Understanding Electron Flow in a Wire: Doubts and Explanations
In summary, the book says that an electron will emerge with an acceleration a = -eE/m. This acceleration is due to the electric field and is uniform throughout the wire. The current must be the same throughout the wire, otherwise charges will build up until the current is the same.
Ashu2912
107
Hi friends! I know this is a question many people might have posted on the forum. I saw many threads but still have some doubt in my mind, about why do electrons flow in a wire when we attach a battery to it. Being more specific, my doubts are as follows :-
(1) My book says that an electron will emerge with an acceleration a = -eE/m. How come it emerges with uniform acceleration when electric field is applied. That too when it suffers collisions and moves under random motion, i.e. how can we be so decisive about it's acceleration? Then they have applied formula for uniform acceleration : v = u + at.
(2) How come the electric field in the wire is uniform throughout?
(3) I also need some detail about the random motion of the electrons before and after the field is applied, i.e. the path when the flow of the electrons is biased in one direction.
In between collisions, the only force on the electrons is that of the electric field. Note that they are talking about the component of the velocity in the direction of the field.
The current must be the same throughout the wire, otherwise charges will build up until the current is the same. Since the wire is uniform, there is a fixed relationship between current and field throughout the wire.
With no field applied, the electrons exhibit random thermal motion. When the field is applied, it exerts a force in the direction of the wire. Thus an acceleration is imposed on top of the random motion, which ends up giving the electrons a drift velocity along the wire.
I thought in conducting wire, velocity [itex] u_e = \mu_e \vec E[/itex]. Where [itex] \vec E [/itex] is develope due to voltage drop across the wire. The better the conductivity, the slower the velocity because the [itex] \vec E [/itex] is smaller.
That's the average velocity. Individual electrons, however, constantly accelerated due to electric field, and loose their velocity whenever they "collide" with the lattice. Naturally, it's all a whole lot more complicated due to quantum mechanics, but this simple model let's you predict a lot of properties of the conductor.
Can you please explain it in a better way because I didn't understand this?
Do you mean the acceleration in the direction of the field? However, since the electrons move in random motion even when the field is applied, don't you think that we must analyse their motion in multiple dimensions? Does the force from the nuclei and other electrons get canceled as in the static situation? But then why do the move randomly even if the electric field, and thus force on them is in one direction?
what book are you using??
Maybe if I give you a "catch name", you might be able to look it up. Search for The Drude Model, or open a solid state physics text such as Kittel or Ashcroft/Mermin. The Drude model will give you a treatment of electron transport in metals by using the free-electron gas approximation. It is a purely classical treatment using the standard Maxwell-Boltzmann statistics.
Zz.
I made several statements. Which are you referring to? The key is that the current must be the same throughout the wire, else charges will build up and throttle the current flow.
Yes.
Not really, at least to draw some crude conclusions. (The model used by your book--I assume--is a simplified version of the Drude model mentioned by ZapperZ. And that model is itself only a classical approximation to a fuller treatment. But it's good enough. What book are you using, by the way?)
I think you're asking if the inside of the wire is electrically neutral. Yes.
There is a relatively high speed random thermal motion of electrons in the wire. With no field, the average velocity of the electrons is zero. (Not net motion along the wire.) When you impose an electric field, the electrons are accelerated in the direction of the wire (in between collisions with the lattice), so there is now a net motion of the electrons. This is the 'drift velocity'.
Picture it this way. With no field, the electrons move in straight lines in all directions (in between collisions with the lattice). With a field, those straight lines are now parabolic paths (much like a projectile in a gravitational field), with a net displacement in the direction of the force on them.
I am using the NCERT textbook (CBSE textbook in India) for Class 12th.
OK. I'm not familiar with that particular text.
I am a student studying in Grade 12 in India under the CBSE board and use the NCERT textbook prescribed by the board. Indeed, the book explains the phenomenon on the basis on the basis of the Kinetic theory of gases (Boltzmann and Maxwell). Thanks for your valuable replies.
