Paradox with elementary submodels of the constructible tower
In summary: This is because for any \delta, we can find some \beta>\delta such that L_\beta \equiv L_\alpha, and then Hull(\{\delta\},L_\beta) will be a countable elementary submodel of L_\alpha. So the set of \delta's is bounded above by the first ordinal where L_\alpha and L_\beta are elementarily equivalent.
Amir Livne
38
This is an argument I thought up after a class on combinatrical properties of the model [itex]\textbf{L}[/itex]. Our course is about set theory, not logic, so this paradox desn't seem relevant in its context. Can you help me figure out where I got it wrong?
The constructible heirarchy of sets is a series [itex]L_{\alpha}[/itex] that is defined for all ordinal numbers [itex]\alpha[/itex]. The important properties for my argument are:
  1. [itex]L_{\alpha}[/itex] is transitive for every [itex]\alpha[/itex]
  2. If [itex]\alpha < \beta[/itex], then [itex]L_{\alpha}\subset L_{\beta}[/itex]
  3. The transitive collapse (aka Montowski collapse) of every elementary submodel [itex]M \prec L_{\alpha}[/itex] is [itex]L_{\beta}[/itex] for some [itex]\beta[/itex]
  4. [itex]L_{\omega_{1}}[/itex] satisfies "every set is countable" and [itex]L_{\omega_{2}}[/itex] does not
  5. [itex]L_{\alpha}[/itex] is coutable iff [itex]\alpha[/itex] is countable
So, we take an countable elementary submodel (CESM) [itex]M_{1} \prec L_{\omega_{1}}[/itex], and look at its transitive collapse, [itex]L_{\alpha_{1}}[/itex] for some countable [itex]\alpha_{1}[/itex]. We then take an CESM [itex]M_{2} \prec L_{\omega_{2}}[/itex] that contains [itex]L_{\alpha_{2}}[/itex], and collapse it to get [itex]L_{\alpha_{2}}[/itex] with countable [itex]\alpha_{2}[/itex]. Then the same procedure yields a model [itex]L_{\alpha_{3}} \supset L_{\alpha_{2}}[/itex] that has an elementary embedding into [itex]L_{\omega_{1}}[/itex]. We generate an infinite series, switching between modelling [itex]L_{\omega_{1}}[/itex] and [itex]L_{\omega_{2}}[/itex].
The limit [tex]L_{\alpha}=L_{\lim_{n<\omega}\alpha_{n}}=\bigcup_{n<\omega}L_{\alpha_{n}}[/tex] is then the union of both subseries [itex]\{L_{\alpha_{n}}\}_{n=1,3,\ldots}[/itex] and [itex]\{L_{\alpha_{n}}\}_{n=2,4,\ldots}[/itex]. But a union of a series of elementary submodels is itself an elementary submodel, since it is a direct limit. In particular [itex]L_{\alpha}[/itex] should be elementary equivalent to both [itex]L_{\omega_{1}}[/itex] and [itex]L_{\omega_{2}}[/itex]. This is impossible because of property (4), namely there is a statement true in one and not in another.
Where did I go wrong in my reasoning? All kinds of tips are appreciated...
"The union of elementary submodels is itself an elementary submodels" is only true when those submodels are elementary substructures of one another. This means more than just the fact that [itex]L_{\alpha_n} \subset L_{\alpha_{n+2}}[/itex] and [itex]L_{\alpha_n} \equiv L_{\alpha_{n+2}}[/itex], it requires that the inclusion map is the elementary embedding. This would be the case if the [itex]L_{\alpha_n}[/itex] were elementary substructures of their respective [itex]L_{\omega_i}[/itex], but they're generally not. You do get that they're elementarily equivalent subsets of their respective [itex]L_{\omega_i}[/itex], but the inclusion maps are not typically the elementary embeddings. The embeddings here are the inverses of the Mostowski collapses.
Nothing I said above proves that the inclusion maps aren't elementary embeddings, although nothing you said proves that they are. But here's why they're definitely not. Let's take for example [itex]L_{\omega_2}[/itex]. For the same that GCH holds in L, we know that [itex]L_{\omega_2}[/itex] thinks there is exactly one cardinal after [itex]\omega[/itex], and that this cardinal is [itex]\omega_1[/itex]. If [itex]L_{\alpha} \equiv L_{\omega_2}[/itex] with [itex]\alpha[/itex] countable, then this structure will also think there's a unique cardinal after [itex]\omega[/itex], but it won't think [itex]\omega_1[/itex] is it.
I see what you mean...
