- #71
PeterDonis
Mentor
- 45,635
- 22,657
rjbeery said:Actually, I don't see these as mucking anything up. On a philosophical level, I think the concept of infinity has no physicality whatsoever and the Universe should be able to be described without it.
Using the proper coordinate chart, the entire black hole spacetime, including the portion below the horizon, can be described without using the concept of infinity. So your requirement is met.
rjbeery said:I can give physical meaning to this by simply postulating some arbitrary frame to be the preferred one.
And I can simply postulate that some other arbitrary frame is the preferred one, such as Alice's (I assume you would postulate Bob's). Now what do we do?
If you're going to take this tack, you need to give some kind of physical basis for preferring the frame you choose. Can you give one?
rjbeery said:If it's true that after some time T_b, Alice cannot be saved by Bob under any circumstance as outlined in the OP, then I'm convinced that GR would allow for the formation of black holes as you and PAllen are saying.
And me. (Just sayin'. ) Classically (i.e., without any quantum effects included), this *is* what GR says.
rjbeery said:An extended discussion in this thread occurred when I brought up quantum effects, Hawking radiation, etc, and it sounds like the consensus on that is "no one knows enough to know the answer currently".
Yes. However, as PAllen pointed out, the weight appears to be on the side of "horizons still form, but no singularities do". If that's the case, then the quantum answer to your criterion is the same as the classical answer: there is some time T_b after which Alice can't be saved by Bob, in the sense of being kept from falling below the horizon.
However, there is a twist if the quantum answer does turn out to be that horizons form, but not singularities. In that case, what happens to Alice after she falls below the horizon? Classically, she would get destroyed in the singularity, but it's possible that quantum effects below the horizon could alter that fate. As far as I know, nobody has come up with a model that would allow her to eventually escape back out when the black hole finally evaporates, but I don't know that anyone has ruled out that possibility either.
Even if something like that last possibility pans out, however, it will still be true, if quantum effects allow the horizon to form, that there will be a *long* period of time for Bob between T_b, the last time at which he could keep Alice from falling below the horizon, and the first time when he sees any evidence of Alice escaping back out. (By "long" I mean times of the order of 10^70 years or more, IIRC, for holes of stellar mass or larger.)
