrogen, and form a loop around the “doughnut” of the other torus… helium… two tori locked quite happily together.
4. If a “string” of hydrogen were excited to become “super-stretched” it might knot itself, upon collapse, into a trefoil, a neutron.
5. There is no ready explanation for solids, liquids, and gasses. If a torus of hydrogen was a high energy state (and it is), then the torus of hydrogen is a gas.
6. If the diameter of the hole, in the torus of hydrogen, becomes less than one third of the average, overall diameter of the torus, then it will begin to condense into a liquid. When the “hole” finally disappears, what is left is a spheroid… a liquid.
7. If the spheroid losses its spin, then it will collapse into the last gasp effort to hold back the pressure of the universe, it will become a shape with the least number of faces, edges, and vertices… a tetrahedron, a solid.
Solids are characterized by having flat surface faces, edges, and vertices. As there are liquids that exhibit the characteristics of a solid, this is easily explained by a flattened spheroid… not quite liquid, not quite solid… two flat surfaces, but no vertices.
It may well be, in addition, that SPACE, itself, is nothing more than a highly charged, or high energy state of helium.
I do not know how to do calculus, so I can offer no math to support this concept. I discovered this concept while writing my soon to be published book, a book meant to be a conjoining of real science and history and pseudo science. Danged if the concept doesn't seem to work. Go figure.
Maybe it will inspire some thoughts...
:smile:
Atoms are not strings.
That's not quantum mechanical spin.
Actually, there is.
Equating something like classical thermodynamics with topological properties of quantum objects is almost impossible.
Space is not charged on average. It also, unlike helium, has no mass.
Dear PF member,
This thread has been locked because it contains opinions that are contrary to those currently held by the scientific community. This is against the Posting Guidelines of Physics Forums. If you would like to discuss your ideas, we invite you to submit a post to the Independent Research Forum, subject to the applicable guidelines, found https://www.physicsforums.com/showthread.php?t=82301.
We appreciate your cooperation, and hope you enjoy the Forums.
The Staff of Physics Forums
1. What is shape-shifting?
Shape-shifting is the ability of a material to change its physical form or structure in response to external stimuli such as temperature, pressure, or light.
2. How do shape-shifting strings work?
Shape-shifting strings are made of a material that can undergo reversible changes in its molecular structure when exposed to certain triggers, causing the string to stretch or contract and change its shape.
3. Can solids, liquids, and gases all undergo shape-shifting?
Yes, all three states of matter can exhibit shape-shifting properties. Solids can change their shape through processes such as melting or crystallization, liquids can change their shape through flow or evaporation, and gases can change their shape through compression or expansion.
4. What are some potential applications of shape-shifting materials?
Shape-shifting materials have a wide range of potential applications, including in the fields of medicine, robotics, and building materials. They can be used to create self-healing structures, responsive textiles, and adaptable medical devices, among others.
5. Are there any limitations to shape-shifting materials?
While shape-shifting materials have many potential uses, there are also limitations to their capabilities. For example, they may not be able to withstand extreme temperatures or pressures, and their shape-shifting abilities may degrade over time with repeated use.
  • Science Fiction and Fantasy Media
  • Beyond the Standard Models
  • Atomic and Condensed Matter
  • High Energy, Nuclear, Particle Physics
  • Electromagnetism