So, it seems that for every ordinal [itex]\alpha[/itex], the set [itex]\{\delta < \omega_{1} \mid L_{\delta} \prec L_{\alpha}\}[/itex] is closed w.r.t taking limits. I thought about it some more and it's not hard to see this set is unbounded for [itex]\alpha = \omega_{1}[/itex], since for each [itex]\beta < \omega_{1}[/itex] you can find find some [itex]L_{\beta'}[/itex] with [itex]\beta<\beta'<\omega_{1}[/itex] that is closed w.r.t Skolem functions of [itex]L_{\omega_{1}}[/itex]. This natually means that the set of δs can't be unbounded for [itex]|\alpha|>\aleph_{1}[/itex].
Correct. Another simple argument is to do the following construction:
  • [itex]X_0 = Hull(\{\beta\},L_{\alpha})[/itex]
  • [itex]\beta_0 = \min\{\gamma : X_0 \subset L_\gamma\}[/itex]
  • [itex]X_{n+1} = Hull(L_{\beta_n},L_\alpha)[/itex]
  • [itex]\beta_{n+1} = \min\{\gamma : X_n \subset L_\gamma\}[/itex]
  • [itex]L_{\beta'} = \bigcup X_n[/itex]
Here [itex]Hull(X,M)[/itex] denotes some Skolem Hull of the set X in the structure M. Since we're working with L, there's a canonical choice for such hull.
Indeed, the set of such [itex]\delta[/itex]'s is empty!
I can provide some insights into your argument and help you understand where you may have gone wrong. First, it is important to note that the constructible heirarchy of sets, L_{\alpha}, is a well-defined and consistent model within set theory. It follows the axioms of Zermelo-Fraenkel set theory with the addition of the axiom of constructibility, and it has been extensively studied and used in various areas of mathematics.
Now, let's take a closer look at your argument. While it may seem valid at first glance, there are a few key points that need to be addressed. Firstly, the statement "L_{\alpha} is elementary equivalent to both L_{\omega_{1}} and L_{\omega_{2}}" is not necessarily true. The fact that L_{\alpha} is a union of two subseries does not necessarily mean it has the same properties as each individual submodel. This is because the union of two elementary submodels may not be an elementary submodel itself.
Secondly, the property (4) that you mention, "there is a statement true in one and not in another," is not a contradiction. This is because L_{\omega_{1}} and L_{\omega_{2}} are models of different sizes, and therefore, it is not surprising that they may have different properties. In fact, this is one of the key features of set theory - the existence of models of different sizes.
Lastly, it is important to note that the constructible heirarchy is not a countable model. It is a model of size \aleph_{1}, which is the first uncountable cardinal number. Therefore, your argument using countable elementary submodels is not applicable to the constructible heirarchy.
In conclusion, while your argument may seem plausible, it is ultimately flawed due to the assumptions and properties that you have used. It is always important to carefully analyze and check the validity of any argument, especially in the field of mathematics where precision and rigor are essential. I hope this helps you understand where you may have gone wrong and provides some tips for future arguments.
1. What is a paradox with elementary submodels of the constructible tower?
A paradox with elementary submodels of the constructible tower refers to a situation where certain mathematical structures within the constructible hierarchy (a set-theoretic model of Zermelo-Fraenkel set theory) exhibit contradictory properties, leading to a logical inconsistency.
2. How does the paradox arise?
The paradox arises when attempting to construct a submodel of the constructible universe that satisfies certain properties. This submodel, known as an elementary submodel, must adhere to the same axioms as the larger constructible universe, but can potentially lead to a contradiction when trying to satisfy specific properties.
3. What are some examples of paradoxes with elementary submodels of the constructible tower?
One example is the Löwenheim-Skolem-Tarski paradox, which involves the existence of a countable submodel of the constructible universe that satisfies the same properties as the entire universe. This leads to a contradiction since the entire universe is uncountable. Another example is the Skolem paradox, where a countable elementary submodel of the constructible universe is able to prove the existence of uncountable sets, contradicting the standard axioms of set theory.
4. How do mathematicians address these paradoxes?
Mathematicians have proposed various solutions to these paradoxes, including modifying the axioms of set theory or introducing additional axioms to restrict the construction of elementary submodels. Ultimately, the resolution of these paradoxes is an ongoing topic of research in the field of set theory.
5. What are the implications of these paradoxes?
The paradoxes with elementary submodels of the constructible tower have significant implications for the foundations of mathematics and the study of set theory. They highlight the importance of carefully examining the assumptions and axioms used in mathematical constructions and the potential for logical inconsistencies in seemingly well-defined systems.
  • Linear and Abstract Algebra
  • Math Proof Training and Practice
9K
  • Classical Physics
20K