Here, I am referring to the electric field (and thus electrostatic force) of the nuclei and other free electrons on an electron under consideration!
Will Fundamentals of Physics by Resnick, Halliday and Walker do good?
So am I. I'd say that except during a collision, there's no electric field to worry about due to the charged particles within the wire. It's electrically neutral.
I used (many years ago) the original version and thought it was pretty good. So perhaps the current version is good as well.
Haliday and Resnick are the best physics teachers. They made me love physics.
Here is a common problem that I see in many posts, and it should be clarified once again.
In a conductor, numerous atoms have come together to form this solid. When that occurs, the individual properties of the atoms no longer dominates. Rather, the collective properties of these many atoms now take over, at least, for many of the common properties of solids that we encounter. For example, a copper atom does not "conduct", but a copper metal does!
When many of these atoms combine to form a conductor, there are bands of states called the conduction band. In this band, there is a sea of conduction electrons that are free (or pseudo-free) to move. Here, depending on what approximation that you make, these electrons are truly free, meaning they do not see the nucleus potential at all. This is the Drude model of conduction electrons where the electron form a free particle gas. The Bloch model, on the other hand, will have some periodic potential to represent the location of the ions in a crystal lattice.
The moral of the story here is that, once we have a conductor, and once you ask about motion of electrons in a conductor, you need to stop thinking about "atoms". Rather, the conductor how has its own set of properties, and the conduction electrons are governed by those properties.
Zz.
Do you mean that the motion of the electrons in the conductor is completely random and not affected by the electric field due to the ions and other electrons? Or perhaps, I may be thinking too deep, i.e such internal forces come under the domain of quantum physics and are not required in the Drude model.
Let me sum up this topic on what I have inferred until now:-
The motion of the electrons in a conductor is completely random, attributing to the thermal motion, and not affected by the fields due to ions and other electrons. In the static situation, there is no current in the wire, and the only motion of the electrons is the random thermal motion. There is current in the wire only when there is a field due to a battery, or other emf device, due to the electric field. Current is a result of a biased flow of electrons in one direction, which is caused by the external electric field. The Drude model (as per my textbook explanation), takes into account this electric field and the average properties of the motion of the electrons and applies v = u + at, where v, u, a and t are averaged for all electrons and a = -eE/m. where a is the accelaration of an electron due to external electric field only as the internal electric fields are rejected.
However, I still do not understand why is the electric field is uniform (sorry to ask again, but the previous explanation could not be understood by me)...
Thanks, all, my concept about the Drude model is much clearer now!
Do you agree that the current must be the same throughout the wire?
Yes, due to the conservation of charge.
1. What is electron flow in a wire?
Electron flow in a wire refers to the movement of electrons through a conductive material, such as a wire. This flow of electrons is what allows for the transfer of electrical energy and the functioning of electronic devices.
2. How does electron flow differ from current flow?
Electron flow and current flow are essentially the same concept, but they are described differently based on the direction of flow. Electron flow describes the movement of electrons from negative to positive, while current flow describes the movement of positive charge from positive to negative.
3. What factors affect the speed of electron flow in a wire?
The speed of electron flow in a wire is influenced by the material of the wire, as well as its length and cross-sectional area. Thicker wires and materials with higher conductivity allow for faster electron flow, while longer wires and materials with lower conductivity can slow down electron flow.
4. How does resistance affect electron flow in a wire?
Resistance is a measure of how difficult it is for electrons to flow through a material. Higher resistance means that it takes more energy to move electrons through the wire, which can slow down electron flow. This is why thinner wires or materials with higher resistance can limit the flow of electrons.
5. Can electron flow be reversed in a wire?
Yes, electron flow can be reversed by changing the direction of the electric field. This can be achieved by switching the negative and positive terminals of a battery or by changing the direction of the alternating current in a circuit. However, the direction of current flow will also be reversed in this process.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
